MM's resident Juice head
07 Mustang GT
A/C not working.
So the A/C hasint worked since i dropped in the stroker...just took it into ford today to get it looked at.
Service manager called and said the PCM wont let it turn on. I said DO NOT hook up your programming tool to my car, seeing how i have my nitrous dyno tune in there....so , has anyones tuner shut off their a/c while writing a tune? Also...i asked them to do a bottle test on my coolant system to see if a had a leaking head gasket....they said my car is to NEW to perform the test. They dont have the right connection to do it. WTF...so i have to pay for all the diagnosis and I got nothing acopmlished. Can you really turn off your a/c in the tune?
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
2005 Mustang GT Roush
You changed your SN? WTF I just got used to 07 procharger. As for your questions I guess it could be possible to disable the AC but I doubt it happened. Ford Service guys usually suck. At least in my expiriences.
2005 BLACK Mustang GT Roush #05-0090 DOB manifold, m122 SC, gt500 TB, 52lbers, KB BAP, AFCO HE,Brisk plugs, Mac Lt's, Off road x, Roush TVS CAI, Detroit rocker sc grind cams, Brenspeed 93 tune, 10 psi (2.875" pulley) 470rwhp-419ftlbs sae |
2005 Mustang GT
13.4@103
Ford used some crazy threads on the heads. My friend was going to do a comp test on my engine but both kits he had didnt have the right threads in there.
Sounds like it could have got disabled or there is an error in the system and it wont let it turn on. |
07 Mustang GT
they just called back...loose connection where it goes into the battery junction box. tip of the hat to my service department.
Good deal Ken. I may be using your Rad points when I get back. Not sure on what yet
07 GT-- Gone But Not Forgotten Military Crew E-5
07 Mustang GT
ya no prob, and I found a rad shop that will bottle test, so my service manager will take it there for me tomorow and test my head gaskets for me....fingers crossed!!!!
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Come on Stroker Boy. That's like my wife telling me the coffee machine is broke before checking if it was plugged in or not.
LOL, glad you got it working as we get into the summer months.
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
07 Boss you act like it gets HOT in Vegas...lol
07 Mustang GT
it was a connection under the fuse block in the engine bay...i never would have went chasing wires in there...you ever lfted up those blocks...lots of wires......no thanks.
2007 Mustang GT
hmmmm..........kinda wierd. I'm wondering why they can't do a headgasket check on your car??? Are you wanting them to pressurize the cooling system and check for leaks?? Maybe a vacuum test?? Or are you talking about the actual combustion gas check? Where the fluid changes colors in the tester if the coolant has combustion gas in it?
Bassani Crew Member #3 |
07 Mustang GT
pressurized coolant test...they say ford doesint have the tools to do it to these cars
2007 Mustang GT
wow. All it is is a normal cooling system pressure tester. Every dealer has one. Hell you can get them from Snap On or Matco, or Ford. Hell even craftsman/sears has them. The only thing "special" about them is the degas bottle adapter, which almost EVERY SINGLE Ford vehicle uses the same degas bottle cap..............We have been using them for a LONG time too, before 2000. Is your dealer living in the past?!? lol because they seriously wouldn't stay in business without that tool, you have to use it ALOT. Ken, you must have a special coolant bottle.
2008 Mustang GT
13.124@105.52
like he said... My Matco cooling system pressure tester has ana dapter for this bottle. And it is the same as every other Ford. Never heard of a "bottle test" though?? Pressure test may not be the best way to find a headgasket though. A combustion leak tester (the thing with the blue water that turns yellow) doesn't need any adapters, so I don't think that is what they meant either.
A/C works now? To the people that were wondering, yes A/C can be disabled in the tune if they set the paramater for WOT cutoff wrong.
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
07 Mustang GT
head gaskets are fine. the engine isint drinking anything other then air and fuel.
2007 Mustang GT
Thats good to know. BTW, how much fuel is that thing actually drinking?? alot more than stock??
07 Mustang GT
you know what ? its really not that bad with the 500 pumps and the 39#s, not as bad as I thought anyway.
2007 Mustang GT
ok, good. Im working on piecing together some stuff. I just can't make up my mind on what I want to use.
Blank
07 Mustang GT
milage on the car is 12500
milage on the clutch and engine is 500
Blank
I meant miles per gallon. My bad
Threads Similar to: A/C not working.
| AC not working | BoostHard1210 | 99-04 | 15 | May 12th, 2009 01:20 AM |
| Who's working? | ~C~ | The Clubhouse | 21 | April 16th, 2009 11:22 PM |
| my a/c is not working | XPLICITSTANG | 99-04 | 7 | November 11th, 2008 12:56 AM |
| AC not working | chuck&monika | 2005 - 2010 | 5 | August 6th, 2007 01:33 PM |
