11.94 on 20" nitto 555's
"How in the hell did that just happen???" was what I was thinking after that run.
The weather was pretty good 82 deg and mild humidity. I just don't get how I could run .24 slower than my best run on M&H drag radials.. on 20" Nitto's at full pressure. I launched at idle and it didn't slip at all, 1.92 60' , 123 mph. I guess I need smaller DRs but the 20"s seem the same height...
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
One Man Wolf Pack
Damn, nice work.
![]() ΜΟΛΩΝ ΛΑΒΕ
I think it might be about tire size... OK tire guyz... what is the height of a 255/35 20" vs 325/45 17"
2008 Mustang GT
13.124@105.52
wow you ran 4 MPH faster?
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
2005 Mustang GT
10.32@137.70
your clutch might be slipping on the drag radials. I feel your pain I went to the track a couple weeks ago and couldn't get my nitto drag radials to hook and was running between 11.8-12.2 @ 126-128 mph.
326 cubic inches of Turbocharged hell will be running soon Tuned by Wes @ TPS ![]() |
I guess it could be the clutch... spec 3 clutches aren't all that...
May 08 ROTM
2008 Audi S6
Livernois has been making hot passes on the 20" radials since they released. One of the main reasons I elected to put them on, that and I burned through several sets of street tires dancing all over the street. Good to see another car doing it on the same tire. I made all my 11 sec passes on 18" nittos and have yet to make a prepped pass on the 20's.
I can manipulate the tire pretty good on the street, so I'm expecting to have some confidence on a prepped surface. Did you try any passes with a higher launch rpm?
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
11's on 20's is impressive. I know you were not as quick, but you were faster.
#9 | |
2007 Mustang GT
325/45/17 = 28.52" diameter tread width (255) X sidewall aspect ratio (35%) X 2 (2 sidwalls in the daimeter) / 25.4 (conversion from mm to inches) + 20 (rim diameter) = 27.03" tire height/diameter. 325 X .45 X 2 / 25.4 + 17 = 28.52" I run a 28.8" tire and that drops my effective gear ration from 4.10 to 3.84 compared to the stock tire size.
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
Made in U.S.A.
2011 F150 FX4
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
Are you talking about the Drag Radials or the 'standard' 555s?
Emay, do you recall what times they were running? I know they were running a 20x10" wheel with 305/35/20 Nitto NT555Rs. I thought they were running 10s or low 11s on them. |
these are just the street 555's... what size tire do I need for a 17" wheel to be 27" tall??
I suck at math... I am going to try it though Rep U Boss
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler Last edited by 2006greyGT; July 4th, 2009 at 09:37 PM. |
I tried it just like you wrote it and got something different
#13 | |
2007 Mustang GT
If you want to stay with the 325, a 325/40 would be 27.23", which is pretty darn close. A 325/35 would be just under 26".
04 mustang gt
7.21 @ 98
very nice and nice mph
![]() cams + 150 shot |
2008 Mustang GT
11.35@123
I run 12.20 on 275/45 17s mickeys drag radials and 12.40 on my 305/35 20s Nitto drag radials. 20s are so tall I dont even get to fourth gear!
CRT-Performance Tuned by Jeff Chambers in Norwalk Ohio, 2.6 Kenne Bell, 62mm T-Body, LT Headers, O/R H-pipe, 4.10s, Foxlake CNC Heads, VSR Stage 2 cams 530/447 Mustang Dyno www.crt-performance.com |
Threads Similar to: 11.94 on 20" nitto 555's
| Nitto 555's at the track | Willy Mo | 99-04 | 19 | May 21st, 2009 01:25 AM |
| Nitto NT 555's | SlammedGT | Parts | 22 | January 31st, 2008 01:23 PM |
