Comp Thumper, NSR, and FRPP Hotrod cams - Page 3
Old July 14th, 2009, 09:48 PM   #41
shanec's Avatar
shanec will become famous soon enoughshanec will become famous soon enough
Thats from august of 2008.
I wouldn't be suprised if those werent SPR cams. I had two well known shops referering to SPR cams as thumpr's in that time frame. Even had a guy argue with me that I had thumpr cams in my car. LOL. It came from comp not listing Thumpr cams and adding SPR cams. Some people just assumed Thumpr cams were the nick name for the new SPR cams.
They loose low end power, or my name isnt Rich
A while back, I am pretty sure I read on their site that those were SPR cams. I can't find that page now though. The graph shows them not losing low end power. I doubt they made up the graph, BUT....look at where the rpm starts. They did manged to not start the chart until 2500.
Old July 14th, 2009, 10:23 PM   #42
Blank
unlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to beholdunlicensed to drive is a splendid one to behold
Originally Posted by 07 Boss View Post
The good shops around here charge from $60 to $90 an hour. Anything more than that I better be getting a piece of ...............................oh I forgot your just a young padowan. Those are pretty fair rates for top notch work, you shouldn't have to pay more than that wherever you are.
I may be a young padawan age wise but not mind wise.
16 year olds are doing it in their driveway in 4 hours. 800 is rape anyway you break it down.
I wouldn't be suprised, heck all it basically requires is cleaning the valve cover gasket, valve cover gasket groove, and head surface, rotating the crank to 12 then 6 o clock, taking off the valve covers/things connected to them, cam sensors, phaser bolts, stock cams, battery/battery tray, CAI, 3 followers(by using compressor tool), and the cam journal bearing caps, using the timing chain wedge to keep the timing chain from rotating any ticks, and putting everything back on.
But when you reinstall the stuff you replace the stock cams with NSR Cams and the now torque stretched stock phaser bolts with new ones, then you also have to put new PTV sealant on the valve covers.
I can't believe I have this crap memorized.
Old July 14th, 2009, 10:31 PM   #43
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
Just cuz you got it memorized doesn't mean you can do it
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old July 14th, 2009, 10:33 PM   #44
Blank
True, very true, it's just that having it memorized gives me more confidence in me and my dad not screwing up if we do it ourselves, even though I doubt we will at this point.
Old July 14th, 2009, 10:34 PM   #45
ixmotoxi's Avatar
08 Alloy GT
ixmotoxi will become famous soon enough
Send a message via AIM to ixmotoxi
vroom.
Old July 28th, 2009, 05:12 PM   #46
shanec's Avatar
Update....
Was just looking at Comp Cams website, and they're claiming that SPR cams lose nothing down low. So yeah that Dynospeed Racing dyno I posted here must have been SPR.
Comp Cams info - Ford 3 Valve Camshafts
Comp Cams dyno charts. Check out the SPR series...looks real close to stock at lower rpm levels. - Ford 3 Valve Camshafts
Old July 28th, 2009, 05:46 PM   #47
2007 Mustang GT
kraigster will become famous soon enough
Here is my dyno graph with SPR Stage 2.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
Old July 28th, 2009, 05:50 PM   #48
shanec's Avatar
Did you lose any low end power?
Old July 28th, 2009, 05:55 PM   #49
2007 Mustang GT
No, there is plenty of low end balls. You have to remember when they make a dyno pull they try to keep it in a 1:1 ratio which is 4th gear. So yeah, they gun it in 4th gear at about 1500 rpms. In real life when we race we don't do that, so figures below 2000 rpms are not that important in the racer world, IMO.
Old July 28th, 2009, 06:18 PM   #50
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
You loose a little down low yes. You need 4.10s with those cams. If you have 4.10s, its not problem, 3.55s or less, its going to be a dog. No matter what any dyno says.
Old July 28th, 2009, 06:37 PM   #51
2007 Mustang GT
Yeah, I guess with the 4.10s it gets you into the range quick. If I could ever figure out how to get my youtube vid on this website, I would post it. Anybody know how ?
Old July 28th, 2009, 06:51 PM   #52
2007 GT
I just copy and paste the URL.
Old July 28th, 2009, 06:55 PM   #53
2007 Mustang GT
Under manage attachments or trackbacks ?
Old July 28th, 2009, 07:06 PM   #54
2007 GT
no the actuall url up in the address bar of the browser. Thats how i put youtube videos. photobucket is different.
Old July 28th, 2009, 07:35 PM   #55
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
whatever
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Threads Similar to: Comp Thumper, NSR, and FRPP Hotrod cams
Comp NSR Stage 2 vs FRPP Hot Rod Cams 06GTMustang89 2005 - 2010 87 March 18th, 2009 10:10 PM
BBR Stage 2, FRPP Hot Rod, Comp Stage 4 or Comp Thumper Cams ivan48humble 2005 - 2010 179 December 8th, 2008 02:19 AM
Video of Comp Thumper Cams. 90Stang 2005 - 2010 30 November 14th, 2008 05:20 PM
Comp thumper cams 90Stang 2005 - 2010 15 October 21st, 2008 05:27 PM
Video of Comp Thumper Cams 06RedfireGT 2005 - 2010 15 September 13th, 2008 05:49 PM
