2007 Mustang GT
Drag Radial Size ?
I want to buy some drag radials for the dragstrip. I'm probably going to get M/T drag radials, my current wheels are the 18" bullits. My question is will 18" drag radials hook up as well as 15" drag radials. I don't have a problem with buying rims for the rear if need be.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
A taller sidewall will help you hook better. Is an 18" going to be enough tire for you, probably, but taller is usually better.
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
2007 Mustang GT
So with a 15" your going to have more sidewall, so would it hook better ?
2007 Mustang GT
The taller sidewall will allow your tire to flex more. The flex kinda acts like a shock absorber with the power from your rim to the pavement. All the torque gets there, it just doesn't hit as hard.
2007 GT
if i had it to do over again i would just get a 15 inch rim and et streets for the drag strip. No point in constantly competing and comparing your times to people with better rim tire setups.
Bogart is at the end of design and starting production on a streetable rim for our car. He said it was like 2lbs heavier then the race rims they sell. So like 15x11 and 15lbs. Nasty. Not sure if you looking to get that aggressive but she'll hook and loose some weight as well. going to cost big bucks though. Just a thought, but yea to me 15 inch rims are the way to go. |
2007 Mustang GT
I wouldn't mind getting some Bogarts for the rear. I have set of 15" Weld Prostars I used to run in a fox body but I'm not sure what offset I would need to use those for the time being.
Made in U.S.A.
2011 F150 FX4
Bogarts, Cobra Jets (Bogarts), Holeshots are the choices for 15" wheels. I'd really like to get some on the rear with slicks but can't stomach the $400 price tag right now. Anyways, if you can get the 15" wheels than do it. I'd recommend going with the Holeshots.
#8 | |
2005 Mustang GT
10.32@137.70
If you want a 15" wheel option besides the $400 dollar a piece then look at this thread and it can point you in the right direction. Combined 15" wheel Fitment Thread - WWW.S197FORUM.COM
350 rwhp and 310 rwtq at 6000 rpms through stock exhaust system 326 cubic inches of Twin Turbocharged hell will be running soonTuned by Wes @ TPS ![]() |
#9 | |
2007 Mustang GT
Threads Similar to: Drag Radial Size ?
| new goodyear drag radial | e3sean | Drag | 4 | June 29th, 2009 04:41 PM |
| which drag radial | jayrock | Drag | 10 | May 7th, 2009 02:48 PM |
| 20' drag radial | tarpeeler | 2005 - 2010 | 13 | August 21st, 2008 12:35 AM |
| charged 08 GT drag radial size? | onebad2v | 2005 - 2010 | 7 | July 21st, 2008 02:28 PM |
| Drag Radial Shopping | Cricket | The Clubhouse | 5 | July 6th, 2008 11:44 PM |
