What excalty does the overdrive button do!?
Old February 4th, 2007, 01:43 AM   #1
FLA Dreadhead is on a distinguished road
I kno it has somehting to do witht he rpm, but is it better to drive with it on or off?
2006 Mustang Gt
Silver
Borla Cat Back Exaust
K&N Intake
Throttle Body Spacer
more to come!!!!
Old February 4th, 2007, 01:55 AM   #2
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
It turns town the BTU factor of the Dilithium Crystals via the Gallo 24 induction switch.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old February 4th, 2007, 01:56 AM   #3
TheUNZippee!'s Avatar
Leave it on. It lowers your highway rpm's, increasing your fuel mileage when you drive the car normally.
You can shut it off if you want it to be in one gear lower, but it's easier and more fun to just move the shifter to where yo uwant it anyway.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old February 4th, 2007, 02:22 AM   #4
so your sayin it adds a gear?
so instead of 5 i have 6 gears, or does it just make 1 gear last longer...?
and yeah wuts with the 1 and the 2, i always just leave it in drive and thats it...what would be a scenario for using the 1 and 2, since you say its more fun?
2006 Mustang Gt
Silver
K&N Intake
more to come!!!!
Old February 6th, 2007, 05:44 PM   #5
jat
jat is on a distinguished road
Send a message via AIM to jat
so ur saying leave it on? for better mileage
Old February 6th, 2007, 06:02 PM   #6
You have a 5 speed automatic transmission. 5th gear is your overdrive. Turning the OD off with the button drops you into fourth gear. For normal driving, just leave the OD on.
Old February 6th, 2007, 07:00 PM   #7
jat
so if lets say im planning on fuck around with my friends doing alil racing. i should leave it on?
but why when i hit the button and turn it off do i feel my car have a quicker respnonse on the throttle?
also when i launch the car from a stand still i feel the car accelerates quicker IMO
Old February 6th, 2007, 07:23 PM   #8
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
example for turning it off is like if i were on the highway in my 5 speed manual. turning off your overdrive would be like me shifting into 4th. if you are just cruising you want to leave it on. it will do nothing for your throttle responce.
as for the 1 and 2......
if you are racing from a stop you want to drop it all the way down to the 1. when you are ready for it to shift to 2nd gear push it up to the 2. next would come your drive gear "D". you'll want to shift close to the redline on your tach.
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old February 6th, 2007, 08:42 PM   #9
jat
confused...
ill just leave the automatic n keep it on.. i guess
Old February 6th, 2007, 08:59 PM   #10
03 Mustang GT Twin Turbo
10.43 @ 139mph
WAVEBYE is on a distinguished road
Send a message via AIM to WAVEBYE
turn off the O/D on city streets and turn it on when you hit the highway/interstate/freeway whatever. the increased load on the tranny with it being in a higher gear when normal driving will wear it out prematurely and if you leave the O/D on in the city,the constant kicking down to pass or whatever will wear it out quicker too. if it's a 4-speed auto leave it in 3rd or whatever your case maybe.
Nobody gonna take my car
Im gonna race it to the ground
Nobody gonna beat my car
Its gonna break the speed of sound
Oooh its a killing machine
Its got everything
Like a driving power big fat tires
And everything - Deep Purple
Old February 6th, 2007, 10:47 PM   #11
Jat, your transmission has 5 speeds. The 5th & last gear is called overdrive.It utilizes a lower number gear, usually around 0.70 to 1. Your first gear has a ratio of about 3.30:1. meaning first gear is multiplying the engine's torque by spinning a shaft inside your transmission 3.3 times faster than the revolutions of the engine.This does not mean it makes your engine have more torque, it means it is multiplying that torque 3.3 times through use of gears.
Now if you go back to the OD ratio of 0.70:1, this means that the shaft in your transmission is spinning SLOWER than the given rpm's of the engine, which is good for highway driving, as a lower rpm equates to higher fuel economy.However OD does not work well for pulling, since it effectively reduces the torque (not actual numbers at the flywheel) that the transmission sees.Which means the internals of the transmission have to work harder and can wear out faster.
If towing or in high snow turn your OD off, or you can cause early tranny failure due to intermittent on off load shifting.
During general driving it is fine and better to leave it on, even while city driving. The times to turn it off: 1)when you are towing something, or may have a heavy load or 2)when you are driving in the mountains; while going uphill sometimes O.D. will shift back and forth frequently, if this occurs definitely turn off the O.D. so the tranny will not over-heat.
However, the best thing to do, is open up your owners manual and follow what it tells you to do.
Old February 6th, 2007, 11:46 PM   #12
10.43 @ 139mph
lol
Its got everything
Old February 7th, 2007, 12:00 AM   #13
im always in the city i live in the city with a lot of stop and go, so would it in the long run hurt your transmission if you leave it on all the time, or does it not make a diffence?
2006 Mustang Gt
Silver
K&N Intake
more to come!!!!
Old February 7th, 2007, 12:09 AM   #14
Dude just read your manual, if I type another long post WAVE might tease me again. lol
Seriously, just check your manual, or ask your dealer.IF I had to choose one way myself, I would go with what WAVE said earlier, and have it off in town and on when using the highway.
Old February 7th, 2007, 04:50 AM   #15
manOwar's Avatar
manOwar is on a distinguished road
It does not shift into OD until 45mph. Leave it in Drive with the OD on unless your Towing.
2007 Alloy/Satin Silver KB GT500
703rwhp/628rwtq SAE
http://www.cardomain.com/ride/2537363
Old February 7th, 2007, 07:07 AM   #16
GTNorm's Avatar
GTNorm is on a distinguished road
After reading all these posts I can see there is a plethera of information here, but Justincredible said it best in the 2nd post.And for the record it can't possibly have any affect on how you launch Jat, it is 5th gear.
A man with experience is never at the mercy of a man with a theory.
Old February 7th, 2007, 09:23 AM   #17
Grabber427's Avatar
2007 Roush 427R
Grabber427 is on a distinguished road
Get a 5 speed and learn to use a clutch, it's more fun and you have better control.
2007 Roush 427R #07-486
FRPP 3.73 Gears
Roush short throw shifter
Roush 73mm pulley and tune
Old February 7th, 2007, 11:51 AM   #18
oh, ive never driven a stick in my life...lol, as sad as it sounds, but im only 18, so i take it sticks dont have an OD button huh?
2006 Mustang Gt
Silver
K&N Intake
more to come!!!!
Old February 7th, 2007, 09:37 PM   #19
2k05gt's Avatar
2k05gt is on a distinguished road
Calculators:
This is a Microsoft Excel Worksheet the calculates Rear End Gear changes and there effects to RPM and Speed. Also there is a calculator that will assist you in selecting the correct Tire size for your car including what Wheel and Tires combo will fit.
look at the gear ratios and this may explain it, play with the calculators watch the graph change it it does not explain it for you at least you get a good show :wink
Download the sheet here.
http://home.comcast.net/~swieduwilt0...lculations.xls
you can get an excel viewer that plugs into your browser here:
http://www.microsoft.com/downloads/d...displaylang=EN
I wish I could get a 5 Speed Manual, but I have a Bad Left Knee, Motor Cycle accident at 22 F'ed up my knee good,
___
12.29 @ 110 All Motor (Auto w/TCI 3500 Converter & Bolt-Ons)
Threads Similar to: What excalty does the overdrive button do!?
O/D Button? burnout5.0 94-95 8 May 22nd, 2012 09:26 PM
hey is there a button BWAL The Clubhouse 1 September 12th, 2007 08:58 PM
Push button start Juggalo_X V6 Mustangs 26 September 8th, 2007 12:51 AM
trunk release button 06RedfireGT 2005 - 2010 32 July 11th, 2007 08:24 PM
Overdrive Button! rene97 96-98 17 March 10th, 2007 11:06 PM
