Eibach Sportline Springs
Old July 29th, 2009, 03:32 PM   #1
highwayman24's Avatar
2011 Mustang 5.0
highwayman24 will become famous soon enoughhighwayman24 will become famous soon enough
If I get Sportline Springs is there anything I have to do in conjunction with them under the car? i.e. move the drive shaft, E-Brake Line, etc.?
"Nice penis, Officer. "
Old July 29th, 2009, 03:34 PM   #2
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
nope
get lca's and relocation brackets though from BMR
Under Construction
Old July 29th, 2009, 03:37 PM   #3
2011 Mustang 5.0
Originally Posted by Mickey View Post
nope
I just knew you would be the one to answer this question.
Old July 29th, 2009, 03:39 PM   #4
bigpappy33's Avatar
2006 Mustang GT
bigpappy33 is just really nicebigpappy33 is just really nicebigpappy33 is just really nicebigpappy33 is just really nice
watch out for speed bumps?
2006 Mustang GT
GT500 5.4L 4V and TR6060 - 566 RWHP/550RWTQ - 11.17 @ 126 - Mods in Garage
Old July 29th, 2009, 03:41 PM   #5
2011 Mustang 5.0
haha, I also a Mazda Miata, and they are a bitch...
Old July 29th, 2009, 03:46 PM   #6
2011 Mustang 5.0
This the best for the job?
BMR REAR CONTROL ARM PACKAGES
Old July 29th, 2009, 03:47 PM   #7
Mickey's Avatar
perfect..exactly what I have
Under Construction
Old July 29th, 2009, 03:56 PM   #8
ixmotoxi's Avatar
08 Alloy GT
ixmotoxi will become famous soon enough
Send a message via AIM to ixmotoxi
mickey- Did you have your relocation brackets welded?
vroom.
Old July 29th, 2009, 04:30 PM   #9
2007 GT
07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of07stanggt has much to be proud of
I beg to difffer that you dont need anything with sportlines. With anything less then a 1.5 drop you can get away with doing nothing else even though its not ideal. With sportlines you need good shocks, you need relocation brackets, you need adjustable upper control arms, problaby a bumpsteer kit. You're just going to end up with a car that rides like shit and handles like shit all so it looks good? Do you want to look at it or drive it? To me if you cant afford to do the sportline level drop the right way learn to like a 1.3 inch drop.
IXMOTOXI. Got your pm. Sorry im on a time crunch trying to get my car fixed and im just consumed with it. On the welded relocation brackets. I dont have mine welded, for 100 passes, 389 hp, 1.70 60s now. Everyone is going to tell you to weld them. with some brands maybe you do, with bmr, I dont. Im just now cutting the kinda of 60 ft times that im probably going to get them welded if I get any more serious with the strip setup. But, 97k 100 passes and some trips to the road course and they are not welded. FWIW.
Old July 29th, 2009, 05:38 PM   #10
2011 Mustang 5.0
Now, I'm confused.
Old July 29th, 2009, 05:43 PM   #11
bigpappy33's Avatar
2006 Mustang GT
rich is a bamf, im too scared and got my brackets welded, this picture scared me
2006 Mustang GT
Old July 29th, 2009, 05:48 PM   #12
2007 GT
About what.
Old July 29th, 2009, 05:51 PM   #13
2011 Mustang 5.0
About what.
I was intending on getting the LCA's, but I'm not so sure about the UCA's and don't they have to be installed by a pro?
Old July 29th, 2009, 05:51 PM   #14
2007 GT
Notice the QA1'S and the rocks still stuck to that sticky tire. Homeboy was cutting some serious 60s.And probably making some power. Its your ride, you gotta sleep at night. But for me, i go with BMR, then say i dont need them welded until im cutting 1.70 60s, them I dont worry about it. I get a set of bogarts on my car, then welded for sure.
Old July 29th, 2009, 05:53 PM   #15
2007 GT
UCA be installed by a PRO. No its two bolts. Adjusted by someone that knows how to set the angle. Yea, probably a good idea.
You need more then LCA's for Sportlines if you want to keep a decent ride and good hanlding car.
Sportlines are a 1.6 and 1.9 inch drop? Right, or am i having a off day.
The angles on your suspension are going to be jacked, understeer will be worse becuase the a arms will be lower at the K member then they are at the tires. the rear lowers will be higher at the axle then at the chassis. The dampers will be overpowered by the stiffer springs and operating out of their stroke range so they will be stiffer constantly and wear out faster, the rear wont be anywhere near centered. Pinion angle also shallow.
You need adjustable upper control arm, lower control arms, relocation brackets, adjustable panhard bar, bump steer kit, and Bilsteins. And dont even think about 20 inch rims with those springs, it will hit like a tank.
Send me a Christmas card.
Old July 29th, 2009, 05:55 PM   #16
2011 Mustang 5.0
The angles on your suspension are going to be jacked, understeer will be worse becuase the a arms will be lower at the K member then they are at the tires. the rear lowers will be lower at the axle then at the chassis. The dampers will be overpowered by the stiffer springs and operating out of their stroke range so the will be stiffer constantly and wear out faster, the rear wont be anywhere near centered. Pinion angle also shallow.
What about the Eibach Pro-Kit? 1.4 in the front and 1.6 out back. What do I need for that? And I was going to install the LCA myself, but I don't think I could install the adjustable UCA's for anything.
Old July 29th, 2009, 06:02 PM   #17
2007 GT
eibach pro kit for our car is 1.3 and 1.4. You might be looking at a spec for the convertible? Or actually let me back up, maybe you have a convertible? In which case thats probably the drop becuase the convertible sits higher to begin with. The springs are actually the same though.
any of the springs in the 1.5 or less range you can get away with not doing all that stuff. Pro kit, ultra lights, FRPP, ETC. The less the drop the less the issue. The lower control arms and relocation brackets to me are always a good idea.
Check out BMR springs. 1.25 in the front 1.5 in the back.
Old July 29th, 2009, 06:08 PM   #18
bigpappy33's Avatar
2006 Mustang GT
i am running the pro kit on the stock shocks with LCAs, brackets, and an adjustable panhard rod. all BMR. The ride is kind of stiff with my 20s, but i will be upgrading shocks soon once the stockers are worn (which will be quicker than normal because of the higher spring rate). The drop is enough for me, i didnt see the need to slam it like the sportlines do.
pic of pro kit drop on 20s
picture on stock 18s
2006 Mustang GT
Old July 29th, 2009, 06:27 PM   #19
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
I believe the pic of the bent relo bracket was the original design and has been updated for some time now. Read that on another forum but dont remember where, so I cant validate it
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old July 29th, 2009, 06:43 PM   #20
Mickey's Avatar
You dont need to but I did it anyways...
Rich is correct on the adjustable UCA being a good thing to have with the sportlines...is it required? no, but its beneficial to realign the pinion angle of the driveshaft
Under Construction
Threads Similar to: Eibach Sportline Springs
Eibach Sportline Springs bubsdelicious 5.0 Mustangs 2 September 5th, 2008 08:27 PM
eibach sportline springs ponygt 99-04 11 August 27th, 2008 06:08 AM
