helpp supershaker
ok im installing my supercharger and just got everthing taken down and realized i didnt pull the fuel pump fuse and run the car dry. can i just use the disconnecting tool and take the fuel line off the rails or is there more?
Saleen Super Shaker; sct 93 tune; frpp stingers; pypes off road X; Hurst Comp Plus ; FRPP springs; BMR panhard bar; Steeda LCA; BMR relocation brackets; rotorpros drill/ slotted; foose nitrous 20' wheels; nitto 555's; avic fb700
That should be fine. Just place alot of rags around and under it. Do it slow. Then when you pull the rails off have to rags to catch the residual coming out the injectors. I haven't done this but its what I would do
07 GT-- Gone But Not Forgotten Military Crew E-5
2007 GT
An easier way may be to pull out the filter ... will keep the fuel spill below the car at least ... keep the tool inserted on the front side line ... should allow it to drain, I don't believe there are any check valves along the way up.
Yea that could work also
alright well i dropped the line right after the fuel filter towards the engine not much came out. anyone have experiance with disconnecting at the fuel line?
2007 GT
At this point I say just pull it and be ready with a few rags ... whatever is laying in the rails is all that should come out.
#7 | |
Other than that you should be fine. |
Threads Similar to: helpp supershaker
| helpp! | Ryguy33 | 99-04 | 7 | June 28th, 2009 03:43 PM |
| Need stock motor mounts for Supershaker | tribaltek | 2005 - 2010 | 14 | May 11th, 2009 10:30 PM |
| Saleen Supershaker sale | usafimj | 2005 - 2010 | 14 | December 21st, 2008 03:33 PM |
| Helpp Pleasee!!!! | 01sta1k3r | 99-04 | 2 | August 17th, 2008 09:57 PM |
| Need Helpp | ThE GhOsT RiDer | 5.0 Mustangs | 5 | December 31st, 2007 05:23 PM |
