N E 1 know if these will fit?
I am thinking about these for the strip only.. just the back.. any clearance issues....
15X10 WELD RACING PROSTAR WHEEL 5X4.5 4.5" BS
![]() 2.6l KENNE BELL 298 Stroker, Ported heads Pro Motion Built 3650/McLeod RST/ MGW Short Throw Long tube/O/R X /Borla Touring 8 rib/65 lb injectors/GT500 twin fuel ET Drag Slicks/3.73 gear Detroit Truetrac /CDC AGR Spoiler |
Made in U.S.A.
2011 F150 FX4
Well I thought you need like ~7" of backspacing.
Weld offers a new line-up of wheels that do fit the S197s though.
2005 Turbonetics Baby!!!
You will need 7 1/2" of backspacing for them to tuck without spacers. Check out this thread for just about anything you ever wanted to know about 15" wheels that will fit our cars. I go by ROUSH STAGE 4 over there and some of my research has been documented too. Lotsa great info there...
Combined 15" wheel Fitment Thread - WWW.S197FORUM.COM
![]() Turbonetics baby!!! 11.23@122 mph... |
is the only reason for the backspace to keep them inside the fenders??? I am only going to run them at the strip...
Dude, those wheels alone will stick out 3 inches past the side of the car, plus the tire width... but yeah...that's why. The inside of the wheel needs to be flat too so it won't hit the brake caliper.
If you don't mind them sticking out past the edge of the car, Summit and Jegs make a wheel that is ALOT cheaper and has 6 1/2" backspacing...and it's 10" wide. With any 10" wide wheel you will have to relocate the swaybar too.
Made in U.S.A.
2011 F150 FX4
Good luck tucking the tires on a hard launch ...
If he runs a short enough tire, it won't matter, it won't be optimal either though... I'd just get the old tried and true ones that tuck and call it good....
well I am running a 28" tall tire now... it killed my ratio and all I need is 2 more tenths.
I ended up getting 15x8 with a 5.5 backspace.. MT ET slicks with tubes 26x10... am I going to be allright with this setup?
I read through all 15 pages of the link to s197 you posted... but I am not sure still... well they are bought and they are the Weld Prostars... I have a grinder and access to a set of v6 calipers... they WILL fit!
2007 Mustang GT
Did you order Prostars ? I tried to mount some Prostars 15x8 w/4.5 backspace just to see if it would clear the brake caliper and it wouldn't.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
I think I might have to do a little work on the calipers... could you see how close yours were to fitting?
2007 Mustang GT
12.6@110
you tryin to get a cage or somethin?
![]() Professor Crackers
I changed... I killed the Weld Prostars and got the Jegs Sport Stars ( Rear : 15x8 W/ 5.5 BS , PN: 555-67077 ,NO Spacers , NO Relocated Swaybar , both front and rear use factory length studs and stock conical style lugnuts)that fit w/o the hastle of making them fit... staying with the 26x10 MT et slicks to put on them.
I am going to go out and run a 11.69 tonight on whats left of my 28" tall dr's.... then when I get the new set up done I will see how low I can go... I know the guys pretty well out there and as long as I don't run sub 11.50 all night I can get away with one or two as long as nobody complains.. this might be the last good night for a while... it is going to get hot..
2007 Mustang GT
Thats a smart choice, because when I measured the space needed with the Prostars, it was like 3/4" needed to clear the calipers and thats alot of Gurindin'.
I smashed by best time by a tenth!!!!! wholly crap was it a perfect run for my set up...
2007 Mustang GT
12.6@110
great job! I need to head back out there sometime, I should be good to go in a few weeks. Have a few new items I need to break in next week
Congrats on the new times.
2007 Mustang GT
Your headed in the right direction. Congrats. !
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Is it me or should you be going a tad quicker based on your Mods?
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
Threads Similar to: N E 1 know if these will fit?
| will it fit? | ZoomZoomMFer | 99-04 | 21 | August 16th, 2008 05:15 PM |
| Will it fit??? | nitrorustlerpro15 | 5.0 Mustangs | 13 | June 25th, 2008 09:39 AM |
| Will this fit? | 2006GTARPD3 | 2005 - 2010 | 10 | June 23rd, 2008 05:23 PM |
| Will These Fit?!?! | ZoomZoomMFer | The Clubhouse | 11 | June 9th, 2008 12:58 PM |
| what would i need to get this to fit | Timmano | V6 Mustangs | 29 | October 12th, 2007 09:40 PM |
