Last Exhaust Thread... I Swear :D
Old August 15th, 2009, 06:49 AM   #1
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
okay so i got my stinger's on... thanks to my buddy DAMN that driver side last bolt takes forever to remove... anyways my passanger side is sagging a bit.. i dont know how to raise it up... if i try to move it more into my mid pipe it doesnt line up with my driver side... anyone had this problem and know how to fix this?
Thank's
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old August 15th, 2009, 10:48 AM   #2
algx's Avatar
2007 REDFIRE VERT GT/CS
algx is on a distinguished road
Pics would help, but right off the bat, bending the support rods might make it work.
I had to bend them a little to get my Magnaflows to line up nice.
FRPP Whipple HO, FRPP 4.10, Magnapacks, SSC springs, BMR adj. panhard bar, Hurst Billet STS, 285-40-18 / 255-45-18 BFG T/A
Originally Posted by Violent Acres
...Fat chicks don't suck dick, it makes them hungry...
Old August 15th, 2009, 11:09 AM   #3
2007 Mustang GT
07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold
Loosen up the exhuast clamps and us a large pry bar to bend everything into place and then tighten up all clamps. Just takes a little trial and error before they end up straight. Little tip, when you tighten the clamps your exhuast should be "relaxed". Don't be holding stuff in position while tightening clamps.
Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit
Old August 15th, 2009, 11:45 AM   #4
2007 Mustang GT
kraigster will become famous soon enough
Make sure you have the support rods through the center of the rubber hangers and not off to the bottom. You can bend the support rods a little to achieve propper position.
Saleen rear fascia with center exhaust, MAC longtubes with o/r Prochamber, Steeda CAI w/carbon fiber elbow, SCT X3, Steeda UDPs, Hurst shifter, modified delete plates, Comp Cams and 4.10s.
Old August 15th, 2009, 01:13 PM   #5
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
When I did my full exhaust I put it on a lit, loossened everything from the midpipe back, used some exhaust stand that tucked everything closer to the body then did all my adjustments, and use air tools if available to get them nice and tight or else they'll come loose
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old August 15th, 2009, 04:47 PM   #6
GTPONY1's Avatar
2006 Mustang GT
539rwhp / 482rwtq
GTPONY1 will become famous soon enough
I agree with Boss, it takes a little finesse.. LOL I also found that rotating the pipe with the clamps slightly loosened will help you center the tips in the bumper cutout.
Old August 15th, 2009, 08:14 PM   #7
Hip Hop Artist
Youngin's Avatar
Byebye V6~
man it is such a hassle driving through speed bumps hearing clankity-clank again... you think the stainless steel hangers from AM would help both situation?
Old August 15th, 2009, 10:13 PM   #8
Hip Hop Artist
Youngin's Avatar
Byebye V6~
to go o/r bassani or catted bassani...?
Old August 15th, 2009, 10:24 PM   #9
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
If you are hearing some clanking then your clamps are not tight enough or the over axle pipes are bumping against something. Definatly use an impact ratchet/wrench when tightening everything up
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old August 15th, 2009, 10:25 PM   #10
Hip Hop Artist
Youngin's Avatar
Byebye V6~
yeah i just used hand tools. lol i should take it to a shop then they can tighten everything and align my tips right? shit hope they dont charge to much...
Old August 15th, 2009, 10:36 PM   #11
usafimj's Avatar
12.847 @ 114.12mph
Man if you thought axle backs was tough to install good luck on your futute mods. Axle backs are cake compared to everything else
Military Crew
E-5
Old August 15th, 2009, 11:06 PM   #12
Hip Hop Artist
Youngin's Avatar
Byebye V6~
its not tough... it was easy except for the one bolt right on top of the mufflers... it wasnt hard just took some time... i just dont know how to align them..
Old August 15th, 2009, 11:08 PM   #13
usafimj's Avatar
12.847 @ 114.12mph
It show's you how to align them in the link I gave you in the other thread
Military Crew
E-5
Old August 15th, 2009, 11:11 PM   #14
Hip Hop Artist
Youngin's Avatar
Byebye V6~
yeah i did that but its still sagging...
Old August 15th, 2009, 11:24 PM   #15
IBEATU
best way is just trial and error. loosen everything up including where your over-axle pipes connect to your midpipe, then set everything how you want it. some axlebacks are near impossible to line up...Stingers arent one of them
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
Old August 15th, 2009, 11:31 PM   #16
Hip Hop Artist
Youngin's Avatar
Byebye V6~
alright i will dirty one more shirt! one more time!
Old August 15th, 2009, 11:32 PM   #17
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Thank's again everyone.
Old August 15th, 2009, 11:37 PM   #18
algx's Avatar
Post count, ladies. Post count
Old August 16th, 2009, 12:00 AM   #19
bigpappy33's Avatar
2006 Mustang GT
bigpappy33 is just really nicebigpappy33 is just really nicebigpappy33 is just really nicebigpappy33 is just really nice
I had that problem at first, i ended up taking off the whole muffler just to be able to really bend the support rod. put it back on and i had bent it too much, but it was easier to pull down then to bend it up while on the hanger. good luck!
2006 Mustang GT
GT500 5.4L 4V and TR6060 - 566 RWHP/550RWTQ - 11.17 @ 126 - Mods in Garage
Old August 16th, 2009, 01:44 AM   #20
Flynnster's Avatar
2007 Mustang GT
14.70@97.24
Flynnster will become famous soon enough
Just keep at it man, told you it'l be a bit of a pain till it's right.
Black on Black 5spd '07 GT
FRPP Stingers
Originally Posted by king_Ahmet View Post
] but, if it tickles your sack in a funny way, have at it...
Threads Similar to: Last Exhaust Thread... I Swear :D
another exhaust thread WeCircleTheProblem Classic Mustangs 5 November 18th, 2008 07:32 PM
yes this is an exhaust thread v606er 2005 - 2010 6 September 22nd, 2008 10:16 AM
Another Exhaust Thread.. Sorry Had to ask andres0286 99-04 6 April 16th, 2008 08:26 PM
Yet another exhaust thread gragra73 2005 - 2010 5 April 6th, 2008 03:11 PM
Another Exhaust thread...yea I know Cricket V6 Mustangs 7 July 6th, 2006 06:55 PM
