2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Nut & Bolt Problem?
I'm trying to install my camber bolts. I got it figured out as to how to install the bolts, but how do you screw the nut onto the bolt. I know righty tighty, lefty loosy. Anyways the nut doesn't seem to want to go on. It screws part way on and then it won't go any further for me. At least without applying an enormous amount of torque, and I don't want to strip it. Has anyone had this issue with camber bolts?
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
Priest of the Car Gods
How do the threads look? If you have a tap and die set, you might want to give the threads a quick chase, just to make sure everything's kosher.
Oh, and CC plates ftw
#3 | |
2007 Mustang GT
Oh, and "HI" Reverand.
2008 Mustang GT
13.124@105.52
hmm. I believe they are lock nuts, but shouldn't be that hard to turn. Perhaps the threads on the nut are boogered up?
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
2008 Mustang GT
13.124@105.52
Boss, I looked at my bolts. They are deffinetely distorted thread lock nuts. You can see that the nut is sort of oval shaped. They screw on by hand like 4 or 5 turns, then get REAL tight. So yes, just force the bitches on.
Threads Similar to: Nut & Bolt Problem?
| Removing a %&#^@$ bellhousing bolt | IronStomach | 2005 - 2010 | 14 | April 18th, 2009 12:39 AM |
| Exhaust bolt/nut replacement | Cricket | 99-04 | 3 | September 3rd, 2008 10:21 AM |
| lt1, bolt ons &100shot | itschristorres8 | Racer's Corner | 12 | August 31st, 2008 04:36 PM |
| J&M 4 Bolt Chamber Plates | MyGT | 99-04 | 1 | July 1st, 2008 03:22 PM |
| ROLL CAGE & BOLT ON SUSPENSION PARTS | JACKEL142 | Parts | 1 | June 21st, 2007 09:59 PM |
