New rotors
Old August 17th, 2009, 05:41 PM   #1
pear0119's Avatar
2005 Mustang GT
13.50@105
pear0119 will become famous soon enough
New rotors
Well I finally opted for some new rotors. I decided to go with the EBC 3GD rotors with some EBC Red Stuff pads on the front and rear. now for my question, for the rear rotors is there any special way that the parking brake connects to the caliper that I need to worry about when changing the rotor and pads? Before I get under there and start ?
JLT CAI, FRPP 4.10s, FRPP Hot Rods, FRPP x-pipe, FRPP TB, CMCV, UDP, Spydershaft, JBA Shorties, Flowmasters, Hurst Billet Plus, AM/Bama 93 race, BMR STB, BMR adj. panhard bar+brace, BMR LCA's, BMR UCA+mount, BMR front+rear swaybar, BMR A-arm brace.
Old August 18th, 2009, 10:27 AM   #2
pear0119's Avatar
2005 Mustang GT
13.50@105
no one.
Old August 18th, 2009, 10:42 AM   #3
IronStomach's Avatar
2008 Mustang GT
IronStomach has a spectacular aura aboutIronStomach has a spectacular aura aboutIronStomach has a spectacular aura about
PM sent.
Maybe take good pictures along the way and post a writeup for everyone else?
Experience is what you get when you didn't get what you wanted.
Old August 18th, 2009, 11:12 AM   #4
need4steed's Avatar
need4steed is on a distinguished road
how much did the rotor kit cost you?
67 Mustang = 492 HP/478 TQ
07 Mustang GT = JLT CIA with SCT Tune, Drops
95 MarkVIII= Project/ resurrection
Old August 18th, 2009, 11:21 AM   #5
2007 Mustang GT
07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of07 Boss has much to be proud of
I run those rotors and pads and really like them. They do produce a bit of "air noise" though, so don't be surprised when you hear it. The parking brake cable should attach the same way as you take it off because it is attached to the caliper and that you're leaving stock, right?
Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit
Old August 18th, 2009, 11:46 AM   #6
pear0119's Avatar
2005 Mustang GT
13.50@105
I will see what I can do.
all 4 of them cost me about $470 excluding pads. Shipping to Canada well thats another story in its own.
Yes sir, they are staying stock. I don't do any racing so there was no need for calipers.
Old August 18th, 2009, 04:14 PM   #7
2005 Mustang GT
13.4@103
Avengence will become famous soon enough
As far as I know the back rotors need the piston turned to push it in. Do you already have a caliper tool? I know a lot of people use c clamps to clamp the pistons.
2005 Mustang GT 5spd
Steeda CAI, Bamachips Tune, FRPP 4.10 Gears, Pypes Violators, Eibach Sport Springs, DD Bullitts w/ Goodyear Eagle F1 Supercar tires (285s), Cervini's Billet Grille
Best 1/4: 13.4 @ 103
Old August 18th, 2009, 05:08 PM   #8
pear0119's Avatar
2005 Mustang GT
13.50@105
I don't have a caliper tool but I have several C clamps that I will be using.
Old August 18th, 2009, 11:19 PM   #9
5.0Massacre's Avatar
1986 toyoya corolla AE86
LOL @ WTF
5.0Massacre has a little shameless behaviour in the past
do NOT use a C clamp on your rear calipers! you will damage it, the rear caliper "pistons" screw in. you need a brake caliper tool that puts a small amount of pressure against the piston and turns it at the same time. If you just try to screw it in without any pressure it will just spin in place. both of the pistons screw in clockwise.
you need one of these!
make life a lot easier
Old August 18th, 2009, 11:27 PM   #10
I am Female!
Shanshine will become famous soon enough
Send a message via AIM to Shanshine
Most of the local auto parts stores rent the tool out.....Its like $40 but when you take it back they refund your money.
Old August 18th, 2009, 11:29 PM   #11
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
I use my channel locks and a bit of pressure and they rotate in just fine. Even after a full disassembly for powder coating and being basically bone dry.
If you do try it this way be very careful not to grab the rubber seal on the piston. Simple enough to avoid as there is plenty of metal to grab at the edge.
FLICKR Unique Imagery
Old August 18th, 2009, 11:30 PM   #12
LOL @ WTF
bought the whole kit for 20 bucks at harbor freight lulz
Old August 19th, 2009, 08:05 AM   #13
pear0119's Avatar
2005 Mustang GT
13.50@105
I will be making a stop to the local parts store before the install to get brake cleaner and stuff. I know they rent tools out so I will look into this at the same time.
Old August 19th, 2009, 09:59 AM   #14
AnimalCrackers's Avatar
2007 Mustang GT
12.6@110
AnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to allAnimalCrackers is a name known to all
definitely a +1 on the brake piston tool, rented mine from autozone and finished swapping rotors and pads in 10 minutes a side.
Professor Crackers
Threads Similar to: New rotors
Used rotors svt95gt 2005 - 2010 6 April 14th, 2009 08:10 PM
rotors justinsstang V6 Mustangs 8 November 26th, 2008 03:52 PM
what rotors to get? Srt2stang725 2005 - 2010 30 November 24th, 2008 04:51 PM
Rotors... soccerboy08 V6 Mustangs 17 January 28th, 2008 02:32 PM
new rotors.... 01silversnake 99-04 15 October 9th, 2007 04:18 PM
