vibrations
ok guys its finally happened and i need to know what you think.
while cruising at about 35-40 i feel vibrations and 120 up i have real bad vibration bad enough that i dont want to accelerate anymore, Could this be the doom of the 2piece driveshaft? |
2008 GT
Have you checked your wheel weights?
Fuel Altereds Rule The Earth
it feels like whatever it is its comeing from the drive train. worst part about it all is that my gears need reshimmed.
IBEATU
06 GT, 98 GT, & 93 Notch
reall could be wheel weights or if your tires are worn then they may just need re-balancing
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
IBEATU
unless its consistant at a certain rpm, it probably isnt in the drivetrain
just thinking maybe my driveshaft is out of whack its not at any certain rpm and it doesnt feel like a wheel is gonna fall off it feels like a wobble in the driveshaft how common is this with the 2 piece?
ill mention i can hear it too its a low frequency sound that i hear besides the gear whine that i still need to fix.
May 08 ROTM
2008 Audi S6
I forgot to call you back Ian, the symptoms you are feeling are not common to the two piece oem unit. It's not likely to be the culprit and I haven't seen anybody to date mention balancing a two piece.
Who did your gears? and why do they need reshimmed? If you had tolerance issues I wouldn't have pushed the car until those were rectified, especially 120+ blasts. Any sort of "freedom" back there would certainly enhance with increased speeds. Not that they are the cause, but that your causing adverse wear in doing so. |
well then shoul i reshim the gears or put the 4.10s back in the right way?
like i said the vibration isnt shaking the car but it feels/sounds like a wobble in the driveshaft.
May 08 ROTM
2008 Audi S6
I'd clean up the gear install, make sure that's mint and then tackle the drive shaft quirks. One may be causing or enhancing the other.
thanks Erin
2008 Mustang GT
13.124@105.52
I agree with erin, fix one issue first and see how it effects the other.
But, I'm not sure why you need to "reshim" your gears. If they were set up wrong, and you've driven like that this long, they will have taken a wear pattern and no shimming will fix it. Hate to say it, but you'll probably need new gears.
Hurst Crew Member #20 2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
1991 Mustang GT
If I had to guess anything my money would be on a bad or loss U Joint. I had some common things like you but I had a bad fly wheel with the U Joint and ToB. But recommend checking U joints first but after reading your last post you should feel the vibrations pretty good but it wouldn't hurt.
Threads Similar to: vibrations
| Vibrations | JKennedy | V6 Mustangs | 10 | February 12th, 2009 09:41 AM |
| Vibrations | Zatrekaz | General Tech | 7 | July 9th, 2008 11:34 AM |
| vibrations | MikeD05GT | 96-98 | 5 | May 1st, 2008 11:09 AM |
| Vibrations! | sneezingfox | 5.0 Mustangs | 35 | April 7th, 2008 10:04 PM |
| vibrations | 89beastin | 5.0 Mustangs | 8 | April 16th, 2007 01:11 AM |
