Hip Hop Artist
Byebye V6~
Welcome Home New Pony :P
Okay Need More Input!
What is this CMDP or CMCV Delete i keep hearing about... i have managed to learn a little bit that the cmdp helps the throttlebody out but need more knowledge on it... please explain and how hard are they to install..?
Thank's
![]() ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig http://www.myspace.com/moddedmustangz Modded Mustang's Song
#2 | |
All sissies going to Hell!
2008 BULLITT #3385
Killing with a smile
Ok the the stock cmcv's are garbage and don't do what they are supposed to. They are like a second throttle body that sucks and hurts power.
Now....if you delete them you will gain power and engine efficiency. I would recommend the steeda race plates. They deliver more power and have a better port match. Also your car will rev easier and your intake will sound more beast mode.. Install is simple but time consuming 2-3hours, 1-1.5 if you are good. There are 10 bolts that need to be removed. 2 are on the inside bank of the intake manifold. They are located between the 2-3 intake runners on each side. You will see them after you take out the fuel rails/injectors. Also you will have to disconnect the control module and take all the 3 bolts out of that. Then you have to take the 4 or 6(can't remember) torx head screws out of the plates that go into the manifold. Then take the 8 green gaskets out put them in the new ones and then slap it back together and tune it up. Then enjoy your mid range to top end power! Hope this helps.
BULLITT CREW FOUNDER (The real one) Bassani Crew Member #5...HARDCORE CREW MILITARY CREW E-5 MA2(AW) ![]() Last edited by navyman8903; August 27th, 2009 at 08:00 AM. |
2005 Mustang GT
13.50@105
At the end of each intake runner there is a plate with butterflies that regulates the airflow into the cylinder head thus claiming to increase fuel mileage and low end torque. All the the CMCV (Charge Motion Control Valve) deletes are, are OEM castings (Steeda Economy plates) without the butterflies and butterfly shafts therefore creating less restriction in the intake path resulting in around +-10HP up top in the RPM range, and with a good tune will show very little to no low end torque loss.
JLT CAI, FRPP 4.10s, FRPP Hot Rods, FRPP x-pipe, FRPP TB, CMCV, UDP, Spydershaft, JBA Shorties, Flowmasters, Hurst Billet Plus, AM/Bama 93 race, BMR STB, BMR adj. panhard bar+brace, BMR LCA's, BMR UCA+mount, BMR front+rear swaybar, BMR A-arm brace. |
Golf Pencil Kawk Juggler
Basically to break that down even more, Ford tried to improve gas mileage by putting butterfly valves below the plenum.
The CMVC's are just a plate that replaces the one holding the butterflys. Hope that helps a little more, navy summed most of it up.
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
2008 BULLITT #3385
I didn't lose any torque and I got some more topend. And if you are planning on cams and you are not getting a twinscrew supercharger, then these are a must.
#6 | |
2005 Mustang GT
13.50@105
2007 GT
Find out if they just plug it in or use a sniffer.
#8 | |
2005 Mustang GT
13.50@105
2008 BULLITT #3385
I would call a mustang shop in NY they will help you pass emissions........however possible.
has anyone ever dynoed the CMDP's on a supercharged car to see the increases of power, i prefer to see a centri dyno.
2008 BULLITT #3385
That would be hard(I'm not shitting on you) seeing as how they are usually a mod you do 1st, then the SC but there might be someone......
i know im allready supercharged but i have 3 more mods really left to do before breaking into my engine.
Longtubes CMDP Throttle body |
#13 | ||
Blank
2008 BULLITT #3385
you can dyno and see the benifits then.....You are getting the steeda race plates correct?
Made in U.S.A.
2011 F150 FX4
Only time I'd recommend getting the billet race plates is if you're going all out. Also, the economy plates are going to be stopped being sold very soon. So if you want those, I'd order them ASAP. The gains are small and you'll probably make ~6 rwhp and rwtq from them but every little thing adds up. Plus you won't end up like this guy ...
2008 BULLITT #3385
I'd get the steeda ones...They are the best and you don't have to worry about anything once they are in or regret anything.
Made in U.S.A.
2011 F150 FX4
Steeda is the only company to make CMCVs as far as I know.
2009 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
2008 BULLITT #3385
they are not the only company that makes them, just the only company you should go to.
2009 Mustang GT/CS
274hp 296tq bone stock
im pretty sure that you have an 09 Mustang so you should not listen to any of the guys telling you to get these................For the 09 Mustangs ford actually welded the CMCV's onto the intake manifold for some god unknown reason....... so unless you are getting an old intake manifold plus these or a aftermarket intake manifold you cant have them.........and dont even think about the plugs steeda sells there is major horror stories over those......
'09 GT/CS TruFiber/TruCarbon, Hillbank Motorsports, AEM, Savini Forged,Toyo Tires,Hellwig Products,Cal Pony Parts,Mishimoto,Katzkin, DynoMax Exhaust New setup coming.......... ![]()
Threads Similar to: Okay Need More Input!
| need some input. | 3kgt2nv | 5.0 Mustangs | 19 | June 28th, 2009 07:11 PM |
| need some input | dpbbnc89 | 99-04 | 32 | May 4th, 2009 08:51 PM |
| need input | Squints | The Clubhouse | 12 | December 26th, 2008 12:36 AM |
| need some input.... | 88stangGT | 5.0 Mustangs | 7 | September 6th, 2008 04:07 PM |
| A little input please | ixmotoxi | 2005 - 2010 | 1 | September 1st, 2008 01:31 PM |
