widest tire for the 2005 17" wheel?
What is the widest tire I can put on the 2005 17" wheel?
Thanks |
booooost'd
2007 Mustang
a 275 if you could find a place that would put it on.
![]() Jucostud's Official Build Thread 1988 LX HATCH 5.0 - FOR SALE $5,000 OBO 2007 vortech gt - SOLD! Looking for next project |
when i had my 90 5.0, i ran a 295/60/15 on it. it bubbled over a bit but man it was wide.
i dont know if that i will help any, probably not.
07 GT 5spd / Pypes axle-backs - K&N CAI - UPR billet stuff - 35% tints - Removed spoiler - Eleanor grill 07 Jeep Liberty Sport / Family ride "An occassional feeding of rice keeps my car happy" |
the width if the tire is not going to be your problem, you can put a 315 35 17 on ther but the issue is that its not the correct diameter for your car. it will affect your ABS, TCM, speedo, odometer and everything else that works off the proper rotational speed of the tire not to mention it will look terrible because you will have a huge wheel well gap because the tire is way too small in diameter for the car. the widest 17" tire currently made that will fit the car and also be the correct diameter is a 255 50 17. thats what we sell the most of for people wanting to upgrade to a wider tire and use the stock rims for 17".
I have seen a few guys with 17" running the NITTO 555s on there S197s and they were 275s....I asked all kinds of questions and couldnt see any reason not to go to the 275s.This Monday they go on the car at D'Agostinos race shop and I will let you guys know how it goes.
1993 5.ohhhh
12.97 @140mph
does uprgading from 235 to 255 on the stock rim have an effect on the speedo.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
2006 Vert
11.49 @ 121.45
the real issue is rim width..... your tire really should not be more than 2" wider than the rim.... so work from there.....
the diameter will affect the speedo etc...but a tuner can recal the car for that issue.... if you get a tire close to the orginal diameter your generally ok... a 255 could be close to stock diameter if your aspect ratio goes down to 5/10 percent.... but you'll need to check the numbers.....
Sold - 06 GT- 4000lb Rowing machine 11.49 @121.45 ![]() 2008 Shelby GT500 4.0 Whipple - L&M Engines - Lund Racing Tuned - E85 |
??? the tire width wont do anything to the speedo. The diameter change will. For instance.. you go from 235/55/17 to 235/65/17. Your diameter increased. This means your speedo will be off. One 360 degree revolution of the tire will move the car farther than the 55 series. Now..changing the rim size + will also increase the diameter. But if you go to 18's, or 20's and put a lower profile tire on to say a 40 or 35, you may break even. Tire width will not change the speedometer. diameter will
Tdog 2007 mustang GT 5speed, Black |
what do wider tires affect anyway? control?
___________________ American Racing Rogue 20" JLT CAI Xcal 3 -Bama "stay tuned-neptune nj" |
i have 255/40's front and 285/40's on back and now i can go around on/off ramps at about 60 mph. the wider tires will give you much more grip as long as you get a good quality tire.
Yup. The wider tire means more rubber on the road. More rubber means better control/handling. It also means more grip. Just have a look at why the WW2 tanks were dominated by the Soviets. Their tanks had a wider track. It would not get bogged down in the mud and it handled better. More surface area = good.
#12 | |
booooost'd
2007 Mustang
hey psycho Im very interested in those KOnigs beyond. Im looking for 20" wouls they look good on black gt? not sure what urs is but it look alloy!? whats the best to get 20 by what?
i got the 18x8.5 and 18x9.5
after the fact i think i should have gotten 9.5 all around and i only wish they would come in a 10 or 10.5 for the rear. as far as the look goes on a black car it is really just up to you and your preference. i do have the alloy grey on my car. the beyonds are almost a perfect match to the color of the paint. a few people actually thought i had them powdercoated to match the car. you can absolutely fit the 20's on there, but the tire will be a low profile and if you go to the drags you won't be able to hook quite as good. if you do go with the 8.5 for the front i would suggest getting a 265 width as i will do next time i buy tires. the 255 is great, but my opinion it needs just a bit more. i would also like to fit some 295's on the back |
aright thanks ill look into that man, really appreciate it...
So if I buy 2 05 factory bullitt 17x8s, and put on 285 40s, or 275 40s, theyll hold on. I want the widest tire that can get a grip on the strip. Thinking of drag radials as of now...any help is appreciated.
1998 Trans Am WS6. (Anti Venom) Forged 347, stage 3 T56, and a 76mm Turbo... 659rwhp @ 13.5# ~725rwhp @ 15.5# Meth, C16, and 20psi coming soon 03 Z71 (H/C/I/E/T)...sold 2005 GT, Full Bolt-Ons...12's... GONE |
2006 Vert
11.49 @ 121.45
w/ 8 in rims i think the 285s are much too wide... recommend rim size for that size tire is 10" from what i saw @ a couple of tire company sites... w/ an 8" rim my reseach told me not to go wider than 255's, which is what I'm going to swap my stock 18" 235's for.....
as mentioned above,...width alone does not effect the speedo.. it's the diameter... if you change the width and not the aspect ration then you will have issues with a different diameter...
booooost'd
2007 Mustang
you should be able to get 275's on there, but i don't think the 285's will fit. I've never installed a tire that wide on a 17x8 rim.
2006 Vert
11.49 @ 121.45
I think the 275's are also too wide... the tire will bulge....
http://www.nittotire.com/index.html#...Ent555%2Esizes check out Nitto's site... give you approved rim sizes for different tire sizes
booooost'd
2007 Mustang
It will bulge a little, but it will easily fit. I've put a few 275 tires on an 8in rim.
Threads Similar to: widest tire for the 2005 17" wheel?
| How do i spin my "Tire"? | MustanG_guy17 | V6 Mustangs | 9 | September 3rd, 2007 07:06 PM |
| Any 2005+ 'Vert owners with a "light bar"? | TCSoff | 2005 - 2010 | 4 | July 11th, 2007 09:28 AM |
| 2005 wheel Camber kits | ozan169 | 2005 - 2010 | 1 | January 17th, 2007 12:06 AM |
| what's the widest size tire you can mount on a 17x8 rim? | 95oldyeller | 5.0 Mustangs | 1 | December 10th, 2006 08:59 AM |
| Widest Rear Tire 02 GT With Sportline Springs | Quarterhorse | 99-04 | 4 | October 3rd, 2006 05:39 AM |
