10.0@136 mph 1/4
powerglide transmission
Powerglide transmission is in...it's a complicated process since the bellhousing is C4, so there has to be an adapter plate to connect to the main body. The scattershield surrounds the center. A template is being made so that a custom bracket can be fabricated to connect transmission bracket to vehicle mountings.
An estimate is that the powerglide is maybe 75-100 lbs lighter than the 4r. ![]() ![]()
2006 mustang GT, 10.0 at 136 mph, 1/4 with old build. New build in progress for low 9s. (sold) srt10 coupe (stock) for street, 505 ci, previousy viper gts, before that C5Z06. |
A well built Powerglide will take some serious abuse, just keep it cool. Looks nice. I don't think I know of anybody that's put one in a new stang. My buddy Don Burton runs low 7's with a Powerglide.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald |
10.0@136 mph 1/4
The 4r70w that we had in the car before was terrific, never missed a beat. We had it reinforced, strong enough to pull both front wheels with transbrake usage.
Now that car has been pulled from the street, allows us to take a build path less traveled. The powerglide is a lot simpler, lighter, only 2 forward gears, and easily upgradeable....but not something anyone would likely consider for even a lightly used street vehicle.
Honeybadger is Crazy
Glides are great, I almost ended up putting one in my 99 Z28 and yeah you just don't street a car with a glide in it. Would that be Total Performance out of Michigan?
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
You need big (BIG) power to get the full benefit from the glide
I had an stroked LS6, with a stage NX kit. The car had the power to turn the glide.
#7 | |
10.0@136 mph 1/4
pic of motor back in and interior that's not quite there yet...lol...but does show extent to which this car is being transformed & redesigned, at different levels. Car is going through major rewiring (harnesses from nose of car being moved into passenger compartment and other stuff). ![]()
2006 mustang GT, 10.0 at 136 mph, 1/4 with old build. New build in progress for low 9s. (sold) srt10 coupe (stock) for street, 505 ci, previousy viper gts, before that C5Z06. Last edited by forensicsteve; September 13th, 2009 at 04:42 PM. |
Blank
The car looks really nice Steve. Do you have the RGR 322CI stroker shortblock in mind for your 2010-2011 build?
What gears will you run?
#10 | |||
10.0@136 mph 1/4
Total Performance Solutions -- Dyno Tuning and Performance Shop between Baton Rouge and New Orleans, Louisiana
Made in U.S.A.
2011 F150 FX4
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
Nice to see something different! Good job Steve.
2005 Mustang GT
12.0 @ 117+
Is it gonna be ready for NMRA Houston??
#13 | |
Blank
Sweet, I can't wait to see what you run with all those cubes.
![]() Steve will have another post in a while after we dyno the car with a "dead" converter (very low stall converter to feel out our powerband). We can play with the tire size and gearing as well as the stall to get us in the meat of the powerband. Still a couple unknowns at this point until we have the car on the dyno and ultimately the track but 3.50:1 gears with the current tires should we choose to continue with them will get us roughly where we want to be at the RPM we want to be at. The beauty of a 9" rearend is very easy gear changes with the removable chunk. Wes |
Sick!!
![]() Under Construction |
Threads Similar to: powerglide transmission
| powerglide gear ratio | notchabovechevy | Modular Mustangs | 0 | July 21st, 2009 03:38 AM |
| Powerglide | skuzzy | Modular Mustangs | 3 | June 13th, 2009 11:17 PM |
| powerglide? | browny | 5.0 Mustangs | 1 | February 23rd, 2009 11:27 AM |
| 99 gt transmission | ArmyChargedGT | 99-04 | 14 | March 14th, 2008 07:10 PM |
| need bellhousing for powerglide to put in my 91 stang | sixpack | 5.0 Mustangs | 2 | August 20th, 2007 07:58 PM |
