E force or Saleen?? - Page 8
Old November 2nd, 2009, 10:27 PM   #141
shanec's Avatar
shanec will become famous soon enoughshanec will become famous soon enough
This is the best apples-to-apples comparison I've seen of an E-Force against another blower. Same tuner, same amount of aggression in the tune, same dyno, same model mustang GT, both are Autos. Both are otherwise stock.
E-force:
The boost there is as indicated up to about 5300 or so, then it ramps up to the higher of the two numbers mentioned below.
Whipple HO - which is actually 11psi across the board, not 10 as they claim.
Now.....compare numbers in the lower and mid bands.
Old November 2nd, 2009, 10:29 PM   #142
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
NastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant futureNastyFX4 has a brilliant future
iTrader: 9 reviews
FYI: 20 degrees isn't that conservative. I'm not even running that much timing on my set-up at any given RPM.
Old November 2nd, 2009, 11:02 PM   #143
onederful100's Avatar
2007 GT 2000 GT
onederful100 has a spectacular aura aboutonederful100 has a spectacular aura aboutonederful100 has a spectacular aura about
thats rather peculiar.
my 8 psi whipple has 410+ torque at 3k rpms. and its a gen 1.
http://i243.photobucket.com/albums/ff26/onederful100/avatars/sig-52.gif
2007 GT 5spd
2000 GT 5spd
whipple crew member
2-Stang Crew
My Car
Old November 2nd, 2009, 11:27 PM   #144
shanec's Avatar
Mine is 20 deg peak at some high rpm, I forget. It ramps to 20 at some point, I forget where.
Old November 2nd, 2009, 11:34 PM   #145
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
iTrader: 9 reviews
It ramps up? It should be ramped but it should decrease in the upper RPMs to reduce load and stress on the stock block.
Old November 3rd, 2009, 01:25 AM   #146
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
a 66-76mm turbo with a ~.80-.96 o/c ar will get you where you want to be... basically a medium sized t4....... easy enough.. and will spool fast enough to catch the twin or roots when its gettin in the meat... past that, we all know what happens to a turbo car givin a lot of rpms... it pulls hard.
turbos are cheap.. you blow one up its like a $900 fix.. my tc78 and pt88 can both be had for $1000 each. I loved my pt88 and 408 when it was running
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old November 3rd, 2009, 02:18 AM   #147
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
shanec, dude...the excuses are never ending, no offense brother.
earlier in the debate, didnt someone mention more torque for the e-force? dont see that happening as indicated by your chart at the top of this page...not even close...i have cams and a ported blower which should give me waay more horses than torque, yet my numbers are similar to the eforce with stock cams up there ^
first, you never post a dyno sheet with boost or a/f, so we're comparing apples to donkey dicks for all we know.
second, you are comparing two different cars up there with the same aggression in the tune? care to explicate on that? and you go out of your way to call out whipple for claiming 10psi instead of 11psi when the e-force claims 7 and spikes to 10? give me a fuckin break man. this is getting old
edit: lmfao, dude the whipple chart is SPIKING at 10.4psi and you are rounding to 11psi?!! wow, i am at a loss for words
have at it, eforce ftmfw!!
second edit: that eforce is making 475rwhp @ 11.5psi!!! holy shit batman, a new record! ok, ive said enough now
Under Construction
Old November 3rd, 2009, 02:26 AM   #148
Mickey's Avatar
Im just waiting for people to hop off edelbrock's dick and realize that the company is what is proven, not their blower
the saleen blower IS PROVEN and has been for the last four years
Under Construction
Old November 3rd, 2009, 10:08 AM   #149
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
iTrader: 9 reviews
Mickey I agree with most of your post but seriously get off this shit. The TVS spikes boost. It's a part of the blower. Nothing any of us can do to change it. Measuring peak boost would be idiotic. We see that peak boost for maybe 2 seconds? That's fair, I bet we're gaining a lot from those two seconds. Irregardless if you're so against these spikes and only want to talk peak numbers, let's not be a hypocrite, your Saleen made 488 at 6.9 lbs not 6.5 lbs. I mean fuck if you wanted to round than wouldn't you of rounded to 7 lbs? It might be a good idea to change the signature now.
Old November 3rd, 2009, 11:39 AM   #150
Mickey's Avatar
Mike, the spikes are the least of my points in that post dude...and as far as rounding...really? .4psi? you are "rounding" like 2psi brother, whatever, im done with that and I could care less. My other points are valid and I still want explanations for that.
He called out hte whipple for 11psi? it spiked at 10.4...where the fuck do you get 11 from that? Again, whatever man. eforce ftmfw
and my signature IS VALID. I AM MAKING 488rwhp @ 6.5psi...look at my chart sweetheart
Under Construction
Old November 3rd, 2009, 11:44 AM   #151
Mickey's Avatar
and the reason i cant figure out what he is making is because he never fucking posts any boost with his charts
Under Construction
Old November 3rd, 2009, 12:26 PM   #152
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
y does it say 17 psi then?
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth
Old November 3rd, 2009, 03:44 PM   #153
Mickey's Avatar
im rounding up
Under Construction
Old November 3rd, 2009, 04:50 PM   #154
05bluestang's Avatar
2005 Mustang GT
05bluestang will become famous soon enough
The Edelbrock is a piece of shit, trust me I know. It would not produce power on my car. At least with the Techco I am making decent power, yea they may have closed the doors but they sure made a hell of a product and their tuners where first class. Now looking at the Techco blower and SMS blower, they do look a lot alike and I'm sure I can get parts for it down the road. Everybody is trashing Techco, shit happens in the real word and if you don't have an investor backing you any new company would have went titts up, doesn't mean you made a shitty product......................
05 Sonic Blue GT, with a shitload of mods... Oh yea and a blower... bring it..................
Founder "Dead Battery Club"
Old November 3rd, 2009, 05:11 PM   #155
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
iTrader: 9 reviews
Didn't Chris install spark plugs that were broken, twice, in your car and that's why it wouldn't produce power?
Old November 3rd, 2009, 05:17 PM   #156
2005 Mustang GT
According to him they chaged the plugs (twice) and the coils (where) are brand new too. Dunno, but my car did not like that thing, kinda like a spoiled little rich bitch having to go to McDonalds I guess......................
Old November 3rd, 2009, 06:50 PM   #157
More Is Better.
DiMora's Avatar
2006 Roush Stage 1 Blown
DiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to beholdDiMora is a splendid one to behold
Send a message via ICQ to DiMora
Those damn HT0's.
Sorry, couldn't resist, Nasty.
OP: I think the Edelbrock has proven itself in enough cars now that we know it is a good product. So is the Saleen. So is the Roush TVS. So are KB and Whipple.
Pick what you like - or get a good deal on. That is what I did. I researched them all and was going to go KB Mammoth, but I got a smoking hot deal on my TVS and I honestly couldn't be happier. As a daily driven street car, I have more power than I can put to the ground with my Michelin Pilot Sport PS2's. You also want to factor in local tuners and what unit they are most experienced with.
Mickey has proven that Saleen is an awesome blower, especially when modded like he has done, and those units make a sweet sound.
The TVS units are much more quiet.
Roush Short shifter / Carmen's 3.47" TVS pulley
Roush TVS Supercharger
Steeda suspension /Big Brakes
Mac L/T's / Prochamber / Roush Extremes KB BAP
"Daily Driver" RWHP: 492@9 PSI w/ LT's
"Dyno Queen": 512@12 PSI-stock exhaust
Mods in Garage
Old November 3rd, 2009, 07:07 PM   #158
Mickey's Avatar
The TVS is quiet? I thought they had a decent whine to them? Dimora makes a great point. Honestly, your choice should come down to what kind of deal you can get. The Whipple, KB, TVS, and Saleen are all great. Just shop around and see what sticks out
Under Construction
Old November 3rd, 2009, 07:25 PM   #159
2006greyGT's Avatar
2006 Satin Silver GT
11.08@125.22
2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about2006greyGT has a spectacular aura about
Send a message via Yahoo to 2006greyGT
if you find a good deal on a KB Mammoth I'll buy it and sell you my 2.6l at a good price...
[IMG]
2.6l KENNE BELL 298 Stroker, Ported heads
Pro Motion Built 3650/McLeod RST/ MGW Short Throw
Long tube/O/R X /Borla Touring
8 rib/65 lb injectors/GT500 twin fuel
ET Drag Slicks/3.73 gear
Detroit Truetrac /CDC AGR Spoiler
Old November 3rd, 2009, 08:43 PM   #160
shanec's Avatar
And the car they ended up installing your blower on ran 11.6's in the 1/4.
yeah, no power at all.
I know you experience sucked. I don't envy that at all. I went through a lot of shit myself when I installed mine. Nothing like you faced. I feel for ya on that.
But E-Force's do make power. Plenty of it.
Threads Similar to: E force or Saleen??
V force mufflers icon 2005 - 2010 V6 3 May 11th, 2009 12:27 PM
edelbrock e-force ? angryoriental 2005 - 2010 1 May 3rd, 2009 06:35 AM
john force blackhavok 2005 - 2010 4 March 30th, 2008 02:21 AM
Force Mufflers blackstang2004 General Tech 2 February 29th, 2008 12:48 AM
G-force T5 is here itschristorres8 V6 Mustangs 19 February 8th, 2008 11:18 PM
