#21 |
2009 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
and why does the stock intake not flow enough at those high rpm's? serious question.
my rules: 1) at least pretend like you know thrasher and I are together 2) try to arrange a personal meeting with thrasher, and it will only be a matter of time before you meet 101fng |
#22 |
Mainly it just can't flow that well do to restrictions because of it's smaller port design. I mean, aftermarket intakes open them up, include longer runners for better flow and torque. They are also tested and retested to maximize flow.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, BBR Stage II cams, Manley, MGW, McLeod RST, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald |
#23 |
2009 Mustang GT
i guess if you're going all out and have already put more money into the engine and drivetrain than the total cost of the car, then an aftermarket intake isn't such an assrape. but honestly, for 90% of us, an aftermarket intake is not worth it. the stock intake isn't nearly the greatest restriction in the engine. it's actually probably the least restrictive part. so after heads, cams, exhaust (no particular order), then maybe i can see an aftermarket intake as the next logical step.
#24 |
I agree.
#25 |
2008 Mustang GT
Basically everything that comes stock on the 3v 4.6 makes for a pretty balanced system, except in terms of the CAI+tune, there isn't anything else under a grand that gives really big all on it's own.
To see total end game gains, the entire system needs to be opened up to match. Judging by results, it's worthless to open up early flow (TB, intake) if the heads don't accomodate that increase in flow. Otherwise it's a bunch of little mods to make a big system. 5 here, 5 there, 5-10 in 5-10 different spots makes solid gains. But I think this is why Ford is scrapping the 4.6 and 5.4 designs: all the headroom has already been bought.
Experience is what you get when you didn't get what you wanted.
#26 | ||
2007 GT
I am. I beleive what I said is that the internet blows them off. I learned this personally.
Do you have a link to this car for me to illustrate something real fast?I have. There are a lot of variables not considered. Last edited by 07stanggt; October 29th, 2009 at 11:15 PM. |
#27 |
![]() Under Construction |
#28 |
2007 GT
#29 |
2007 GT
Question for some n/a guys genuinely interested in this. Did any of you notice anything odd about that dyno that he mf123 linked?
#30 |
2007 Mustang GT
13.7 @ 105
Following this thread closely...
black 07 GT, jlt2 cai, sct2 brenspeed 93 octane tune, UDP's, spydershaft, triax, magnaflow catted x, steeda axleback, bad ass steeda suspensionStealth GT Twin Turbo System On The Way!!!!!!! STEEDA SUSPENSION CREW FOUNDER |
#31 |
2007 Mustang GT
13.7 @ 105
the only thing that struck me as wierd is that the power seemed to taper off after 6k rpm, but maybe thats normal...I'm a retard
#32 | |
Blank
One would think so because that car has very aggressive cams, high flow cylinder heads, and more cubic inches, so obviously it is going to be drawing in more air, which puts a larger demand on parts that aren't upgraded. If you mean the upgrades, then here: Livernois Motorsports 323ci Big Bore Stroker Longblock Livernois Motorsports Stage 3 CNC Heads Livernois Motorsports Custom Camshafts Livernois Motorsports Cam Phaser Limiters Livernois Motorsports Crankshaft Scraper Livernois "Reload" CNC Valve Covers C&L Intake Manifold Innovators West Damper Kooks Longtube Headers and X-Pipe w/ Cats Whipple Single Blade Throttle Body Ram Clutch Dynotech 1-Piece Driveshaft Ford Racing Handling Package I am positive that it still had the stock bullitt CAI. Oh and here's the link to the thread over on s197forum: C&L Arrived for N/A Big Bore Stroker.. Pics! - WWW.S197FORUM.COM Last edited by unlicensed to drive; October 30th, 2009 at 12:26 AM. |
#33 | |
2007 GT
I agree. the power curve stayed exactly the same for the different runner lengths. The short runner made more power everywhere and droped off at the same point? I saw it pull to 6800 on a car. There is another MM&FF article coming out on this. Last edited by 07stanggt; October 30th, 2009 at 12:30 AM. |
#34 |
2007 GT
Thanks mf. I was really looking more for the car. What trans is in the car they dynoed this on? Auto or manual? what size rims/tires, gears, etc. Those are the things i was wondering.
#35 |
Blank
No problem. It is a 2009 Bullitt, which indicates that it's a manual. I would assume that it still has the OEM TR3650 transmission in it. I have no idea what gearing or wheels/tires it had on it though because Rick@Livernois never mentioned it in the thread, but I might be able to find out by PMing him.
I just noticed something about the dynograph which disappoints me. They used STD correction. I wish that car made those numbers SAE.
#36 | |
2007 GT
You are to worried about correction factors. Menace nailed it. Its flatlining at 6k like menace said. At 6k my car only maks 370. You wanna know. Maybe the reason why a stock bottom end n/a car made 409 when a stroker only makes 420 is becuase one is peaking at 6000 and the other is peaking at 6800. |
#37 | |
Blank
That makes a lot of sense. I wonder what the stroker would make if it pulled to 6800. |
#38 |
2007 GT
Here is another thing that no one seems to ask. What is the grind on this cam? Just becuase its custom doesnt mean is the most aggressive cam on the planet. What were they going for with it. What rpm will that cam pull to, what rpm does the cam come on. Just a thought.
To disect those livernois numbers we need do a little more then assume its the perfect engine for the question at hand. If the c&L made all that power before and up to 6k its really not that bad considering what we really want I really want to know is what it makes to 7k. And it doesnt mean that it will do worse on a 281. Last edited by 07stanggt; October 30th, 2009 at 12:56 AM. |
#39 |
2007 GT
#40 | |
Blank
Yeah they never posted the specs of the cams used, so I just assumed that they used a cam which would allow that car to make power pretty high up in the rpm's, but I'm dumb for that. You could not be more correct about what we want to know. I hope that someone can give us that information, but the only way to find out is to contact Livernois. |
Threads Similar to: C&L Intake Manifold
| P&P Upper Intake Manifold | 9986paulk | V6 Mustangs | 8 | June 6th, 2009 10:03 PM |
| C&L intake manifold a bust??? | leebunnyz | 2005 - 2010 | 80 | May 4th, 2009 09:26 PM |
| C&L Intake Manifold? | unlicensed to drive | 2005 - 2010 | 22 | February 22nd, 2009 11:35 PM |
| C&L Intake Manifold!!! | 06GTMustang89 | 2005 - 2010 | 21 | August 27th, 2008 10:20 AM |
| C&L to release it's intake manifold very soon!!! | RStrick0352 | 2005 - 2010 | 9 | July 15th, 2008 08:15 PM |
