'10 capless gas fill on 05-09?
Old October 29th, 2009, 10:18 PM   #1
97gtstang is on a distinguished road
I found a capless fill on a wrecked '10, but wanted to know if anyone knew if it worked the previous years or any problems with them.
Also i know they had sequential tails, is that stock on all? if so does anyone know what the relay looks like? Is it in the trunk or under hood.
07 Roush Fastback Package
93 2.3 LX project car!
They all think it has a 5.0 ... n00bs
Old October 29th, 2009, 10:59 PM   #2
Catfiesh's Avatar
2003 Cobra
Catfiesh is a jewel in the roughCatfiesh is a jewel in the roughCatfiesh is a jewel in the roughCatfiesh is a jewel in the rough
2010 is the first year for capless on the Mustang. All `10s come with sequentals. I have seen `09 Escapes and Explorers with the capless set up.. as most would immagine.. the first few had leaking issues causing evap codes. Since `10 is all new I would not reccomend running the capless set up, likely to have evap leaks.
MM Cobra Club #48
Mineral Gray Club Member #12
Im what you would call a "bad influence".
Old October 29th, 2009, 11:05 PM   #3
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
^ i dont think all '10s come with sequentials... i saw a couple v6's without em..
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old October 29th, 2009, 11:08 PM   #4
2010 Mustang GT
Robdawg80 is on a distinguished road
hmmm i thought they all did come with them...
Old October 29th, 2009, 11:19 PM   #5
1rnkpny's Avatar
2007 G9 Eye Catcher
1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about1rnkpny has a spectacular aura about
It would have an EVAP leak. With no gas cap, it would most likely spit out a "P0455 Evap gross leak detected" code. Even the locking gas caps (one with a key) will set a "P0441 or P0442 EVAP small leak detected" code.
Old October 29th, 2009, 11:20 PM   #6
Yea thats what I was worried about... How do they keep water from getting in and gas from getting out?
It was a sixer i believe, and was missing one tail light , but there was something bolted in the trunk that the wiring went to. I dont think I want to put the sequentials on but someone else might so I could tell someone where it was.
Old October 29th, 2009, 11:25 PM   #7
Catfiesh's Avatar
2003 Cobra
The new system is designed without a cap, it uses a trap door held by spring tention that acts as the cap. This is not the same setup on your stang
MM Cobra Club #48
Old October 29th, 2009, 11:33 PM   #8
1rnkpny's Avatar
2007 G9 Eye Catcher
I realize that, but he was mentioning about doing it on an 05-09. Not a 10'.
Old October 29th, 2009, 11:38 PM   #9
Catfiesh's Avatar
2003 Cobra
correct, however your statement sugested that the capless sys would cause evap leaks because it doesnt have a cap. It works the same regardless of vehicle. If the `05 had been equipped, the capless would work the same as a regular cap set up. Just clarification..
MM Cobra Club #48
Old October 29th, 2009, 11:41 PM   #10
1rnkpny's Avatar
2007 G9 Eye Catcher
I've been a tech for 16 yrs. I get the system.
Old October 29th, 2009, 11:42 PM   #11
Catfiesh's Avatar
2003 Cobra
Haha ok man.. not tryin to get you riled up.. just wanted clarification
MM Cobra Club #48
Old October 29th, 2009, 11:44 PM   #12
1rnkpny's Avatar
2007 G9 Eye Catcher
That's kew, Cat. I see where you're coming from.
Old October 29th, 2009, 11:46 PM   #13
Catfiesh's Avatar
2003 Cobra
I like you sir.. no homo.. most people cant take things like that too well.. get all defencive. I am a Ford tech a well..
MM Cobra Club #48
Old October 29th, 2009, 11:52 PM   #14
1rnkpny's Avatar
2007 G9 Eye Catcher
Cool, what dealer?
Old October 29th, 2009, 11:54 PM   #15
Catfiesh's Avatar
2003 Cobra
Bankston, wayyy down in Texas
MM Cobra Club #48
Old October 30th, 2009, 04:23 AM   #16
booooost'd
Jucostud's Avatar
2007 Mustang
Jucostud is a name known to allJucostud is a name known to allJucostud is a name known to allJucostud is a name known to allJucostud is a name known to allJucostud is a name known to all
Yep, these are the cats always working on my car.
Jucostud's Official Build Thread
1988 LX HATCH 5.0 - FOR SALE $5,000 OBO
2007 vortech gt - SOLD!
Looking for next project
Old October 30th, 2009, 12:42 PM   #17
Catfiesh's Avatar
2003 Cobra
^^that is very true.. haha
MM Cobra Club #48
Old October 30th, 2009, 03:27 PM   #18
2005 Mustang GT
13.4@103
Avengence will become famous soon enough
My brother in law has a 2010 gt. I think he prefers the standard cap over the capless. Just seems weird to me to have no cap. Is there any way to lock it or do they all come with anti siphon screens now anyway?
2005 Mustang GT 5spd
Steeda CAI, Bamachips Tune, FRPP 4.10 Gears, Pypes Violators, Eibach Sport Springs, DD Bullitts w/ Goodyear Eagle F1 Supercar tires (285s), Cervini's Billet Grille
Best 1/4: 13.4 @ 103
Old October 30th, 2009, 08:31 PM   #19
1rnkpny's Avatar
2007 G9 Eye Catcher
There is normally a check valve inside the tank where the filler neck meets the gas tank. Otherwise known as a rollover valve. That valve rides in a small cage which is hard to get a normal sized hose into. The valve is there in case your vehicle flips over, so the fuel doesn't spew out.
If you guys are workin on Juco's ride, then you must be pretty good.
Threads Similar to: '10 capless gas fill on 05-09?
Gas Leaking right after Fill up oannamarie 96-98 17 October 9th, 2009 12:28 PM
05+ gas tank fill "fix" ???? stage2ROUSH 2005 - 2010 3 March 31st, 2009 10:57 AM
Sex For A Fill-Up oldernewbie The Clubhouse 14 December 3rd, 2008 10:50 PM
HOW TO FILL UP TORQUE CONVERTER? oasr87 V6 Mustangs 3 July 10th, 2007 04:58 PM
Fill The Gas Tank theodoor24 Classic Mustangs 10 February 25th, 2007 11:25 PM
