Stroked kit on Ebay
Old November 4th, 2009, 12:56 AM   #1
ethrjock's Avatar
2006
11.62@121
ethrjock is on a distinguished road
Stroked kit on Ebay
What sort of "deal" is this compared to what it might cost retail? Are they good parts?
Ford 4.6 Mustang 302 Supercharger Engine Upgrade Kit B:eBay Motors (item 360202379952 end time Nov-04-09 08:04:47 PST)
Also..from what I have researched on the web a spec stage 3+ clutch is around $400-500 for the s197s and here is a new one for $270.
Saleen 05- Mustang SPEC Stage 3 + Clutch Kit SF463F HT:eBay Motors (item 380173555200 end time Dec-01-09 06:00:38 PST)
06 Paxton HO, 60lb Inj, GT500 pump, 3.16 pulley, BMR LCA Panard Drop Bkt, FRPP spgs, Basssani exhaust, Off X, SLP LLck, 4.10 gear, Weld RT 15x10 rear, 4" ft-MT 28.1 x 12" rear (PB 11.62:1.51 60 ft on 11-21-09 at SDR)
Paxton/Vortech Crew Member #4
Old November 4th, 2009, 12:57 AM   #2
ethrjock's Avatar
2006
11.62@121
From looking at the vendor...they bought out Saleen's old parts.
Old November 4th, 2009, 02:58 AM   #3
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
next year
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
i think most strokers run about 2k
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete
Old November 4th, 2009, 03:00 AM   #4
2007 Mustang GT
07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold07 Boss is a splendid one to behold
The one major issue that I would consider is if those pistons are going to fit your engine. You don't know until you tear your engine apart if you can get away with just a good honing or if you are going to have to do a little boring of the cylinders. With that said, if you bore it 20 over then you will not have the right size pistons. Now if you are going to buy a brand new block then you won't have to worry about that. AND if you are going with a new block you should just get a short block with the bottom end all put together for you.
Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit
Old November 4th, 2009, 09:03 AM   #5
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
I believe thats the same kit that another memeber on here bought. Looks like a good deal to me, and hopefully your block is still good.
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old November 4th, 2009, 05:29 PM   #6
05roush0090's Avatar
2005 Mustang GT Roush
05roush0090 will become famous soon enough
With a 302 kit you will definately have to bore the piston walls. The most you can go with simple honing would be a 298 kit I believe.
Paxton/Vortech crew member # 2
Vortech V3 si, A/A cooler, 3.48" pulley, 39lbers, KB BAP,
Billet delete plates, Stage 2 thumprs,
phaser limiters, Mac Lts, Offroad x,
Roush short throw, Brisk plugs, Brenspeed 93 tune,
relocated IAT.
Old November 4th, 2009, 11:52 PM   #7
usafimj's Avatar
2007 Ford Mustang GT
12.847 @ 114.12mph
usafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of lightusafimj is a glorious beacon of light
Send a message via Yahoo to usafimj
I bought one of those kits about 1.5 months ago. Its a great product. I ended up selling it due to military orders. Wish I could have kept it. Only issue you'll have is bore diameter. Stock is 3.552. Hopefully your block is still fairly new and you can still use your stock block
07 GT-- Gone But Not Forgotten
Military Crew
E-5
Old November 5th, 2009, 12:27 AM   #8
ethrjock's Avatar
2006
11.62@121
block has 22k miles on it but you never know until you get into the guts of her. I'd hate to spend the cash only to find out my cylinder walls need bored.
Hmmm...
Old November 5th, 2009, 10:18 AM   #9
More Is Better.
DiMora's Avatar
2006 Roush Stage 1 Blown
DiMora is a name known to allDiMora is a name known to allDiMora is a name known to allDiMora is a name known to allDiMora is a name known to allDiMora is a name known to all
Send a message via ICQ to DiMora
3.551" is the diameter on those pistons., and they are designed for a bore diameter on your block of 3.554" per the spec sheet on Ebay.
Stock cylinder bore is 3.550 inches (90.2 MM), and stock piston diameters vary based on the "grade" used...and it looks like Ford uses 3 different "grade pistons" but the diameters are the following (all uncoated):
Grade 1 3.5504-3.5499 in
Grade 2 3.551-3.5503 in
Grade 3 3.5515-3.551 in
So, it looks like they allow for a cylinder "cleanup" of .003" to .004".
I am NOT a machinist, but I know that normally when you bore an engine, it is one of the three over-bores:
.010
.020
.030
What I am saying is it looks like those pitons are designed for "stock blocks" with no over-boring. They gain the 302 inch displacement through the piston design and the rods, and maybe the crank...in other words, the "stroke", but not the cylinder bore.
Hope that helps.
Roush Short shifter / Carmen's 3.47" TVS pulley
Roush TVS Supercharger
Steeda suspension /Big Brakes
Mac L/T's / Prochamber / Roush Extremes KB BAP
"Daily Driver" RWHP: 492@9 PSI w/ LT's
"Dyno Queen": 512@12 PSI-stock exhaust
Mods in Garage
Old November 5th, 2009, 02:27 PM   #10
IBEATU
Good info Shane!!
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
Old November 16th, 2009, 10:33 PM   #11
ethrjock's Avatar
2006
11.62@121
Thanks diMora. That's what I was looking for. It sounds like a risky purchase. I might be better suited with a kit that's designed for overboring .030.
Old November 16th, 2009, 10:56 PM   #12
Torch Red 2005 GT
Casey4s is on a distinguished road
Ask the vendor if you need to bore the block out. I agree with DiMora I can't see why you would need to bore the block. The3.554 bore by 3.80 storke is 301.5681~ Cu In
Old November 17th, 2009, 05:36 PM   #13
.010
.020
.030
Hope that helps.
hmmm,,.....interesting. I actually am liking the sound of this kit. How does the piston make up for not boring? Dish type to create more room? Please explain.
relocated IAT.
Old November 17th, 2009, 05:56 PM   #14
Torch Red 2005 GT
The pistons are .004 oversize so you shouldn't need to do anything but a honning for the pistons to fit the block. The pistons are dished to lower compression for a blower application.
Old November 17th, 2009, 06:51 PM   #15
jonnieguns's Avatar
2009 Mustang GT
13.5@105.88
jonnieguns is on a distinguished road
I was about to buy it, lol. Sale ended on the 4th.
Old November 18th, 2009, 01:15 PM   #16
HBK_2007's Avatar
next year
ive seen those alot be4, just keep ur eyes open and ull find another
Old November 18th, 2009, 04:38 PM   #17
jonnieguns's Avatar
2009 Mustang GT
13.5@105.88
There's a similar high compression kit advertised as well. Would it be inadvisable to install that kit, and then swap in pistons with more of a dish (for lower compression) when it comes time to go forced induction? Would there be any problems with the new pistons not being set/matched to each cylinder?
Old November 18th, 2009, 04:55 PM   #18
More Is Better.
DiMora's Avatar
That would be a waste of time...you would have to pull the whole engine again to do that.
The pistons, connecting rods, wrist pins, and crank are all balanced together as a "rotating assembly".
The pistons, wrist pins, and connecting rods are "balanced" by removing material until they all match one another within the desired tolerance. Therefore, each piston / rod / wrist pin is a "matched set".
The crank is then fitted with "bob weights" that are equal to the weight of the 8 piston/wrist pin/connecting rod combos...and then the crank is balanced.
By disassembling and changing pistons, you throw this off - unless you weight match the NEW pistons so that they are equal in their relationship in the same ratio that the original pistons were.
The bottom line is that it is easiest to pick what you want and do it right (and once) the first time.
If you are going to go forced induction (and I don't know why you would not on these cars with their small displacement engine) then just get the correct low comp pistons from the get-go and call it good.
Mods in Garage
Old November 18th, 2009, 05:00 PM   #19
jonnieguns's Avatar
2009 Mustang GT
13.5@105.88
Makes sense, thanks for the insight.
Old November 18th, 2009, 05:51 PM   #20
Made in U.S.A.
NastyFX4's Avatar
2011 F150 FX4
NastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud ofNastyFX4 has much to be proud of
iTrader: 8 reviews
Just something to add to the conversation... If you're going to be running a 'normal' amount of boost like 8-13 lbs than there is ZERO issue with running a stock or slightly higher compression ratio. I believe our stock motors are 9.8:1. If you're planning on running a lot of boost than it's probably not a bad idea to get the lower compression pistons.
NastyStang's Garage Sale!!
Threads Similar to: Stroked kit on Ebay
Opinion on ebay turbo kit? cobra99svt 4V / SVT 3 March 23rd, 2009 12:25 PM
Turbo kit on Ebay? The Novice 5.0 Mustangs 11 May 28th, 2008 04:55 AM
Ebay Turbo Kit? The Novice 5.0 Mustangs 10 March 21st, 2008 03:43 AM
Anyone here ever use a HID kit like this one on ebay? black88 5.0 Mustangs 11 February 5th, 2008 07:11 PM
Cheap boost on EBAY. S/C kit. ItalianBullitt754 99-04 11 August 26th, 2007 11:15 PM
