Vibrations at 75+ - Page 2
Old November 17th, 2009, 12:24 AM   #21
Doctor of Jurisprudence
Nameless's Avatar
2005 Mustang GT
Nameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to beholdNameless is a splendid one to behold
Originally Posted by 2006GTARPD3 View Post
have a buddy hang on the bottom of the car while you do 75. Chain him up or something. Then have him look all over and listen for the problem.
chain won't work...all that metal clanking together might mask the real noise...perhaps some sort of nylon harness?
Me -----><----- You
Nameless's s197 Write-Ups
he kept taking pics of me saying "OMG look at that!!!"
Old November 17th, 2009, 12:32 PM   #22
MM's resident Juice head
07 STROKER's Avatar
07 Mustang GT
07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold07 STROKER is a splendid one to behold
I would run by your dealer and ask your service manager what the tolerances are.
Typically there should be no up and down movement when you attempt to move the driveshaft in up or down near the hanger. Sometimes though the play can seem fine, but the bearing itself can still be shot.
Also note I'm not saying that this is definitely your problem. It's just an educated guess, and one of the things to eliminate as you look for the problem.
Another consideration is that even though they told you that everything is fine with the work they did..... that it's really not.
So if you start eliminating things like a bad hanger bearing, bad u-joint(s), bad axle bearing, etc... and are finding nothing wrong with anything anywhere... chances are they fucked up something in the dif, and just are either missing the problem because they're dumber than a box of rocks, or they know and are trying to avoid warranty costs.
not trying to disagree...but i disagree bud.
If you go under the car and put one hand one the front shaft and one on the back shaft and bench press...you will get alot of movement in the hanger...also some slop noise...i know ...i did it, and i was told it was normal.
The MGW short throw shifter
Its not just a shifter...It's a lifestyle!
Old November 17th, 2009, 04:55 PM   #23
TheUNZippee!'s Avatar
Indeed. That's why I said 'typically', and why he should find out from the dealer what the proper tolerances are for these cars.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old November 17th, 2009, 05:03 PM   #24
07 STROKER's Avatar
07 Mustang GT
gearjammer
Old November 19th, 2009, 01:38 AM   #25
Threads Similar to: Vibrations at 75+
vibrations ia07gt 2005 - 2010 13 August 21st, 2009 12:02 AM
Vibrations JKennedy V6 Mustangs 10 February 12th, 2009 09:41 AM
vibrations jat 2005 - 2010 13 November 5th, 2008 09:47 PM
vibrations zinc02GT The Clubhouse 9 July 8th, 2008 06:28 PM
vibrations MikeD05GT 96-98 5 May 1st, 2008 11:09 AM
