HID Issue
So i have had the xenon digital ballast with 10k hid bulbs in my projector headlights for a couple months now and the hid's startup fine every time when the key is on or off but when i start them and my engines running sometimes they just turn on warm up and flicker off and other times they work completely fine..i've basically uninstalled and reinstalled to make sure every connection is together tightly my only guess is that the ballast are bad or are the wrong watt or something..but then why would it startup completely fine with the key off??
![]() BBR SCT 93, BBK Throttle Body, Pypes O/R H Pipe Steeda:CAI, UDP, CMDP, Axle Back, Triax, Sway's Tokico Dspec w/ 1.6" Springs BMR Adj Pan, UMI UCA & LCA GMS:Strut, A Arm Brace D/S Rotors/Ceramic Pad HID 6k + 8k Fog Staggered Black S Style |
Moderator
did they come with a relay?
To the battery? No
Is this the relay harness i need?
Xtreme Hids
Moderator
that should do the trick
Thanks for the input
Purchased and installed a relay today for the headlights and it fixed the flickering and inconsistency upon startup but my question is will i need another relay for my fog lights when i install them?
Threads Similar to: HID Issue
| HID issue | 06HellFireGT | 2005 - 2010 | 15 | October 25th, 2009 02:20 AM |
| HID on/off issue | Jazzer The Cat | 99-04 | 9 | August 24th, 2009 02:17 PM |
| HID help | Megawatts88 | Audio/Video | 14 | March 2nd, 2009 01:13 PM |
| HID Help | mantis3567 | 99-04 | 10 | February 15th, 2009 01:27 PM |
| HID Help | weems | 4V / SVT | 4 | August 16th, 2008 04:11 PM |
