Autocross, Lookining at Wheels and Tires, Need Advice - Page 2
Old November 20th, 2009, 08:00 PM   #21
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
To what limit can you modify the suspension in ST? Can you use hiem joints anywhere?
Also, do you really reccomend R-Compound tires even if its your first season in the car?
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old November 23rd, 2009, 04:58 PM   #22
AirBoyzT's Avatar
2008 Mustang GT
AirBoyzT is on a distinguished road
Originally Posted by Sam Strano View Post
I can help you out... seeing that I'm not only an autocrosser, but a pretty good one. I also teach autocrossing, and know about these cars (since I own one and have multiple National Championships in them, and others).
It's not quite so simple as to take a poll on the 'net. For instance, I run 295's all around, and I also run 10's at all 4 corners with no mods to the body. 18x9.5's are no sweat and again, you can get some big rubber on there--but tires do vary a bit in actual size so not every 295 will fit, and you have to watch you wheel offset.
Steeda Pentar's aren't very expensive, I have set of those among the wheels I have have collected for the car over the years. In fact I think they are among the best looking wheels.
Anyway, my suggestions? First, understand the rules for the Sactioning body and category you want to run with. NASA does some autocross, but SCCA is the big daddy in the USA and most run with their rules. If your mod list is accurate (cold-air and a tune) you are ok for STX, STU, or ESP (not F-stock). The car can be pretty good in all 3, but best in ESP because the use of R-compound tires helps a heavy, powerful RWD car the most. In the ST classes you will have to run against lighter, smaller cars that can mod as much as you can but get power down better due to better traction on the less sticky tires vs. R-comps.
Thanks, yea my friend is just a member of NASA so that's why I was checking them out...I'm gonna check out SCCA, but not sure if they compete in VA for Autocross. As for the steeda pentars, they are kinda expensive compared to other wheels I could get, IDK yet...I think I am going to take the advice and go with regular street tires at first, mainly because I am a newbie and the fact that the track is 30min away and I have to drive the stang to get it there. I would appreciate it if you could PM me with some good mods to get me started, I don't think I will attend my first NASA event until Jan, and already ordered a helmet...I think the next mod should be Wheels and tires, I would only put them on when attending Auto Cross Events, and would keep my regular wheels and tires when not. Thanks for the help, and look forward to hearing from you!
2008 Black Mustang GT
JLT Cold Air Intake, SCT SF3 Tuner
Car Domain Profile
Threads Similar to: Autocross, Lookining at Wheels and Tires, Need Advice
advice with wheels tkwhitestang 94-95 0 October 15th, 2009 10:35 PM
Need help advice on what wheels dothedew1654 General Tech 3 July 23rd, 2008 05:42 AM
18 Inch Polished Alm. Wheels advice myroush6 2005 - 2010 8 May 16th, 2008 06:46 PM
Wheels and tires 03Gtmustang 99-04 8 March 8th, 2008 01:42 PM
20in Wheels and tires need advice Mroman27 96-98 11 January 20th, 2008 07:39 PM
