Synthetic Oil
Hi. I'm a new guy. Just got my 2007 GT last Saturday. Do you guys recommend synthetic oil or fossil oil?
Thanks for the forum. It really gives me an opportunity to learn. The last new Mustang I got was in 1971. Take care. |
11.47@120.58
Run conventional stuff until you get some miles on the car, probably around 5k or so. Then, definately switch to the synthetic stuff. It'll leaps and bounds better than dino oil but would hamper your break in if you ran it right away.
synthetic oil
My '06 GT came with a synthetic blend which is recommended in the owners manual. The gains in going to a full synthetic are very marginal.
The modualr engines are built to much tighter tolerances than your '71 engine was. For this reason alone a synthetic blend or full synthetic is desireable due to it's ability to flow into those tighter places. Basically, it's a personal choice but I'm sticking with the syn. blend for now.
Seems ok, but could use more power |
Mobil 1, use it in all my vehicles, never looked back!
2005 Ford Mustang GT - *Sonic Blue* FRPP/Whipple Supercharger Intercooled 495 RWHP / 504 RWTQ SAE Corrected @ 11psi Tuned by Kevin @ Wicked Motorsports |
#5 | |
booooost'd
2007 Mustang
Re: synthetic oil
![]() Jucostud's Official Build Thread I'm selling everything off my car, if i have something u want, pm me. 1988 lx 5.0 - Daily 2007 vortech gt - for sale 2012 mustang 5.0 - December 2011
you can run synthetic on your first oil change. i use mobil 1 .
I put mobil1 in at my first oil change around 3000 miles . My wife's 4.0 explorer threw a timing chain at 42000 miles and the mechanic blamed it on the engines running so hot that the regular oil sludges up. I had her oil changed every 3-5k miles too. If I didn't like the new mustang style so much I'd have never bought another ford after that. The mechanic did say that with synthetic the problem could have been avoided. I'm not sure if the 4.6 gets as hot but why risk it.
A man with experience is never at the mercy of a man with a theory.
I personally don't like Mobil 1. I tried it in a few other cars after breaking the engine in with conventional oil (about 10k). I did notice a little better mileage but I also noticed that it would burn off quickly. I found myself adding oil in between changes when I never had to before.
I aslo tried Castrol synthetic with same results. The best for me and my application was actually Amsoil. I still use it in my daily driver and the wifes car. Not sure what I'm going to do with the 'stang yet. More importantly, what filter are you going to use? This will have more of an effect than the oil your running on the life of your engine ( so the "experts" say)
most important, make sure you use 5-20. i changed my oil after 5-600 miles just in case the motor was'nt pre run good enough. (any loose metal)
Amsoil ????? WTF is that ? SOIL ?
Just run 100% synthetic from any major brand. An oil filter is just a filter. It is only as good as the owner and his/her replacement frequency.
Tdog 2007 mustang GT 5speed, Black |
amsoil is a great synthetic oil it's just harder to find, so i just use mobil 1 oil and filter
My First Oil change was at 2500 miles, and I have used Royal Purple ever since. I would also consider AMSOIL but is harder to find, don't forget to pick up WIX Filters, does not matter how good the oil is if it ain't clean.
___ ![]() 12.29 @ 110 All Motor (Auto w/TCI 3500 Converter & Bolt-Ons) |
Mobil One synthetic for sure - but not till at least 3k miles on the stang. Conventional oil during break in ensures everything is "seated" and broke-in properly. Synthetic lubes do not allow this to happen properly during break-in because it's so damn good.
#15 | |
then why would the stang come w/synthetic blend stock if its not good? |
I just switched my '07 gt over to Mobil 1 5W/20 full synth @ 6k miles
'07 Grabber Orange GT 5-spd Just got it 12/26/06 Tinted Windows 4.10 Gears A WHOLE LOTTA FUN!!! |
I just put in Quaker State synthetic. And my 4.6 is running a little better with it. I've always used Quaker State oil. Never had any prob's with it.
Offical MM Zepplineers crew member #4-Commander ![]()
#18 | ||
booooost'd
2007 Mustang
Synthetic blend is just that , a blend. There are no guidelines for the oil manufacturers out there to follow so your going to get a wide range of percentages of synthetic and conventional mixtures.
Once again, if you refer to your manual it will recommend the synthetic blend that came in the car for a minimum of 1000 miles ( I think that's the number) for break in purposes. Not like the old days when the break in period was significantly longer (5-10k). After that, it's personal preference. And yes, what filter you use does matter no matter what your oil change interval. Great feedback and responses.
#20 | |
Threads Similar to: Synthetic Oil
| Synthetic | Youngin | V6 Mustangs | 43 | August 31st, 2007 12:02 PM |
| conventional to synthetic | WilltheThrill | 99-04 | 18 | August 23rd, 2007 10:30 PM |
| synthetic oil ? | Blackbeauty v601 | V6 Mustangs | 6 | July 31st, 2007 11:05 AM |
| Synthetic or Regular Oil | PaperCross | General Tech | 28 | May 2nd, 2007 07:31 PM |
| Synthetic vs. semi synthetic vs. standard | stagecrewgod | General Tech | 2 | March 29th, 2007 10:33 AM |
