2005 s197 gt
temp gauge
my temp gauge is not reading atll all , just sits there like the engines, not even running anyone have/had this problem, and know how to fix it???? thanks
Eibach pro-springs,Eibach sway bars front & rear.Steeda cai /wsct x-3 tune, or-x, Steeda udp's,gt500 spoiler,qtr window scoops,steeda adj panhard bar & brace,FRPP stingers {just installed. UMI adj uca,non-adj lca, bolt in sfc. and more when I get $
2005 s197 gt
anyone?
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
Have you checked the fuses or tried reseting the computer?
QUOTE OF THE DAY (5/24/12): “I not only use all the brains that I have, but all I can borrow.” -- Woodrow Wilson |
2005 s197 gt
not yet, how do i reset the computer?
Nike Fast
Just unhook the neg terminal of the battery for about 30 minutes. What about the rest of your guages or the dash lights ( are they turn on and operating )? Cause this would rule out the fuse. Could also be a bad sensor... How many miles are on your car?
2005 s197 gt
other gauges work fine, car has 49,000 miles
Made in U.S.A.
2011 F150 FX4
I'd imagine it's a bad sensor but I've never heard of anyone having one of them go out in a S197 but I guess it's possible.
Nike Fast
Sounds to me ( which is hard to say without being at the car ) like its the sensor if everything else is reading fine. But you can still reset the computer and see if it helps any. Maybe you will get lucky...
2005 s197 gt
yea I was sort of thinking sensor, but just wanted some more thoughts, if its a sensor, any idea if its a pain to replace?
Made in U.S.A.
2011 F150 FX4
Have you removed your intake manifold lately?
2005 s197 gt
yeq I'm going to try resetting first, maybe I'll get lucky. Hmmmmm that could be taken sooooo many places!
2005 s197 gt
no,I do have a set of cmdps I need to install,which I'm curious .anyone that has them what do you do if you have to take the car in for warranty work. with cmdps installed and with the tuning issue?
#13 | |
Nike Fast
The CHT ( Cylinder Head Temp ) is located on the head under the intake manifold.
Your warranty wont automatically void just cause you have a tune. For the tune to get in the way of the warranty it would have to be something that is affected by the tune. For instance... If you had a brake problem that would be covered under warranty naturally, it would still be covered even if you brought it in with the tune. Did you get an extended warranty or something other than the factory 3yr/36k one?
QUOTE OF THE DAY (5/24/12): “I not only use all the brains that I have, but all I can borrow.” -- Woodrow Wilson Last edited by 1FastFox; January 13th, 2010 at 05:01 PM. |
Threads Similar to: temp gauge
| Temp gauge | oblivion2k | 99-04 | 3 | September 11th, 2009 12:13 PM |
| Temp Gauge. | Genevieve! | 99-04 | 13 | July 13th, 2009 05:34 PM |
| temp gauge | Anasty97Cobra | 96-98 | 2 | April 15th, 2009 11:51 PM |
| new temp gauge | burnout5.0 | 94-95 | 3 | July 6th, 2007 04:10 AM |
