Why does everyone say you have to..... - Forums at Modded Mustangs
post #1 of 76 Old January 22nd, 2010, 03:57 PM Thread Starter
IBEATU
stanglifemike's Avatar
drop the gas tank to remove/install the upper control arm mount??? About to start it and looking at it seems there would be no need. The furthest forward bolt is in under the back seat in the center and the rest are exposed under the car. Just curious. I'll let ya know what I find.
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
stanglifemike is offline
post #2 of 76 Old January 22nd, 2010, 04:12 PM
Authorized Vendor
BMR Sales's Avatar
You have to drop it down so you can get the bolt out of the upper arm.
BMR Sales Dept.
BMR Suspension Inc.
sales@bmrfabrication.com
813.986.9302
BMR Sales is offline
post #3 of 76 Old January 22nd, 2010, 04:22 PM Thread Starter
IBEATU
Well the bolt comes out just fine, its just the nipple on the UCA that wont come out. Dropping the tank now...
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
post #4 of 76 Old January 22nd, 2010, 04:34 PM Thread Starter
IBEATU
Hey Dennis, roughly how much shorter from stock should the adjustable UCA be? BMR springs
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
post #5 of 76 Old January 22nd, 2010, 04:35 PM Thread Starter
IBEATU
Also, you think I should use the upper hole(which looks to be same as factory) or lower hole? Thanks in advance
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
post #6 of 76 Old January 22nd, 2010, 05:14 PM Thread Starter
IBEATU
Well mount and adj UCA are in . Gonna wait on the Rearend bushing when ever I adjust the UCA. Havent put an angle finder on the shaft yet but it looks pretty freaking straight with my guesstimate.
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
post #7 of 76 Old January 22nd, 2010, 05:16 PM
Skirt Chasing Philanderer
1RápidoZorro's Avatar
To answer your original question... This is why everyone says you have to drop the tank.
1RápidoZorro is offline
post #8 of 76 Old January 22nd, 2010, 05:24 PM Thread Starter
IBEATU
Haha, at first glance I thought it would be possible. I will say that the torx bolts that hold the tank straps are freaking tight. My 3/8 cordless impact or 3/8 air impact wouldnt break them loose. Had to turn them by hand most of the way. Lots of loctite on them from Ford.
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
post #9 of 76 Old January 22nd, 2010, 06:17 PM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
Nasty is offline
post #10 of 76 Old January 22nd, 2010, 07:38 PM
bigpappy33's Avatar
i did it without dropping the tank...
2006 Mustang GT
GT500 5.4L 4V and TR6060 - 566 RWHP/550RWTQ - 11.17 @ 126 - Mods in Garage
bigpappy33 is offline
post #11 of 76 Old January 22nd, 2010, 07:54 PM
I don't want to drop my tank. Please explain your procedure Bigpappy!
'08 STi
'02 Supercharged Harley-Davidson F-150 (Sold)
'05 Mustang GT (Sold)
tribaltek is offline
post #12 of 76 Old January 22nd, 2010, 08:37 PM
Black Baby II's Avatar
Me too !!!!!!!!!!!!!!
Paxton 2200 SL, BBK Equal Length Shorties, Pypes Off Road X, Corsa Axle Back, Hurst Short Throw, J&M UCA / LCA / Adj Pan Rod, BMR Drop / Relo Brkts, FRPP STB / 4:10's / Diff Support / Hot Rod Cams, SCT Brenspeed Tuned, + other stuff
Cammed Crew #2
Black Baby II is offline
post #13 of 76 Old January 22nd, 2010, 08:50 PM
Do go on Pappy.
Whipple, 3.125" pulley-Comp NSR's-Meziere-Pacesetter L/T's+Outlaws-Level 10 trans-PI 3400-PH driveshaft-Auburn Pro LSD-Richmond 4.10's-CobraJet springs-Viking shocks-BMR control arms, panhard, rear sway bar-and a bunch of other really cool shit
07 Boss is offline
post #14 of 76 Old January 22nd, 2010, 08:58 PM
bigpappy33's Avatar
if you just loosen the bolt under the backseat along with removing the two bolts attached to the mounting bracket it will lower the bracket the UCA mounts to to give you just enough clearance to get it out. here is one of the write ups i followed If this is unclear. The UCA was probably the biggest PIA i did of all my suspension parts.
S197 Ford Mustang Adjustable Upper Control Arm Install | StangNet
2006 Mustang GT
post #15 of 76 Old January 22nd, 2010, 09:04 PM
Yeah I did that too when I replaced my UCA and kept my stock mount. But what he is refering to is replacing the mount as well. It looks like you can get it out, but you can't.
Try again Pappy
07 Boss is offline
post #16 of 76 Old January 22nd, 2010, 09:08 PM
bigpappy33's Avatar
oops! read too fast. Its a Friday and i started at 3! sorry :facepalm
2006 Mustang GT
post #17 of 76 Old January 22nd, 2010, 09:21 PM
Yeah...........right...............whatever....... .......
07 Boss is offline
post #18 of 76 Old January 23rd, 2010, 12:06 AM Thread Starter
IBEATU
For you who havent done it yet. It was super easy and took me about 40 minutes. All you do is remove the 2 bolts that hold the straps which support the tank. The tank lowers down, you dont even have to disconnect any of the fuel lines. If your doing the UCA and mount, theres only 4 bolts on them, the 2 bolts on the fuel tank straps, and they're out. Reverse and your done.
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
post #19 of 76 Old January 23rd, 2010, 01:56 AM
Is the rod end noisy? People told me that the poly/rod end lowers would be unbearable on the street and i can barely tell that they are aftermarket on a DD.
'09 GT/CS
TruFiber/TruCarbon, Hillbank Motorsports, AEM, Savini Forged,Toyo Tires,Hellwig Products,Cal Pony Parts,Mishimoto,Katzkin, DynoMax Exhaust
New setup coming..........
DRock is offline
post #20 of 76 Old January 23rd, 2010, 02:56 AM Thread Starter
IBEATU
My LCA's are poly and the adj. UCA is sperical. I've heard a lot of people say that theyre noisey, but I cant even tell a difference in NVH. It could just be the volume of my exhaust, but I pushed in the clutch going down hill on a rough road to quiten the exhaust, and still heard no additional noise. I was actually surprised because I was expecting some added noise, but nothing.
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
Human Verification
