2006 Mustang GT
havent been yet
sooo...i cant see! help?
so now that i got my new lights in, i cant see shit lol.
i sprayed them with Nightshade and they look great. I knew this would reduce visibility some but good god its bad. i run around with my brights on and havent been flashed yet. and i still cant see any kind of distance. anybody know if these bulbs will help? Sylvania Silverstar H10 Light Bulbs at AmericanMuscle.com - Free Shipping! also these are the lights i have....
Powerhouse 4" Driveshaft JLT CAI Xcal2 + Brenspeed 93 tune Flow 40s custom fab'd O/R Hpipe
Whatever it originally would be
You put too much on probobly.
![]() MILITARY CREW ANTI ILLEGALS CREW FOUNDER |
2006 Mustang GT
havent been yet
well i couldnt find any that i could buy shaded...and the only pair of those i found were the big halos which i didnt want. not to mention they werent dark enuf neway
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Well I'm not sure that I understand. You want darker headlight lenses (and running those little projector lights) but you want it to be brighter so you can see? WTF did you expect? I'm done.
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
2006 Mustang GT
havent been yet
thnx for the helpful input. i just didnt know it was gonna kill my lights down to nothing and wondering if anybody knew if these other bulbs would be worth my time or not
May 08 ROTM
2008 Audi S6
If your running brights and still have sight issues, the silverstars are not going to be much better. They have a much whiter light, but it isn't more intense.
Try a hid kit is my suggestion. May or may not work as well. However the output is so much greater over stock I'd rather see you try that. This is one of those learn by mistake moments. Kinda sucks, but we all been through it. A little thinner with the night shades next time.. |
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
Spray tint FTL.
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
2006 Mustang GT
havent been yet
ya....lesson learned the hard way. do you know if they make HID kits for those little projector lights? i dont know much about the HID stuff. I've looked briefly but only found the ones for the stock stang lights. thnx
#9 | |
2007 Mustang GT
![]() EMAY's right, but I don't think you can run HID's in those projectors. I think my kit said not to run them with projector housings. I think the HID's run too hot or something. Maybe try like a plastic scratch remover kit or wet sanding with 2000 grit to lighten up the spray stuff.
2006 Mustang GT
well for one thing I know that those lights you have just by themselves are dimmer then your stock lights and then you sprayed them which made them worse.
solutions wet sand it like boss says or get new lights sorry bro but we all learn from our mistakes, and others. |
2010 Mustang GT
i can tell you from experience that nightshade stuff won't come off easy with 2000 grit. I tried it out on my fogs and didn't like it so I took it off. Have to start lower like 400-500 ish and work your way up to 2000 (preferably with an orbital sander)
48.47@ 12.58
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 10 reviews
um.. run some fog lights?
I thought they looked kinda dark in your sig picture HID's Should help but those do look pretty dark so i'm not sure how much
![]() BBR SCT 93, BBK Throttle Body, Pypes O/R H Pipe Steeda:CAI, UDP, CMDP, Axle Back, Triax, Sway's Tokico Dspec w/ 1.6" Springs BMR Adj Pan, UMI UCA & LCA GMS:Strut, A Arm Brace D/S Rotors/Ceramic Pad HID 6k + 8k Fog Staggered Black S Style |
May 08 ROTM
2008 Audi S6
Only reason you can't run a hid in a projector is because the projectors lens is plastic. If it's glass as it should be, hids will be fine. HIDS run cooler not hotter than stock bulbs, but the focused light output is pinned through the lens and a hot spot occurs in the focus area.
Should be able to tell if it's a true glass projector lens at a glimpse. |
2005 Mustang GT
I just got those same headlights for christmas and finally installed them a few weeks ago. Everything I read said that they are NOT compatible with HIDs.
I have a separate issue, my high-beams are jacked, ones aimed at the sky and the other's at the ground. But we've been in the middle of (for my area) a blizzard and I haven't had much of a chance to go screw with em.
Black 05 GT, Sequential Taillights, Hand-me-down Axelbacks, Toddler Carseat |
#16 | |
MM's Resident Muffler Shop
so when are we going to work on aiming those?And OP.... :facepalm you seriously should have tried the film tint before going w/ NightShade Smoked Headlight Tint and Tint Kits for the Ford Mustang 2005 - 2009
Meine Garage ![]() MAD Stangs #9 Olivia Munn FTW Crew Founder commandersafi (10:54:49 PM): i love how much veiny sticks out |
#17 | |
2007 Mustang GT
#18 | |
2005 Mustang GT
hey, I almost posted on that shifter thread, but I didn't wanna go crazy posting on two different threads in the same day. gotta pace myself.
2006 Mustang GT
good enough
i had those lights and i just got the bulbs from 2kracing and i saw great, and there not H10s, there H1's. H10 is ur fogs
![]() 308 RWHP and 322RWT with some stuff |
2006 Mustang GT
havent been yet
thnx for the help guys. i think my highs are pointed a little low too. i guess i'm gonna try to sand a little off and try to point them upward a little to see if that helps. apparently getting new bulbs wont help and theres no way i'm buying new lights as i just bought these and i'm broke. so i guess its sand and then SOL, yay!
Threads Similar to: sooo...i cant see! help?
| Sooo....eff this | Ace417 | The Clubhouse | 26 | March 1st, 2009 07:29 PM |
| sooo | MustanG_guy17 | The Clubhouse | 21 | February 12th, 2009 12:58 PM |
| sooo | MustanG_guy17 | The Clubhouse | 10 | December 14th, 2008 12:55 PM |
| sooo guys | Blk01ponyGT | The Clubhouse | 32 | June 3rd, 2008 03:08 PM |
| Sooo | thetrooper31 | The Clubhouse | 16 | December 11th, 2007 02:47 PM |
