Question about lowering springs and need for adj. LCA's
Old March 3rd, 2007, 03:06 PM   #1
ponyup is infamous around these parts
So confused!!!
I'm ready to lower my '06 coupe and after many hours of searching the web and talking to a few shops, my head hurts!
If I want to moderatly lower the car (about an inch) all the way around, do I need new struts/shocks? I've heard both yes and no. What would I giving up if I don't replace the struts and shocks?
I've also heard that due to the lower stance the pinion angle will be off which will result in wheel hop when I launch from a standing start and premature joint failure on my driveshaft.
This would require adjustable LCA's some say, other say balony.
Can anybody clear the air here????????????
Parts, part supplier and shop recommendations are welcomed.
Seems ok, but could use more power
Old March 5th, 2007, 06:55 AM   #2
Modern_Muscle's Avatar
Modern_Muscle is on a distinguished road
Send a message via AIM to Modern_Muscle Send a message via Yahoo to Modern_Muscle
ok, im no pro, but heres my two cents,
I am planning the same as you, lowering and such.
First question, do you have the money for new shocks/struts?
Second, with the upgrade in your stangs ride height, why not upgrade your ride quality too?
Ive read on various sites about them advertising about that hurting launches, and buy our LCA's to cure it. With just an inch of drop, I dont believe you would have a problem leaving factory shocks/struts, but you probably wont have the same ride quality. I do not know of it, but I'm pretty sure that you will need an upper control arm to help it out, even Steeda says that dues to the geometry of lowered cars, the pinion angle needs correction, using their tubular upper control arm fixes this...P.N. 555-4096 $124.95 (can probably find cheaper than the Steeda site) it says to only use it on lowered cars, due to the change in pinion angle.
I am putting CHE upper and lower control arms on mine and using H&R supersports springs 1.7f/1.9r to lower it, and also adding Tokico shocks/struts for the ride quality.....
P.N. 555-8215/16 , or for Ultralite Springs (same lowering) P.N. 555-8206
If I helped you out here, good, if I confused you more, I'm Sorry... I hope I helped you out on this....
Old March 5th, 2007, 07:03 AM   #3
MaverickMLFD371's Avatar
2005
MaverickMLFD371 will become famous soon enough
Send a message via AIM to MaverickMLFD371 Send a message via Yahoo to MaverickMLFD371
this is what you will need to PROPERLY lower your car.
springs
new alignment
struts
Lower control arms
lower control arm relocation brackets
panhard bar & brace
if you continue to have wheel hop after this combination, the add a upper control arm
2005 Ford Mustang GT - *Sonic Blue*
FRPP/Whipple Supercharger Intercooled
495 RWHP / 504 RWTQ SAE Corrected @ 11psi
Tuned by Kevin @ Wicked Motorsports
Old March 5th, 2007, 12:17 PM   #4
It's not so much about the money, I just want to do it once and do it right. Not interested in having a bone jarring ride. I would like to keep it as close to stock ride quality as possible while lowering the car just enogh to close some of the tire/wheel lip gap.
I can get the eibach kit with struts and springs for about $560. If I need to add the adj. lower control arms I will. I saw a nice set at MRT. I think they were going for $225. They have offset bushings to avoid the need for relocation brackets. Anybody have any comments/experience with this part?
Just curiuos Modern_Muscle, why are you going with different manufacturers for your springs and struts ?
Old March 7th, 2007, 09:54 AM   #5
Contrary to what a lot of people think, jsut because one company is good at building LCA's, doesnt mean another company doesnt make a better version the first company's UCA's.
CHE makes great products, and Ive heard great reviews of them. Their LCA's have an integrated holder for the Parking Brake line, as well as the option of being painted to match to your car. CHE makes great CA's and braces. Tokico makes great struts/shocks, and springs is a toss-up, so I think I am going with H&R, heard great things about them too. Its like anything else out there...put it like car audio, Company A make badass subs, but their mids and coaxles are not as great as Company B, Company B;s mids are great, but their tweeters arent as good as Company C's, and neither are their subs to A, or amplifiers to Company D's...and so on. Every Company shines in a particular product(s), no company makes the absolute best of everything, at least, not yet Do you get what Im shooting at, or have I confused you more??? Hope I helped you.
1998 Trans Am WS6. (Anti Venom)
Forged 347, stage 3 T56, and a 76mm Turbo...
659rwhp @ 13.5#
~725rwhp @ 15.5#
Meth, C16, and 20psi coming soon
03 Z71 (H/C/I/E/T)...sold
2005 GT, Full Bolt-Ons...12's... GONE
Threads Similar to: Question about lowering springs and need for adj. LCA's
Lowering springs 2001Mustang Saleen 99-04 3 October 15th, 2007 05:22 PM
Lowering Springs Fitting Question!!!! Slowbra_12 96-98 2 June 10th, 2007 11:34 AM
lowering springs help!? wootmustang 5.0 Mustangs 8 March 25th, 2007 03:08 AM
What Is With Lowering Springs? mustangstud13 99-04 2 September 6th, 2006 11:33 PM
