#21 |
Priest of the Car Gods
I agree, they do seem contradictory, that's part of the joy of suspension.
Think of it as a parabolic curve - increasing stiffness will increase grip up to a certain point, after which you're losing grip. There's an "ideal" rate, but it's going to change based on a lot of factors, at least one of which is subjective (ride quality). For the S197, SFCs are superfluous. The chassis of your car is considerably stiffer than a fox-platformed car ('79-'04). Adjustable LCAs are also superfluous on S197s - the adjustment is length, which isn't very helpful. I'd just go with static length, and put the extra money into the bushing type. Other than that, the only thing I see missing from your list is CC plates, though admittedly I'd start with shocks/tires before moving on to mods.
#22 |
2009 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
so you're gonna drop it and not get UCA? what about you're pinion angle?
#23 | |
Golf Pencil Kawk Juggler
![]() Procharger D-1SC Kit - Pypes O/R H - FRPP Stingers Team Ricer GT Co-Founder
#24 |
Admanistrator
Woah there. I might have a GT40 engine swap in the works. You don't know for sure.
#25 |
GT40? Are you going 289 or 427?
#26 |
Admanistrator
I was told that with an inch drop, you don't need the adjustable UCA, and they really don't do much anyway, and that the adj. LCA's would be able to adjust the pinion enough, and so would the adj. panhard. Was I informed incorrectly?
#27 |
Why would you want to adjust two LCAs to do something you can do by adjusting a single UCA?
#28 | ||
Admanistrator
For the CC plates, I was told the camber bolts would adjust it enough because the caster isn't really effected. BMR Fabrication Inc. most of the way down the page are the bolts. Edit: This question was answered by using an adj. UCA and the fixed LCA's. Without adj LCA's, how do I adjust the pinion angle of the lowered ride?
![]() MAD Stangs #8
#29 | |
Admanistrator
I was joking. He was just being mean about my v6.
Do you agree that I need the adj. panhard as well? |
#30 | |
Yeah. When you change the ride height, you're going to change where the differential sits. The adjustable panhard bar will allow you to recenter it, rather than having it kicked off a little bit to the side.
#31 |
Admanistrator
There seem to be so many varying opinions on what is important for suspension work.
Rev, how does this list look now? non adj. LCA's adj. UCA eibach prokit lowering springs adj panhard bar CC plates |
#32 |
1989 Mustang GT 5.0
i have one on my fox mustang
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#33 |
1989 Mustang GT 5.0
ok lets think about this, if the car as a whole is sliding u need better tires, if u think and or feel the body is sliding but the tires arnt, u need a panhard bar to stop the lateral movement from the rear end (side to side movement) even with control arms u still will get up to 2inchs of play lateral movement. The sway bar is gonna tighten up body roll, not sliding, if u had crap tires with the best sway bar ud still slide but ur car would do it with no body roll.
#34 | |
Looks like a good start, what shocks are you gonna run with that?
#35 | |
Admanistrator
2005-2009 Ford Mustang Shocks, Mustang Struts at AmericanMuscle.com - Free Shipping! Especially because these shocks (except for the first two Tokico's) are pretty expensive. |
#37 | |
2007 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Sorry I had to drop out of this conversation earlier today, but the good Reverend seems to have done a good job in my absence. That's a good list to start with. I started off with pretty much that list except i went with camber bolts. Actually there not even in. I kind of like have a bit of camber up front. Not the best things for my tires but she is pretty responsive when I tug at the wheel. Anyways, like I said earlier if the rear feels sloppy with a lot of body roll vs. the rear of the car kicking out (loose), stiffening the sway bar back there will help. But like the Reverend said, you have to find a balance. With my STB, Pro-Kit springs, and couple degrees of camber, makes my car push, understeer, more than it already did. But now I've lowered the LCA's and stiffened up the rear sway bar to a point where I have less body roll and makes it easier to kick out the rear of the car, oversteer. Why? Because I would rather drive a car with a bit of oversteer than one that pushes into a corner. And I agree that you should do a little track time. Throttle control and braking technique when used properly can help you steer around corners, sometimes better than turning the steering wheel. Proper cornering techniques will help you negotiate as well, if not better than, than many suspension parts.
![]() Roush CAI-Comp NSR's-Pacesetter L/T's and O/R H-pipe-4.10's-PH Driveshaft-PI triple disc 3000-elec H2O-Pro Kit-BMR billet LCA's w/brckts-BMR adj UCA & Panhard-BMR sway bars-Bilsteins-Nitto NT05R DR's & Toyo T1R's-and a bunch of other really cool shit |
#38 |
Admanistrator
Thanks for the advice on getting track time boss. reverend said the camber bolts would get it to factory level alignment, but the cc plates would get it even better, but is it really worth the extra ~200$ to get the alignment slightly better? I know 'worth it' is very subjective, but I'm not doing any national motor-x events either.
#39 | |
2007 Mustang GT
Threads Similar to: New strut tower brace installed - back end now wishy-washy - now what?
| Strut Tower Brace??? | 06RoushProCharged | 2005 - 2010 | 4 | April 23rd, 2009 11:32 AM |
| Strut Tower Brace | 07GT-CS | 2005 - 2010 | 10 | February 12th, 2008 10:08 PM |
| strut tower brace | FIVE-0 | General Tech | 16 | July 8th, 2007 03:02 PM |
