LinkBack (4) | Thread Tools |
BBK T-Body
Hey guys, I just installed my new BBK twin 62mm t-body on my 07 stang gt. Install was simple and I fallowedthe instructions to a "t". But now the idle is way high (960-1000 rpm) according to my tach and my predator. Also upon taking it out for a drive as soon as I get ready to shift gears (no matter what rpm Im at) the rpm's hang at what ever the engine rpm's were at, at the time ( shift @ 3k and they stay there ) if I "blip" the throttle to try and get them to drop it just makes it worse, rpm's go even higher to the point I have to shut off the ignition and then start the car again to get them to drop.
Again I fallowed BBK's instructions to a "T" and tripple checked everything. I seem to be at a loss as to what to do. I also looked on there Q&A section of there web site and it talks about removing the positive and negitive conections from the battery over night to conpletely reset the ECU (Im trying it now). I was wondering if anyone else has run into the same problem and how did you fix it, need it fixed by tomarrow or Im gonna have to put the stock t-body back on till I can talk to BBK. The only other mod's I have done to the car are a, C&L race intake, Predator tune (for the c&l intake), over drive pulley's and the BBK t-body. HELP PLEASE!!!!!!!!! |
From what I've read in the forums, aftermarket TB's just give loads problems and no real performance to the new modular engines... Reason why almost noone uses them
thanks for your input, anyone else???
Sounds like the new idle stop screw is set too "hot". Back it off a few turns until the idle returns to normal. Should be all you need to do.
#5 | |
Might I also add, to me it seems like a vacume leak. So after removing the t-body and inspecting everything and then reinstalling it, with the engine running I sprayed t-body cleaner around the surface where the t-body and intake mate. No change in idle. So I dont think there is a vacume leak.
The throttle bodies are causing lots of problems on the new modular engines and BBK is aware of this. Take it off, put the stock throttle body back on, and send it back to BBK and demand a refund.
Take the money and buy yourself a delete plate. It will add much more horsepower without all the problems. Good luck. |
#8 | |
heres a quote from Maverick about aftermarket TB's sorry I could'nt help any, but with a high risk factor as this, I would stay clear of aftermarket TB's
#9 | ||
Something to check.
#10 | |
CHECK THE IDLE SCREW FIRST, ITS FREE AND PAINLESS
I'm telling you, I had the exact same symptoms when I installed my Accufab, adjusted the screw, and it runs perfect now. This may not be your problem, but it is worth checking.
#12 | |
By the way Coltdog you mentioned a delete plate. What and where can one get one of these. ( not to change the topic of my post). Pleas e keep the advice coming. It is how I/we learn. |
#13 | |
I think ghis talking about the Charging-motion delete plate.
I've been lurking the forums for far to long now...
you can get the plates from steeda or ford racing
http://www.steeda.com/products/steed...ion_plates.php http://www.fordracingparts.com/parts...tKeyField=9123
![]() heads, cams, and eforce using up all the air around |
#15 | |
Re: BBK T-Body
2005 mustang GT auto
Stoptech gt stage 2 braking system Kenny brown strut tower brace Bmr rear swaybar Bmr lower rear control arms Bbk airfilter kit Bbk ceramic short headers Magnaflow x pipe with racing cats Magnaflow Cat-Back Exhaust System Bbk 62mm twin throttle body Moto blue under drive pulley kit brentspeed Sct tuner Ford racing 4.10 gears Comp cam racing cams stage1 comp cam valve steel retainers comp cam valve springs Ford racing cmcv delete kit tci torque converter 3000stall hi iv got a 2005 mustang auto box and have the bbk throttle body as well but i think im the lucky one because i have mine on the car 4 about 6months and no problems at all i done same as you i followed everything on the paper. after i installed it i left the car to run for about 5mins then jumped in and went for a spin i did find power in the rev range after 2000rpm to about 6000rpm. good luck with yours
Sounds just like the problems I had when changing my T/B.
Except it looks like you haven't had to deal with 'forced limited power' mode. It's no fun. If you don't own a handheld tuner this will change that very fast. Our stock T/B's have been ran deep into the 10's, I would recommend spending the money elsewhere. |
1st07Stang,
Sorry I dropped off the forum and didn't catch your request for the delete plate. But, it looks like some other stang buddies have already pointed you in the right direction. Good luck with the modding. |
Well Just an update to all. I messed with the idle set screw and it help with of course the standing idle, and to my surprise it helped a little with the higher idle "drop off" after being on the gas or shifting gears, BUT not eneough to warrent keeping it on the car. The idle still "hangs" for a period of time and its more agrivating than anything. I have found the stocker does the same but not as long as the BBK. The stocker will hang for a spilt second and then the rpm's drop off. The BBK will hang for a good 5 sec. ( counting one thousand one, one thousand two, ect...). So I took it off. I did feel a differance in throttle responce and pull from 3k and up. Now with the stocker on and the over drive pulley's I also installed over the weekend I can feel a good bit of in the seat of your pants differance.
Im gonna call BBK tomarrow and see if there is a fix (dought it) for the hanging throttle. Or I might now have a new expensive paper weight. Thanks for all the input and help guys. |
get rid of that BBK T/B before you have even more problems!!
2005 Ford Mustang GT - *Sonic Blue* FRPP/Whipple Supercharger Intercooled 495 RWHP / 504 RWTQ SAE Corrected @ 11psi Tuned by Kevin @ Wicked Motorsports |
Well I dont think RPM Outlet is gonna take back the t-body, do to the fact it now has a few tool marks on it. And according to there return policy for any type of credit or exchange it has to have not been installed or be marked up. To bad I couldnt get it to work. Cause after driving around today on the stock t-body, I could tell a differance between the 2. The BBK did help the car pull harder and a little quicker. Im still gonna call BBK tomarrow and talk to them, see if they can do anything.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/15532-bbk-t-body.html
| BBK TB troubles - MustangForums.com | This thread | Refback | September 27th, 2011 12:50 PM | |
| BBK TB troubles - MustangForums.com | This thread | Refback | May 22nd, 2011 12:56 PM | |
| BBK TB troubles - Page 2 - MustangForums.com | This thread | Refback | May 1st, 2009 02:07 PM | |
| BBK TB troubles - MustangForums.com | This thread | Refback | April 30th, 2009 07:05 PM | |
Threads Similar to: BBK T-Body
| NOW FOR BODY FLEX ON MY ON FOX BODY FLEX MACHINE | keith0s | 5.0 Mustangs | 65 | October 25th, 2007 10:54 PM |
| body kit | triggerhappy101 | 5.0 Mustangs | 9 | June 29th, 2007 04:19 PM |
| body kit | cali 5.0 | 5.0 Mustangs | 1 | April 24th, 2007 08:04 PM |
| Body Kit or Body Part.. hmm | 04musclestang | V6 Mustangs | 6 | January 7th, 2007 08:29 PM |
| will a 94' to 98' body style rear end fit under a fox body | frankenstein | 5.0 Mustangs | 3 | July 13th, 2006 10:53 PM |
