SOS Pillar / Gauge's In General - Page 2
Old March 20th, 2010, 10:51 PM   #21
Skirt Chasing Phallus Phondler
1FastFox's Avatar
Kit Car/Ducati/Explorer
Nike Fast
1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future
No offense hamish, but like everything else in life you get what you pay for. Glowshift gauges have a lenghty reputation of not lasting very long. I'm sure they will function great now, but give them 6 months and see how they are working... I just don't see how someone can try to save a couple bucks on a gauge when it's monitoring A 20k investment.
QUOTE OF THE DAY (5/23/12):“Luck is what happens when preparation meets opportunity.”‐‐ Seneca
Old March 21st, 2010, 01:59 AM   #22
Hip Hop Artist
Youngin's Avatar
Byebye V6~
Welcome Home New Pony :P
Youngin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of lightYoungin is a glorious beacon of light
Send a message via AIM to Youngin
i paid a bit over than 30k -.-
ItaliStang Made.. Maybe Red But Makes One Hell Of A Sig
http://www.myspace.com/moddedmustangz
Modded Mustang's Song
Old March 21st, 2010, 02:07 AM   #23
2011 September ROTM
Yur2slo's Avatar
2006 Mustang GT
12.04 119
Yur2slo has a spectacular aura aboutYur2slo has a spectacular aura about
these are glow shifts. they are almost an exect match. but again they deffinately aren't the best. the fuel pressure only last me about 2 weeks
F1a Procharger 14psi, MMR 900, Tr6060, Remote tuned by Ray Mcclelland = Daily Driver
Numbers coming soon
14psi pump -
14psi race -
23psi race -
Old March 21st, 2010, 02:07 AM   #24
hamish's Avatar
2006 gt
hamish is on a distinguished road
No offense taken.
I personally wanted the cobalt gauges but out of my range.
As for longevity, these have a 1 year warranty.
If they are at all innaccurate I will send them back.
Saleen Supershaker
Old March 21st, 2010, 08:58 AM   #25
Hip Hop Artist
Youngin's Avatar
Byebye V6~
how does it last 2 weeks lol.. i dont understand how gauges break.. there job seems kind of simple apart from everything else in the car.
Old March 21st, 2010, 09:48 AM   #26
2009 Shelby GT500
Buck's GT500 is on a distinguished road
SOS Guages
http://<a href="http://s199.photobuc...tobucket"></a>
SoS with AutoMeter Cobalt Boost/Digital Info Guages
SLP Exhaust,3.5 Alum Driveshaft,JLT 2.6 Pulley and Carbon Fiber Intake. Shelby CS 40 Wheels BFG KDW, SoS AutoMeter, AFCO Dual Pass Heat Exchange with Moroso Tanks. Eirbach Springs, Drilled/Slotted Rotors.KR Short Shifter,Steeda Panhard
Old March 21st, 2010, 10:24 AM   #27
2011 September ROTM
Yur2slo's Avatar
2006 Mustang GT
12.04 119
when i accelerate at all it pegs the gauge
Numbers coming soon
14psi pump -
14psi race -
23psi race -
Old March 21st, 2010, 02:27 PM   #28
1FastFox's Avatar
Nike Fast
Originally Posted by hamish View Post
No offense taken.
Yeah the guages do have warranties, but if happens when they lose their accuracy and your air/fuel says your stoich but in reality your running leaner than all hell and burning stuff up without even knowing it. At that point getting a new gauge is the least of your concerns. This is what I was referring to...
Old March 21st, 2010, 03:03 PM   #29
hamish's Avatar
2006 gt
I've decided not to run an a/f gauge. I have no means to check it's accuracy.
Which one are you running?
Saleen Supershaker
Old March 21st, 2010, 03:04 PM   #30
Hip Hop Artist
Youngin's Avatar
Byebye V6~
links broken ;P
Old March 21st, 2010, 03:05 PM   #31
UrbanRedneck's Avatar
2008 Mustang GT
13.124@105.52
UrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really niceUrbanRedneck is just really nice
I think that the cobalt gauges look real good compared to the factory gauges, I like them.
Youngin, to give you a better idea about the difference between mechanical and electric gauges, a mechanical gauage is mechanically driven like fastfox said. But more specifically, an example would be that a mechanical fuel pressure guage has a fuel line going to it, so fuel is litteraly going into the car. Same for oil pressure. A mechanical boost gauge has a vacuum line attached to it. Electronic gauages are isolated with sending units, so there is a fuel pressure sending unit on the fuel rail, then wiring from it to the gauge. YOu really don't want mechanical gauges in the car. A boost guage is fine, since it just measures air, but you don't want a fuel or oil line going into the car because if it broke somehow you'd have gasoline spraying in your car. So you could mount them outside, like on the cowl for instance. But for inside-the-car uses, you want electric gauges. I know mechanical gauges used to be considered more accurate, but I don't think that is the case anymore with the technology and higher grade sending units we have today.
A a/f gauge just connects to a factory oxygen sensor and tells you what it is reading. This is completely useless, as a factory 02 sensor has a very limited range and is constantly switching from rich to lean. Basically all this will do is give you a light show as the lights bounce back and forth. A wideband a/f gauge uses a wideband oxygen sensor that must be added to the exhaust and tells you your actual, exact air/fuel ratio. This is significantly more accurate, and obviously actually useful. This is what you want.
Hurst Crew Member #20
2008 GT - ARH, C&L, Hurst, BORLA, BMR, Bilstein, FRPP, Axle Exchange. Awesome.
Old March 21st, 2010, 03:11 PM   #32
Hip Hop Artist
Youngin's Avatar
Byebye V6~
thanks for clearing that up urban.. makes sense now.
damnit cant rep ya.. someone give him some repsauce for me!
Old March 21st, 2010, 06:59 PM   #33
Predator07's Avatar
2007 Mustang GT
Not yet
Predator07 is on a distinguished road
Send a message via MSN to Predator07
Maybe this has been covered before.... But where is the best place to hook up 12v inside the car for gauge power and where you can find a good hook up for lighting that adjusts with gauge light level. If possible... Thanks!
"When keepin' it real goes wrong"
Old March 21st, 2010, 07:20 PM   #34
2011 September ROTM
Yur2slo's Avatar
2006 Mustang GT
12.04 119
i tapped in the back of the head light switch for lighting
Numbers coming soon
14psi pump -
14psi race -
23psi race -
Threads Similar to: SOS Pillar / Gauge's In General
SOS triple gauge pillar 08RoushGT 2005 - 2010 14 July 29th, 2009 07:51 PM
SOS Radio Panel Kuro 2005 - 2010 14 July 28th, 2009 03:34 PM
Foxbody in need of expert advice!help!SOS 93fourbangerstanger The Clubhouse 28 April 1st, 2009 01:16 AM
SOS Gauge Pod 05bluestang 2005 - 2010 12 November 2nd, 2008 11:06 AM
phantom II gauge's 01dutchGT 99-04 0 December 12th, 2007 11:49 PM
