weld in relocation brackets and control arms - Forums at Modded Mustangs
post #1 of 17 Old March 20th, 2010, 11:55 PM Thread Starter
2011 September ROTM
Yur2slo's Avatar
got a set of umi weld-in relocation brackets and a set of there lower control arms to put on the car to try and help with the traction
first disconnect the battery and get the car in the air supported by the body. take of the wheel and disconnect the ebrake cable from the caliper
remove the cable from the lower control arm then remove the lower control arm
next if equipped (Not sure what years the cars had these) remove the weights that bolt to the lower control arm mount on the rear end
bolt the relocation bracket in place. i had to get a shorter bolt for the upperbolt as the kit did not supply it
now weld around all edges
let it cool off. paint it and install the control arm
hook the e-brake back up
and bolt in the front
i installed it in the lower hole and at ride height i now have it going slight up hill as before it was down hill pretty hard.
repeat on the other side
F1a Procharger 14psi, MMR 900, Tr6060, Remote tuned by Ray Mcclelland = Daily Driver
Numbers coming soon
Yur2slo is offline
post #2 of 17 Old March 21st, 2010, 12:47 AM
Made in U.S.A.
Nasty's Avatar
iTrader: 12 reviews
It looks good! Good write up. Relocation brackets and LCAs really help out a lot. Now you just need that adj. UCA!
Next time you're going to be welding on it it's not a bad idea to pull the plugs or even remove the PCM, regardless of the battery being disconnected. Seen a lot of PCMs get fried because of it.
Nasty is offline
post #3 of 17 Old March 21st, 2010, 12:50 AM Thread Starter
2011 September ROTM
Yur2slo's Avatar
yeah the upper control arm is next. good to know on the pcm. Thanks!
Numbers coming soon
Yur2slo is offline
post #4 of 17 Old March 21st, 2010, 01:23 AM
Resident Brewer
The lower relocation brackets need to be properly aligned before any welding begins. You can very easily weld them in wrong and everything bolt right up, but have the rear out of proper alignment with the front axle. This write up really should stress that. Relocation brackets must be welded in using serious attention to detail using an alignment rack or have very close measurements of front/rear axle distances on the fucking money on both sides of the car before the welds are done. Bottom line...both front and rear wheel centers need to measure out exactly the same on both sides and it's super easy to fuck that up.
Sorry to jump in here and say this, but it has to be said. Do not do what this write up describes without properly setting front/rear axle distances...meaning ...you don't want your front rear axles to be out of line...like right side an inch or so more wheelbase than the left side. Very easy to screw up without an alignment rack or super close attention to detail with wheelbase measurements on both sides of the car.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, Stage II cams, Manley, MGW, McLeod RST, Eaton Posi, 3.73's, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald....Other Mustang 2015 GT Premium
Anthony05GT is offline
post #5 of 17 Old March 21st, 2010, 01:25 AM
TotoGT06's Avatar
Send a message via AIM to TotoGT06 Send a message via MSN to TotoGT06 Send a message via Skype™ to TotoGT06
What do you mean next time he's welding? I still need to weld my brackets so this was good to know
JLT cai, Borla Stinger AB, Pacesetter LT, O/R H, CMDP, UDP, 4.10, J&M LCA, Eibach Sportlines, adj panhard and brace, adj UCA and bracket, welded LCA bracket, Spydershaft, GT500 tb, SCT 93 oct
TotoGT06 is offline
post #6 of 17 Old March 21st, 2010, 01:33 AM Thread Starter
2011 September ROTM
Yur2slo's Avatar
i did measure this and the umi brackets with the upper bolt put them dead nuts so depending on the manufacture this could be different but the umi ones worked nicely
Numbers coming soon
Yur2slo is offline
post #7 of 17 Old March 21st, 2010, 09:31 AM
Resident Brewer
That's worth noting on your write up. Good looking welds by the way.
post #8 of 17 Old March 21st, 2010, 02:24 PM
HOLLYWD69's Avatar
Looks good. I need to get mine welded in. They are just bolted in right now.
See Garage for Mods
HOLLYWD69 is offline
post #9 of 17 Old March 21st, 2010, 02:31 PM
TotoGT06's Avatar
I have the bolted in ones too, I wanted them because of the extra support on the back with the metal tab. My buddy is welding it at his shop for me
TotoGT06 is offline
post #10 of 17 Old March 21st, 2010, 10:09 PM
StutteringStang06's Avatar
another LCA question, so i am ordering the BMR LCAs and relo kits and i was wondering if i could install it all my self and then drive it to the shop to get welded in to save on the install fees??
308 RWHP and 322RWT with some stuff
StutteringStang06 is offline
post #11 of 17 Old March 21st, 2010, 10:13 PM
TotoGT06's Avatar
Okay thread stealer, yes you can
TotoGT06 is offline
post #12 of 17 Old March 21st, 2010, 10:40 PM
haha srry to lazy to start my own thread and this one seamed pretty dead
post #13 of 17 Old March 28th, 2010, 12:46 PM
Excellent write up and thanks for the pictures
Like you mentioned our weld in brackets also bolt into the tapped hole in the rear end where the weight on the newer models is. This insures you can only install the bracket one way, meaning we did all the measuring to insure the rear end is centered during the design process. Of course it never hurts to double check!
Thanks again and I am glad to see you liked the product. Nice welding as well
Ryan
UMI Performance is offline
post #14 of 17 Old March 28th, 2010, 01:44 PM
TotoGT06's Avatar
One suggestion I would make UMI, that little spacer for the driver side should be a bigger piece so that 1) its easier to hold in place when trying to match up the bolt, and 2) makes another spot to weld the bracket to the axle so there isnt wasted room on the top part to make welds. Although I see that piece is already welded into the "weld in bracket" but my "bolt in bracket" was just a loose piece and was a PITA at times because I had a that top hole not matching but all the other holes did
Just did mine too and i pulled the battery wires and unplugged the PCM. Spraying up the rear axle now to make it look pretty
TotoGT06 is offline
post #15 of 17 Old March 29th, 2010, 12:37 AM Thread Starter
2011 September ROTM
Yur2slo's Avatar
the onlything i think the kit needs is the shorter bolts i had to get to replace the weights
Numbers coming soon
Yur2slo is offline
post #16 of 17 Old March 29th, 2010, 12:48 AM
TotoGT06's Avatar
I had the bolts for where the weights were, I left the weights off
TotoGT06 is offline
post #17 of 17 Old March 29th, 2010, 12:49 AM Thread Starter
2011 September ROTM
Yur2slo's Avatar
i did to but you need shorter bolts to replace them and i didn't get those
Numbers coming soon
Yur2slo is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/2005-2010/157846-weld-relocation-brackets-control-arms.html
weld in relocation brackets and control arms This thread Refback March 21st, 2010 03:01 PM
