How Do I tell what rear end gears I have? - Forums at Modded Mustangs
post #1 of 22 Old May 16th, 2010, 08:17 PM Thread Starter
Memphis's Avatar
Question How Do I tell what rear end gears I have?
Ok, so before you tell me that I am an idiot and to check the tag on the pumpkin, I got the car modified, the DEALER I bought it from had no idea if the rear end gears had been replaced. So, can I use tire height, rpm and speed? I know currently Im running between 2000 and 2200 RPM at 60MPH in 5th gear, but not sure of how to do the math here. Any suggestions ?
Thanks in advance!
Memphis is offline
post #2 of 22 Old May 16th, 2010, 08:54 PM
if your running 2200 rpms in 5th gear at 60mph i would say either 373 or 410 gears i have 373 gears and i do 2000 rpms in 5th doing 60mph
BULLITT CREW #13 (The real one)
bullitt2086 is offline
post #3 of 22 Old May 16th, 2010, 09:10 PM
shanec's Avatar
I'm not sure of the details, but it should be possible to jack up the back of the car, spin the rear wheels, and then compare the number of wheel rotations to the number of driveshaft rotations, then do some match to come up with a ratio.
shanec is offline
post #4 of 22 Old May 16th, 2010, 09:27 PM
97blkgt's Avatar
Yep. If you have to turn the driveshaft 3 3/4 times for 1 tire rotation you have 3.73's.. If you have to rotate it just over 4x you have 4.10's
03 PI 4.6, 2 row Fluidyne radiator, CAI, 90mm MAF, 24lb fuel injectors, 75mm TB/Plenum (P&P), o/r hpipe, Magnaflow mufflers, Steeda timing adjuster, 12lb alluminum flywheel, King Cobra clutch, Short throw handle, 3.73 gears, Eibach springs
97blkgt is offline
post #5 of 22 Old May 16th, 2010, 09:29 PM
Not Banned
101fng's Avatar
yep. jack up the car, put a reference mark on the driveshaft, and have a friend spin the tires ONE COMPLETE ROTATION (no more and no less). the number of times your driveshaft spins is your gear ratio. of course, it's gonna be a lil difficult to see the difference between 3.73s and 3.55s. more than one reference mark will help with this.
101fng is offline
post #6 of 22 Old May 16th, 2010, 09:38 PM
That's how I was taught to do it too. If you have 3.73s, the driveshaft will turn three complete revolutions and 3/4 of another revolution. If you have 3.55s, the driveshaft will turn three full revolutions and slightly more than 1/2 of a revolution.
The easiest way to make sure you turn the wheel exactly one revolution is to put the valve stem at the 12:00 position, then mark the driveshaft and a point to reference it to on the diff case. Then, when the valve stem goes around to the 12:00 position, you're done.
One other thing: IF you don't have posi, both wheels will have to be turned by two people at the exact same speed. Otherwise your results will be false.
carl418 is offline
post #7 of 22 Old May 16th, 2010, 10:12 PM
97blkgt's Avatar
or you could just turn the driveshaft
97blkgt is offline
post #8 of 22 Old May 16th, 2010, 10:14 PM
Seabee's Avatar
Send a message via AIM to Seabee
Dont forget they make 3.90's, but slim chance its that
EX-MILITARY CREW
ANTI ILLEGALS CREW FOUNDER
Seabee is offline
post #9 of 22 Old May 16th, 2010, 10:39 PM
Not Banned
101fng's Avatar
let me know how that works out for you
101fng is offline
post #10 of 22 Old May 16th, 2010, 10:53 PM
Alter Ego Trip's Avatar
Thanks in advance!
Well if you don't want to jack the car up. Rpm = (mph x final gear ratio x 336*) / tire diameter.
You can figure out the rest from there.
Alter Ego Trip is offline
post #11 of 22 Old May 18th, 2010, 07:39 PM
J07StangGT's Avatar
Was wondering the same thing bought mine tuned. Today I went 60mph and looked at rpm's was 2000-2200.
J07StangGT is offline
post #12 of 22 Old May 18th, 2010, 09:09 PM
bone_crusher's Avatar
Send a message via AIM to bone_crusher
probably 4.10's...
thats what i have and at 2000 rpm i am at 57-58 mph (in 5th gear)
2007 Mustang GT/CS- forged motor/cams/whipple supercharger.
Originally Posted by WAR-PARTY View Post
Fucking Marines, Ya gotta love them. The bad guys gotta fear them!
bone_crusher is offline
post #13 of 22 Old May 18th, 2010, 09:55 PM
Originally Posted by bone_crusher View Post
probably 4.10's...
That must be nice. My auto rev's 2k at 58-59 in overdrive with the 3.31's.
post #14 of 22 Old May 18th, 2010, 10:15 PM
bamagt's Avatar
Don't know about you guys but I'm running about 2800@65 with 4:10s.
~ 08 Alloy ~ JLT CAI ~ BBR Tunes ~ Comp Stage II NSRs ~ UDPs ~ MAC LT O/R Prochamber/Violators ~ Hurst STS ~ FRPP 4.10 Gear ~ BMR LCAs ~ CHE Relocation Brackets ~ BMR Adj Panhard ~ Prothane Motor Mounts ~ Coast Drive Shaft ~
bamagt is offline
post #15 of 22 Old May 18th, 2010, 10:24 PM
That sounds more accurate. Depending on tire size, you should be pushing 3k at 70 with a 4.10.
post #16 of 22 Old May 19th, 2010, 04:34 PM
J07StangGT's Avatar
I just checked and I'm at 2400-2500rpms@ 65mph
post #17 of 22 Old May 19th, 2010, 05:04 PM
go hold 2k in 5th gear or 3k in 4th and give me your speed then, tell me if you have a manual or auto and give me you tire size i can tell you what gears you have.
post #18 of 22 Old May 19th, 2010, 06:06 PM
J07StangGT's Avatar
I did 60mph in 5th yesterday and it was around 2000-2200rpm it has the BF 18's and its an auto
post #19 of 22 Old May 19th, 2010, 06:44 PM
You need the whole tire spec to calculate. That being said, you should have 3.73's based on that number. Your RPM's don't vary 200 RPM either if your tc is locked in. Are you at 2k or 2.2k?
post #20 of 22 Old May 19th, 2010, 09:43 PM
babe, let's get packed
Margarita Girl's Avatar
Thanks in advance!
Stock gears in the 2005 manual shift are 3.55's. If the gears were changed, chances are you are running an aftermarket tune. Did you get a handheld with the car? Is your speedometer off? Anyhow, I've got 4.10's and my rpms are a bit higher.
Wicked Topless GT 5-speed Crew
Margarita Girl is offline
Human Verification
