CMCV tune
Im gettin the JLT and Xcal2 combo with the 3 tunes form bamachips, but i also want the FRPP charge motion delete plates and i know you need a tune for that...so if i ask bamachips to throw that into the tuner will he? or do i have to take it to a shop and get it tuned?
oh yea and also if bamachips can tune it for me and i throw the tune on my car without having te delete plates put in yet would it mess up my car? or should i get the delete plates 1st then the JLT Xcal combo?
![]() Jesus Christ is #1 "The Founder Of Crews"
no, just call up doug or send it in before you buy it and he will give you the tune for the charge motion delete plates along with the JLT2 intake and your car will be fine bro! its better to get everything first, then the tune for the combination of everything!
2005 Ford Mustang GT - *Sonic Blue* FRPP/Whipple Supercharger Intercooled 495 RWHP / 504 RWTQ SAE Corrected @ 11psi Tuned by Kevin @ Wicked Motorsports |
ok kOo thanx
IBEATU
06 GT, 98 GT, & 93 Notch
My SCT has the cmcv delete already in it. Just waiting on installing so I can set it.
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
after getting my jlt and sct tuner i emailed doug about adding bolt on parts later. he said he wouldn't charge to change minor mods such as the charge motion deletes, udp's, ext. the only things he would charge for would be things like supercharger, nos, or adding a turbo.
![]() heads, cams, and eforce using up all the air around |
how will he change your tuner? over
the computer or do you have to send it back to him? and can any mechanic install these delete plates or should i get someone who REALLY knows mustangs?
#8 | |
damn thats real convieniant...thanx
the charge motion deletes are pretty simple and just about any mechanic should be able to do this. the question i have is can you use the plates if you get a sc such as a kenne bell or whipple. i'd hate to waste the money if they can't be used
my whipple did not reuse the stock CM plates or come with any CM delete plates. the manifold just bolted to the block.
i believe saleen has their own version of delete plates that comes with the kit. KB i am not sure
Threads Similar to: CMCV tune
| TUNE UP!!! | marks87gt | 5.0 Mustangs | 16 | October 27th, 2007 10:58 PM |
| My next mod: UDP's or CMCV deletes?? | stanglifemike | 2005 - 2010 | 54 | August 14th, 2007 09:38 PM |
| dyno tune & flash tune | miafan | 2005 - 2010 | 4 | May 31st, 2007 05:05 AM |
| To Tune or not to Tune? That is the Question! | kevnsue | 5.0 Mustangs | 24 | May 10th, 2007 08:22 PM |
| CMCV Delete | gx1856 | 2005 - 2010 | 1 | October 10th, 2006 03:58 PM |
