Diagnosing a dead cylinder
Old July 24th, 2010, 07:06 AM   #1
dysan's Avatar
dysan has a spectacular aura aboutdysan has a spectacular aura about
Exclamation
I was driving my stang last night and then all of a sudden I felt a cylinder go out, change in sound on the engine and could feel that vibration. So I get back home and start pulling the COP connectors and figured out it's the 2nd cylinder back on the driver's side, I believe that's cylinder 6? When I pulled that COP plug there's no change in the engine, so I tried swapping the COP with another one and the same cylinder stayed dead. I also compared resistance of the spark plug from top to tip and that's the same as another so I don't think it's a plug either.
I looked in the online service manual at the wiring but I don't know how to figure out which PCM plug the COP wire I need to trace goes into. On the schematic it's got a number 15 at the PCM side and along the wire there's number 1025. Ford Service Manuals - Wiring Diagrams
Does anyone know which connector the wire is in? Top, middle or bottom? I guess I should also check the wires for the fuel injector since no fuel would most likely cause the same issue.
Thanks for any help you guys can provide. I need to get this figured out this weekend so I can install the supercharger next weekend.
300 stroker @ 10.3:1, FRPP stage 2 heads, VCT lockouts. 4.10's M&H 325/50/15 DR's. J&M Extreme LCA's, JPC race UCA. Kooks 1 3/4" LT's with 3" O/R H. 10.259 @ 134.5mph with E-Force with 3" pulley. Tuned by Manuel from TUDYNO.
Old July 24th, 2010, 08:49 AM   #2
Anthony05GT is a jewel in the roughAnthony05GT is a jewel in the roughAnthony05GT is a jewel in the rough
You need to do a compression test first. If you find a dead cylinder remove that side valve cover and inspect for a valvetrain issue. I'd do this before starting the engine again. If you have no obvious valvetrain issue, but a dead cylinder, sadly, the engine will probably have to be removed or at least pull that side's head for inspection.
JDM 302 Stroker, Whipple 10 rib 12 psi, L&M, JBA, J&M, LFP, Corsa, Stage II cams, Manley, MGW, McLeod RST, Eaton Posi, 3.73's, Metco, Steeda, Autometer, CDC, Street Scene, SOS, Tuned at JPC Racing by Kevin MacDonald
Old July 24th, 2010, 02:55 PM   #3
dysan's Avatar
The odd thing is that it happened just like a switch was flicked. I finally go a code and it was a coil code. The weird thing is that the code says coil F which would be cylinder 5 but the one that's not functioning is cylinder 6. I confirmed that the correct wires are going to the correct coils so it's quite odd.
I'll be stopping by a guys shop tomorrow and we'll pull the cover as well as put a scope down the spark plug hole.
Old July 25th, 2010, 06:22 AM   #4
dysan's Avatar
Well, it was one of 2 things. I picked up a new spark plug and at the same time took the boot off the COP and cleaned the old grease and dirt from it as well as cleaned the spring real well. The combination of those 2 things fixed the issue.
I think there was too much dielectric grease in there causing an issue but I'll never know since I did both at once. Next weekend when I start the install of my E-Force I'll clean out all the COP's when changing to HT0 plugs that way it's all nice and fresh.
Thanks for the reply.
Old July 25th, 2010, 08:31 AM   #5
That was easy. I guess you're relieved.
Threads Similar to: Diagnosing a dead cylinder
one cylinder is dead why???!!? Street_Racer 2.3 Mustangs 6 March 6th, 2008 06:23 PM
dead cylinder KEIT01 5.0 Mustangs 8 March 4th, 2008 07:52 PM
need help diagnosing sonicblue 5.0 Mustangs 18 October 23rd, 2007 10:02 PM
95 5.0 Dead Cylinder behrwang 94-95 2 March 22nd, 2007 10:35 PM
dead cylinder 2001bullitt 99-04 14 January 14th, 2007 03:28 PM
