07 mustang dtc code 2104 - Forums at Modded Mustangs
post #1 of 5 Old January 18th, 2011, 11:24 AM Thread Starter
Hey all,
I stored my 07 twin turbo stang for the winter. car was running well, wen to put the battery back in a month later to give it a start and she started but the wrench light and engine light came on. I was getting the dtc code P2104 throttle actuator forced idle. so we suspected the tps because I remember during the summer every now and then before starting the car I could hear the throttle body cycle like the flaps would open and close very loudly like a machine gun type sound tact tact tac and I always had to wait for that to finish before cranking it over.
anyhow, I swapped the tps and still have the same issue, changed the actuator with a working spare and again same issue. could it be the tb itself? or maybe the gas pedal sensor gone bad.
any help is appreciated.
and this is the only code I get.
Drummerrr is offline
post #2 of 5 Old January 18th, 2011, 11:42 AM
pear0119's Avatar
Thats interesting, I was getting the same thing on my Explorer and it turned out to be the TPS. But mine had another code regarding "throttle stuck open" or something to that nature. I was going to suggest the TPS, but since you already did not sure what is going on.
JLT CAI, FRPP 4.10s, FRPP Hot Rods, FRPP x-pipe, FRPP TB, CMCV, UDP, Spydershaft, JBA Shorties, Flowmasters, Hurst Billet Plus, AM/Bama 93 race, BMR STB, BMR adj. panhard bar+brace, BMR LCA's, BMR UCA+mount, BMR front+rear swaybar, BMR A-arm brace.
pear0119 is offline
post #3 of 5 Old January 18th, 2011, 12:05 PM
May 08 ROTM
Any wiring tapped into the TPS harness for the twins - WOT switch for intercooler sprayer or similar?
Emay is offline
post #4 of 5 Old January 18th, 2011, 02:16 PM Thread Starter
No I did not trace the wiring yet, I ma getting a throttle body on loan this evening and will give that a try to see what changes if any. The thing is even if I reset the codes, the instant I turn the key on my scanner beeps with a code. so whatever it is it's sending a fault right off the bat.
post #5 of 5 Old January 18th, 2011, 08:14 PM Thread Starter
Problem resolved! Installed throttle body from another stang and everything is fine. I noticed the set screw on my old one was missing, all summer it ran fine but I guess after removing the battery the ecm did a cycle and found the flaps would go to far back without that set screw for the limp mode.
thanks guy's.
Human Verification
