Need help with lean A/F !
Hi
On my 05 Auto Stang with Procharger kit, still getting lean idle, my question … do I need to change the pump or install Ford GT pump or do a return line? Any suggestions ! |
48.47@ 12.58
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 10 reviews
if your running a stock pump... change it.
May 08 ROTM
2008 Audi S6
Definately need pumps, I ran the GT500 dual pumps on my procharged 07 GT.
I'd also suggest you get a custom tune done to make sure everything is good across the RPM range, if your getting lean codes at idle, your gonna have big problems on the top end. |
are you using the stock procharger tune?
The 39 lb injectors and piggy-back pump that came with the P1SC unit were adequate up to 480 rwhp (dynojet). Beyond that car would run lean at very high rpms. Went to 60 lb injectors and GT500 fuel system. A/F ratio is presently 11.3 at highest rpms.
#6 | |
2012 Mustang GT
2012 Mustang GT - JLT CAI, BBK L/T Headers, BBK X-Pipe, Borla S-Type axle backs, 3.73's *more coming soon* Latest Dyno: 406 rwhp 377 rwtq *need more!* MILITARY CREW
HMC(SW/AW) |
I found some here http://www.rpmoutlet.com/05gtrip.htm#1
There is the different Fuel Injectors size which one? And about the GT 40 SUPERCAR Fuel Pumps is this ok ? |
Threads Similar to: Need help with lean A/F !
| lean really lean plaese help 331 stroker | stangzilla 331 | 94-95 | 8 | January 30th, 2010 06:58 PM |
| lean | patwrecked | 5.0 Mustangs | 4 | September 10th, 2007 09:59 PM |
| Lean! | Clayhistorian | V6 Mustangs | 5 | April 24th, 2007 11:07 AM |
| RUNNING LEAN !!!! | 97MUSCLESTANG | Modular Mustangs | 6 | March 5th, 2007 09:03 AM |
| My Car Is Running Too Lean, How Do I Fix It? | SPEEDRACERCHICK02'92' | 99-04 | 10 | December 13th, 2006 11:54 PM |
