Eibach Pro Kit Installed finally!
Old May 24th, 2007, 12:49 PM   #1
GTron's Avatar
Alloy 2007 Mustang GT
13.39@103.49
GTron is on a distinguished road
I've had this kit for a couple months, but just haven't had time to put it on. I absolutely love it. To me, the ride height is perfect. Car's dirty, but what do you think?
Alloy 07 GT
Hurst Shifter
C&L Racer Intake w/Breenspeed Tune
Eibach Pro Kit
Pypes Mid-Muffler System
4.10s (Waiting to be installed)
Current Best Time: 13.39 @ 103.49 (With Intake, tune, and shifter only at the time)
Hurst crew member #8
Old May 24th, 2007, 12:50 PM   #2
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
looks real good. i have the same kit on my 04
2008 Acura TL-S - 2008 Honda Pilot EX-SE
Old May 24th, 2007, 01:04 PM   #3
GTron's Avatar
13.39@103.49
Thanks Bro
Alloy 07 GT
Hurst Shifter
Eibach Pro Kit
Old May 24th, 2007, 02:01 PM   #4
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
Looks GREAT!! Same kit I want to do. Post up some more pics
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old May 24th, 2007, 02:48 PM   #5
bander9 is on a distinguished road
looks clean any problems with it?
Old May 24th, 2007, 03:05 PM   #6
GTron's Avatar
13.39@103.49
Won't be when my adjustable panhard bar comes in. The rear end is slightly off-centered until then.
Other than that, time will tell. I'll post up if there are any problems down the road.
Alloy 07 GT
Hurst Shifter
Eibach Pro Kit
Old May 24th, 2007, 03:40 PM   #7
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
I've had the prokit on mine for a good while now, and I really like the results as well. A set of Tokiko d-specs and sways will make for a even greater improvement.
FLICKR Unique Imagery
Old May 24th, 2007, 04:08 PM   #8
GTron's Avatar
13.39@103.49
Been looking into that.
Alloy 07 GT
Hurst Shifter
Eibach Pro Kit
Old May 25th, 2007, 05:12 AM   #9
GT/CS's Avatar
GT/CS is on a distinguished road
Remeber your rear end center is not the only thing that is off now. Your lower control arm angles to your axles are actually in the negative which may cause wheel hop in varying degrees depending on your mods and driving habits.
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Old May 25th, 2007, 06:40 AM   #10
Ensit Mike's Avatar
2005 Mustang GT
Ensit Mike is on a distinguished road
gt/cs im glad you brought that up. Is there a kit from eibach that corrects this? I want to lower my car but i want to do it right. If that means new control arms and all that stuff thats fine....just gives me a reason to do it all at once!
=D
Old May 25th, 2007, 09:13 AM   #11
May 08 ROTM
2008 Audi S6
BMR has relocation brackets that you can get to make some set adjustments, but the right way would be to get an adjustable upper control arm.
Looking back you didn't mention you had purchased lower controls yet, you can get those as adjustable units as well.
Old May 25th, 2007, 09:43 PM   #12
GTron's Avatar
13.39@103.49
They're coming soon. Was going to wait until I got everything before I put the springs in, but couldn't wait any longer.
BMR Panhard bar will be on this weekend and will be getting the adjustable CA's within a couple weeks.
Went for a quick spin today and the car handles much better already. Have not had it at the drag strip yet though so not sure about the wheel hop. Wasn't any during some pretty "spirited" driving today though.
Alloy 07 GT
Hurst Shifter
Eibach Pro Kit
Threads Similar to: Eibach Pro Kit Installed finally!
finally installed spero 99-04 5 August 3rd, 2007 01:27 PM
Finally got my Longtubes installed! RStrick0352 2005 - 2010 2 June 10th, 2007 07:53 PM
Exhaust Finally Installed!!! Dawgs2099 Pictures 5 May 30th, 2007 03:43 PM
MGW finally installed neckbonekat 99-04 16 March 15th, 2007 03:01 PM
4:10's were finally installed VIDEO flattusmaximus78 2005 - 2010 10 July 4th, 2006 09:52 AM
