'07 Mustang GT Rev Limiter - Forums at Modded Mustangs
post #1 of 12 Old May 28th, 2007, 01:34 PM Thread Starter
raycutchins's Avatar
What is the stock rev limiter set to on a stock '07 Mustang GT? I was on the freeway and was going to pass a car, dropped it in third a gave it the gas. The car got to 4,000 rpm and acted as if it didn't enough fuel or air. I let off the gas and it went back to normal. I do have 4:10's installed and I am thinking that the rev limiter is set well below the 6250 red line. Feedback please!!!!
2007 Shelby Cobra GT500, bone stock, for now......
raycutchins is offline
post #2 of 12 Old May 28th, 2007, 01:41 PM
RStrick0352's Avatar
Send a message via AIM to RStrick0352 Send a message via Yahoo to RStrick0352
First off, did you recalibrate your ECM when you installed the gears? If you didnt thats what it is, there is a huge diff in how much your engin is spinning now with those lower gears. You propably were hitting the rev limiter, which by the way is set at 6,240 rpm give or take on your 07, and just didnt know it without you reprogramming the car.
GT 6sp Grabber Orange
For mods check my garage.
349 rwhp, 331 rwtrq Naturally Aspirated
445 rwhp, 495 rwtrq 100 Shot
60ft: 1.74
1/4: 12.15 @ 112.43 N/A
60ft: 1.71
11.40 @ 121.18 100 shot Nitrous
RStrick0352 is offline
post #3 of 12 Old May 28th, 2007, 05:18 PM
Send a message via AIM to cams-shelbycobra07
with new a new rearend your speedo will be wrong to
cams-shelbycobra07 is offline
post #4 of 12 Old May 28th, 2007, 07:15 PM
MaverickMLFD371's Avatar
Send a message via AIM to MaverickMLFD371 Send a message via Yahoo to MaverickMLFD371
sounds like he didnt recalibrate the speedo
2005 Ford Mustang GT - *Sonic Blue*
FRPP/Whipple Supercharger Intercooled
495 RWHP / 504 RWTQ SAE Corrected @ 11psi
Tuned by Kevin @ Wicked Motorsports
MaverickMLFD371 is offline
post #5 of 12 Old May 28th, 2007, 07:17 PM
HMUSN's Avatar
iTrader: 11 reviews
either that or you chirped your tires in third and forgot to take TC off and it cut fuel.
HMUSN is offline
post #6 of 12 Old May 28th, 2007, 08:17 PM
I hate traction control
post #7 of 12 Old May 28th, 2007, 08:46 PM
that sounds like TC and not rev limiter. Sure, you have a diff gear set, but the engine RPM is just that, RPM. It doesnt matter if you have 7.5 gears(or whatever), if you hit 6200 RPM the limiter will trip. Forget the gears. We are talking about crank revolutions per minute. You mentioned you only hit 4K RPM when this happened so look at TCS or some other system
Tdog
2008 GT500 convertible, Torch Red
TDog is offline
post #8 of 12 Old May 28th, 2007, 10:18 PM
Stkjock's Avatar
+1 to the TCS..... happened to me yesterday on the highway.... even with the damn drag radials I just put on!
Sold - 06 GT- 4000lb Rowing machine 11.49 @121.45
2008 Shelby GT500 4.0 Whipple - L&M Engines - Lund Racing Tuned - E85
Stkjock is offline
post #9 of 12 Old May 28th, 2007, 10:19 PM
Modern_Muscle's Avatar
Send a message via AIM to Modern_Muscle Send a message via Yahoo to Modern_Muscle
Thats true, the speedo on ours actually works off the front and back, I got the explanation from a tech when we were working on my car.
It wont let you give any gas if the car is in the air (we were listening to the trans)
But rpms has its sensor at the crank, while speedo is on the rear end, so his problem wouldnt be because of gears (cept for the speedo)
87 GT - All stock w/50k miles... an assload of parts waiting!
09 GMC Duramax - 520whp, big tires, big lift, big sexy!
98 T/A WS6 - 414ci, PT88, Built T56, and a shot of giggle gas... Numbers to come!
Modern_Muscle is offline
post #10 of 12 Old May 29th, 2007, 01:49 AM Thread Starter
I did reprogram it to account for the gears. I didn't chirp the wheels.
post #11 of 12 Old May 29th, 2007, 02:43 AM
and it sounds like the traction control is your problem, make sure and click that pretty button next to the radar detector power source...
post #12 of 12 Old May 29th, 2007, 08:49 AM
Tree Fiddy Z
Breakout's Avatar
Send a message via AIM to Breakout
ford positioned that power outlet very nicely for radar detectors Not that anyone would want to go fast in our cars or anything
Breakout is offline
Human Verification
