wiring question...need help
Old June 20th, 2007, 09:10 PM   #1
mustangrebuilder will become famous soon enough
im putting in gauges and i need to know on the 06 mustang which wire behind the panel were you turn the lights on is the power wire
Old June 21st, 2007, 08:18 PM   #2
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
Picture?
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old June 21st, 2007, 08:54 PM   #3
crazytaz's Avatar
crazytaz is on a distinguished road
do you have a test light to see what wires are postive wires? what type of gauge are you installing
Old June 24th, 2007, 09:12 PM   #4
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Eats Chevys, Shits Imports...
Grabber523 has a spectacular aura aboutGrabber523 has a spectacular aura aboutGrabber523 has a spectacular aura about
YUP!!! Your white (gauge light) wires from your gauges need to splice to the Black wire with the White stripe on the back of the panel light dimmer rheostat, next to the headlight switch. If you use that one, you'll be able to dim your gauge lights with your panel lights and they'll turn on and off with the parking lights...that one was easy, it was finding the 12 volt switched for the red wires that was tough for me...I used the power out from my intercooler pump relay for that...even with the volt tester I couldn't find a good power supply behind the switch...not sure why...
http://www.moddedmustangs.com/forums...p-vote-me.html
TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER)
MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER
TRUNK MONKEY CREW FOUNDER
Old June 24th, 2007, 10:39 PM   #5
crazytaz's Avatar
The white w/ blue strip is the power wire on the head light switch and the other to ground of the car. thats is for a light hookup.
Old June 24th, 2007, 10:58 PM   #6
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
Is that where you hooked up your aftermarket gauge lights, taz?
Old June 25th, 2007, 03:50 PM   #7
grabber thanks for the help and if you ever hook anything up again that needs a 12v switch soruce use a thing call add a circuit...it goes right into your fuse box...its so much easier....
but thanks again
Old June 25th, 2007, 09:10 PM   #8
crazytaz's Avatar
Ya. thats where i have my wires hooked up. the lights on the guages dim with the dash lights.
Old June 25th, 2007, 11:21 PM   #9
Your Mom's Favorite
Grabber523's Avatar
2007 Mustang GT
huh...black/white on the rheostat worked the same for me...
Threads Similar to: wiring question...need help
Question about wiring up speakers and what not Fox2102 Audio/Video 4 September 22nd, 2007 02:00 PM
Wiring harness question Dj1123 V6 Mustangs 3 June 27th, 2007 02:49 PM
wiring???? 95 mustangmiz Audio/Video 1 June 16th, 2007 12:01 PM
wiring question mustangrebuilder 2005 - 2010 4 April 27th, 2007 10:18 PM
Question About Wiring mustangrebuilder Classic Mustangs 3 November 5th, 2006 03:57 PM
