Innovate MTX L Gauge Install... - Forums at Modded Mustangs
post #1 of 12 Old May 22nd, 2012, 11:32 PM Thread Starter
CandyredGT's Avatar
Getting ready to install my Innovate MTX L wideband and MTX boost gauge. It has a white wire which in the Headlight power wire. Instructions say DO NOT attach this wire to the dinner wire. Attach ONLY to the head light wire. This gauge has an auto dim feature. So my questions are. Is the a headlight power wire behind the headlight switch? Even if there is or not I need to the color of the wire? If not behind the headlight switch where can I tap into it?
Thanks,
Nick
2009 Mustang GT
Zimmers Fab Turbo Kit
Tuned by Jeff of Precision Autosports
467rwhp and 467rwtq
CandyredGT is offline
post #2 of 12 Old May 23rd, 2012, 05:07 AM
Bob The Mo'fukkin Builda!
psycho bob's Avatar
Send a message via Yahoo to psycho bob
this is something you can find with a search. sorry if i knew i would tell you.
you could also use a multimeter and figure it out by finding which wire has power going into the light switch. you could also just put an add-a-fuse in the fuse box. this would give the gauge it's own fuse
my newest toy
psycho bob is offline
post #3 of 12 Old May 23rd, 2012, 06:05 PM Thread Starter
CandyredGT's Avatar
i used search and couldnt find anything. I am going to do an add a fuse for the power to the gauge. but this is for dimming the gauge. it has auto dim so this feature only needs power when the head lights are on.
2009 Mustang GT
467rwhp and 467rwtq
post #4 of 12 Old May 23rd, 2012, 06:49 PM
I smell like beef
Shelbydog!'s Avatar
iTrader: 11 reviews
Read this, I think it may help. You are basically wanting to wire the boost gauge into the headlight switch right? I wired my boost gauge right into the wires coming out of the headlight switch, mine was a blue/white wire but yours may be diff because its newer. The wideband needs to be wired into a source that powers only with ignition on.
gauges...some help for a member - Ford Mustang Forums
pics in post #6
4r70w Dirty 3800 Stall P1SC@9lbs TRV25 60# SVT Pump FRPP 4.10s TFS TB+Plenum MAC O/R H Flows 382rwhp 384rwtq
Shelbydog! is offline
post #5 of 12 Old May 23rd, 2012, 10:29 PM
You need to splice into the tan w/ white stripe wire that is located in pin #9 of the headlight switch.
2008 Alloy GT/Built 11:1/Comp Cams
ON3 turbo kit/Precision Billet 6765H/Full 3" Cold Side
GT500 Pumps/FRPP 80lb Injectors/KB BAP
HPX MAF/UPR Sway Bar Delete
MBRP AB/CMDPs/E85/CJ Springs
J&M LCAs/J&M Ad UCA/J&M Ad PH
700 HP 788TQ
Fuel is offline
post #6 of 12 Old May 24th, 2012, 01:15 AM Thread Starter
CandyredGT's Avatar
Shelbydog - For the actual power up for the gauge I am doing a add a fuse to a switched power source in my passenger side fuse panel for my switched power. This id for the auto dimming feature.
Fuel - Thanks I will use that wire, Are you using the same gauges?
2009 Mustang GT
467rwhp and 467rwtq
post #7 of 12 Old May 24th, 2012, 03:39 AM
psycho bob's Avatar
if you need the wire that is only hot when the lights come on just use the multi meter to find which one is that wire. you can use a paperclip opened up as a probe so you can get to the wire connection easier.
my newest toy
post #8 of 12 Old May 24th, 2012, 05:54 PM Thread Starter
CandyredGT's Avatar
cool, i am going to start with the wire Fuel told me about and go from there. i will prolly use your tip on the paper clip, never thought about doing that
2009 Mustang GT
467rwhp and 467rwtq
post #9 of 12 Old May 24th, 2012, 09:11 PM
I am using an Innovate LC-1 wideband and autometer cobalt digital boost/vac gauge. Both of my gauges also need a constant voltage signal for the dim feature and directly state to not hook up to the dimmer wire.
Here is a pic of my guages with the headlights on(in dim mode)...
700 HP 788TQ
Fuel is offline
post #10 of 12 Old May 25th, 2012, 02:35 AM Thread Starter
CandyredGT's Avatar
looking good Fuel. I will have my car back next week from the turbo kit install and dyno tuning. i am going to install my gauges shortly after i get the car back.
2009 Mustang GT
467rwhp and 467rwtq
post #11 of 12 Old May 25th, 2012, 03:04 AM
psycho bob's Avatar
still a bit brighter than the rest of the lights, but at least it's not blinding
my newest toy
post #12 of 12 Old May 30th, 2012, 08:41 PM
OP, did ya get your gauges installed?
700 HP 788TQ
Fuel is offline
Human Verification
