Meth Injection Advice! - Forums at Modded Mustangs
post #1 of 40 Old June 8th, 2012, 06:36 AM Thread Starter
NISM23's Avatar
I have a 2007 GT Supercharged and Nonintercooled. I am trying to find out if it would be beneficial to put in a meth kit or if it would be a waste of time and money. Any help on this would be greatly appreciated.
NISM23 is offline
post #2 of 40 Old June 8th, 2012, 06:59 AM
Bob The Mo'fukkin Builda!
psycho bob's Avatar
Send a message via Yahoo to psycho bob
this is a great idea. i would suggest looking through the last page or two and finding where 08redgt did the same thing for his non-cooled sc'er.
my newest toy
psycho bob is offline
post #3 of 40 Old June 8th, 2012, 07:06 AM Thread Starter
NISM23's Avatar
Thanks!! I'm also considering putting a smaller SC pulley on the blower for more boost.
NISM23 is offline
post #4 of 40 Old June 8th, 2012, 07:26 AM
slater's Avatar
i think for the money VS gain, its one of the best things to do. just make sure you spend the money on the saftey side of things. ie, low meth indicator and such, and make sure you use a reputable tuner
tri ax short shifter,4.10's, shaker,Ford Racing TB, full mac exhaust,steeda CMDP,Vortech V3Si HO,Brenspeed supercharger detroit rockers, BMR lowering springs/relo brackets/LCA's 479/417
http://www.warhorsesofamerica.webs.com/
slater is offline
post #5 of 40 Old June 8th, 2012, 08:59 AM Thread Starter
NISM23's Avatar
As I look through the Snow Performance products, they have Stages 1-3 as well as "SafeInjection" kit and low level indicators. Which of these combinations would best suit my setup?
NISM23 is offline
post #6 of 40 Old June 8th, 2012, 09:12 AM
psycho bob's Avatar
links? who's going to tune the car? you definitely want the low fluid level lights
my newest toy
post #7 of 40 Old June 8th, 2012, 09:32 AM Thread Starter
NISM23's Avatar
Well I was looking on Snow Performance : Snow Performance Water Methanol Injection Systems. The Best Most Accurate Gas and Diesel Water Methanol Injection Strategies for Fuel Injected Carbureted Turbocharged Supercharged and seeing what products they offer and I was gonna email BAMA and have them send me a tune for my SCT/SF3 handheld programmer.
NISM23 is offline
post #8 of 40 Old June 8th, 2012, 10:21 AM
2011 September ROTM
Yur2slo's Avatar
look at the aem kit. what supercharger are you running? i dont think bama will tune for superchargers. evryone has been having problems with them anyway lately it seems. i would do a remote tune if i were you with either ray at fullthrottlekustoms, lito, or vmp
F1a Procharger 14psi, MMR 900, Tr6060, Remote tuned by Ray Mcclelland = Daily Driver
Numbers coming soon
Yur2slo is offline
post #9 of 40 Old June 8th, 2012, 10:23 AM
08redgt's Avatar
A non-cooled vortech? I just did this exact same thing and have a thread on it in the last couple pages. Im using the AEM 30-3000 meth kit and snow performance boost juice. The kit is cheaper then any of the snow kits and has the same safe guards like a low level sensor and warning light should the pump fail. I'm also using a 3.48 pulley to take advantage of the lower intake temps. The only thing I have to warn you on is make sure your first spray with meth is on a dyno with the hood popped, this is crucial! The type of hose connectors that are used in these meth kits (snow included) will not hold pressure unless the hose is cut perfectly straight. On my first dyno pull the hose popped right out of the nozzle, my tuner saw it and cut the motor. Had he not seen it the 12 psi and aggressive tune could of blown the motor without the meth.
I also trunk mounted my tank and pump, you wont find any other place unless you use your windshield washer resavoir.
08redgt is offline
post #10 of 40 Old June 8th, 2012, 10:28 AM
08redgt's Avatar
If you're in CA and anywhere near LA just go to RET in Downy, call Greg he's an amazing tuner. Im at 452 wheel in 80* heat running pretty rich aa a safeguard. He's also the only good tuner you'll find here who will tune for meth.
08redgt is offline
post #11 of 40 Old June 8th, 2012, 10:33 AM Thread Starter
NISM23's Avatar
I am running a non-cooled whipple twin screw SC. I will take a look at the AEM kit.
NISM23 is offline
post #12 of 40 Old June 8th, 2012, 10:42 AM Thread Starter
NISM23's Avatar
I am up in northern california so that would be a 9 hr car ride down there.
NISM23 is offline
post #13 of 40 Old June 8th, 2012, 10:48 AM
psycho bob's Avatar
your best bet will probably be to use a local dyno and have a reputable tuner remote tune it. basically you'll use the physical dyno, but the tuner will go back and forth using email to get the tune right.
my newest toy
post #14 of 40 Old June 8th, 2012, 11:18 AM
08redgt's Avatar
That's another great option what bob said. The AEM kit also has a built in check valve so fluid doesn't get sucked in through vacuum when you're not boosting, the snow kit doesn't.
08redgt is offline
post #15 of 40 Old June 9th, 2012, 04:09 AM Thread Starter
NISM23's Avatar
To 08redgt, How would i go about driving the vehicle to the tuner without meth once i've installed the kit??
NISM23 is offline
post #16 of 40 Old June 9th, 2012, 04:29 AM Thread Starter
NISM23's Avatar
Another question I have is would it pass smog in CA?
NISM23 is offline
post #17 of 40 Old June 9th, 2012, 05:31 AM
psycho bob's Avatar
there won't be any difference in driving it to the tuner. just keep it unplugged till you get there. once there swap pullies and plug in the meth kit
passing smog you should talk to the tuner. i'm sure you could probably just keep the tune you have now and swap pullies back for smog purposes.
my newest toy
post #18 of 40 Old June 9th, 2012, 05:31 AM
slater's Avatar
meth isnt constantly injected.
but you cound install everything, run all the lines, and just leave the last connections to do once you get to shop.
slater is offline
post #19 of 40 Old June 9th, 2012, 05:33 AM
slater's Avatar
NM, bob musta been typing same time as me
slater is offline
post #20 of 40 Old June 9th, 2012, 06:00 AM
psycho bob's Avatar
you just got tree'd
my newest toy
Human Verification
