Super Charger or Turbo
Old June 28th, 2007, 12:06 AM   #1
Bayouboy4.6's Avatar
Bayouboy4.6 is on a distinguished road
which one is safer on a stock motor? i was told that a turbo is safer to use on the stock motors. but i dont see how it would be any different from a super charger?
Old June 28th, 2007, 01:11 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
there really is no reliability issue
Old June 28th, 2007, 01:19 AM   #3
FireryDriver is on a distinguished road
yeah, I'd say it depends more on what boost you run them at
SLP Loud mouths
SLP x-pipe
4.10 gears
K&N intake
X-Cal II custom tune
Old June 28th, 2007, 02:17 AM   #4
Regency 2007's Avatar
F-150 FX4
Regency 2007 will become famous soon enough
ok here is the break down on turbo vs. supercharger...
I have a Hellion turbo on my car by the way!
A turbo does not make hardly any boost from 1000-2,800RPM so in normal everyday driving your car is perfectly fine and feels like it is stock until you get on it! Also turbo's make more power per psi than a supercharger does because a supercharger is having to be driven by the motor...
The down sides to a turbo are, there are alot more parts involved and the infamous turbo lag but it is about the same or a hair more than a centripical supercharger...
I would tell you this, if you want very good dependability go with a twin screw supercharger and run it at 8psi if you are a super worried about your engine, less parts involved but in the long run your motor would like you better if you gave it a turbo, alot of it depends on how you drive, how good the tune is, and who installed the system... Hope this helps
Old June 28th, 2007, 02:46 AM   #5
IBEATU
stanglifemike's Avatar
06 GT, 98 GT, & 93 Notch
stanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nicestanglifemike is just really nice
Best thing for you is just research the two of them untill your sick. Figure out the pros and cons, and which one works better for your situation. I dont think there really is a "better" of the two, just what you want.
98 GT: some stuff
06 GT: more stuff
93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper
Paxton/Vortech Crew Member #3
FRPP's #1 Dealer
Injected Engineering
BMR Suspension
Old June 28th, 2007, 03:32 AM   #6
GT/CS's Avatar
GT/CS is on a distinguished road
Forget them both and throw a tubonator in your intake for an insane performance gains and they only cost $35! Wow!
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Old June 28th, 2007, 03:41 AM   #7
IBEATU
Yeah man those are the way to go
98 GT: some stuff
06 GT: more stuff
FRPP's #1 Dealer
BMR Suspension
Threads Similar to: Super Charger or Turbo
Super Charger, Turbo Charger Effects? Gtwrestler Modular Mustangs 15 June 9th, 2009 08:02 PM
The cheapester turbo or super charger out there LikeYouStoleIt V6 Mustangs 23 November 5th, 2007 09:50 AM
Super charger VS turbo charger stinglikeastang V6 Mustangs 25 July 23rd, 2007 11:24 PM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 05:15 PM
