2010 Mustang GT
Steel driveshaft
Hi All,
I am thinking of getting this soon: http://www.ninosport.com/Fidanza-Ste...&category=5231 Any opinions? Are there better ones out there? Thanks in advance. |
F-150 FX4
I bought an aluminum one for $100 more than that one...
I like it though, I had it installed the same time as my hellion turbo but I can tell down low that power and torque have increased, motor revs faster, and gas mileage has improved in the city some... |
2010 Mustang GT
thats cool....any inherent advantages/disadvantages between aluminium and steel driveshafts? Because if alum is better i would rather pay the 100 bucks for it. I tried researching it but i am not able to find enough info on it.
also did you have to get it retuned after the installation? I was told that it doesnt require a retune. |
I have DriveShaftShops steel one piece in my GT, I got it in lieu of them not having any aluminum ones available. The diff in weight was only 4 pounds so I figured that justified the over $100 difference in price. The guy told me the major diff between the two is that the aluminum is less prone to vibration, funny he should say that cuz I dont have any with the steel, but that if there was potential to vibrate the steel would be more prone to it. But even though that have similar power ratings the steel will still be the stronger of the two. Regency was good in describing how the power comes in more right now, and the shop I got mine from describes it as making the car feel more athletic, which I think is very appropriate. Heres a link to where I bought mine, compare prices and see what you think. If you have any questions call them, they're extremely friendly and helpful.
http://www.driveshaftshop.com/item168735.ctlg
GT 6sp Grabber OrangeFor mods check my garage. 349 rwhp, 331 rwtrq Naturally Aspirated 445 rwhp, 495 rwtrq 100 Shot 60ft: 1.74 1/4: 12.15 @ 112.43 N/A 60ft: 1.71 11.40 @ 121.18 100 shot Nitrous |
F-150 FX4
make sure you get a driveshaft loop with it, this will cost you a little extra but is good insurance... my tuner wont instal one unless you get the loop with it, he thinks it is very important to have one for insurance
2010 Mustang GT
Cool...thanks guys....appreciate it.
Here is something to chew on, 1 pound of rotating weight is equal to approximately 8 pounds of dead weight. We've seen small hp gains (under 10hp) at the rear wheels switching to aluminum not to mention the added strength and vibration dampning.
F-150 FX4
yea, I've got these huge/heavy wheels on my car... tuner said I could easily gain 20-30 rwhp if I switched them out to some smaller/lighters 18's or something...
But they look so good!
F-150 FX4
Oh, by the way... an aluminum driveshaft knocks .2 seconds off the quartermile time
Best recorded quartermile in stock GT is 13.3 by MM&FF, add driveshaft and you have a basicly stock GT doing 13.1 (If you are a good driver )
If you change your drive shaft to a one piece driveshaft, Aluminum or steel, you are going to have to adjust the pinion angles if your car is lowered. If you don't, you may have vibration and noise at certain speeds.
Here's an article on how to install a drive shaft and adjust the pinion angles: http://www.cherod.com/mustang/HowTo/...riveshaft.html For other how to articles, try this link: http://www.cherod.com/mustang/HowTos.htm |
Threads Similar to: Steel driveshaft
| Steel wheel ?'s | 2000Mustang | The Clubhouse | 9 | May 2nd, 2007 01:29 AM |
| difference in ss and alumanized steel? | 03 R Code | General Tech | 11 | April 10th, 2007 08:18 AM |
| Billet or boxed steel | leebunnyz | 2005 - 2010 | 1 | March 14th, 2007 04:11 AM |
| Steel crankshaft for 96 3.8l v6 | Easy04_jm | General Tech | 0 | October 22nd, 2006 12:50 AM |
