2007 GT
lot of black smoke on start up.
I have 29000 miles on my 07 gt. Today when I started it it blew it a big puff of real dark smoke. It does not smoke regularly. I had started it earlier today and moved it from one spot to another. Then when I started it later thats when it smoked. I noticed this one time before a month or so ago but dont remember the circumstances. I did not keep smokeing just blew it out on start up. What is this?
CHeck oil level asap. REPLACE YOUR PLUGS. A fouled plug will leave less than 100% fuel burned in cylinder. the result is smoke. What gas are you running ? Any computer codes going crazy on your dash ?
Tdog 2007 mustang GT 5speed, Black |
Softcore Porn Enthusiast
Sounds like she's running rich and your getting fuel in the exhaust. What do the plugs look like? Is she misfiring?
2005 Colorado LS, Z71 Off Road Package, I5 Vortec, Space Age Plastic Bed-Liner W/Shiny Factory Installed Deep Drop Tool Box, Twin 12 Volt Power Points...In A Whopping 200+ HP Beast.
Are there any diesel trucks near buy? Your car could be getting a crush on one and wants to show it can blow as much if not more black smoke then they can......haha j/k
Plugs, or bad gasket thats leaking oil
"Are you sure thats as big as it gets? I thought you said it was big?" 2007 GT K&N CAI, Hurst Short throw, who needs mufflers? hood scoop, hood, and spoiler painted flat black. Hurst Crew Member #12 |
2007 GT
Wow u guys were suppose to say nothing is wrong with your baby. Anyway, the oil is fine and im running 93 octane. I have the FRPP power package. So i got the tune for that, with the cai and gta's.
Change the Plugs? I thought these new plugs lasted forever. |
2007 GT
93 octane. got the frpp power package so it comes with the 91+ re-cal, cai and gta's. The oil is fine. Full sunthetic mobile one. change it a month ago. New plugs? Thought the lasted forever now.
2005 Mustang GT
10.32@137.70
sounds like it is a little rich on cold start up. probably in the tune. it shouldn't hurt anything. if it was oil it would be a blueish/white smoke from a leaky valve stem seal. does the car still have cats on it because once you remove them the cold start is a little richer and you get the black smoke. i wouldn't worry about it. had a z28 with 383 stroker and did the same thing on start up and wide band was always showing rich when it happened.
are you throwing any rich codes?
Pull your plugs and check em out, see if they are fouled. could possibly be a code mis-write somewhere in the cpu causing the injectors to spray more than they should upon startup... are you pumping it as if it were carb'd? BTW these plugs are good for 100k, but with me about to spray, i gotta have new ones
1998 Trans Am WS6. (Anti Venom) Forged 347, stage 3 T56, and a 76mm Turbo... 659rwhp @ 13.5# ~725rwhp @ 15.5# Meth, C16, and 20psi coming soon 03 Z71 (H/C/I/E/T)...sold 2005 GT, Full Bolt-Ons...12's... GONE |
I asked a friend of mine who is a distributor for AMFLEET fuel additive and said that you probably have water moisture in your tank and thats mold thats burning off. he said that could be the reason why it happened on your second start up. the first one washed it all down into your tank and then the second one sucked it all up. just throw some sort of gas additive in there that will dry it out and watch where you buy your gas from after it rains. try to buy from a gas station that is on a hill.
Maybe your car is pissed because it has 29K on it in less than a year. Try giving her a rest. I dont plug my girlfriend as much as you drive your Stang. I know we love our Stangs but
Geez
Props to another highmilin' stang driver. I have 22,000 miles on my 07, and it was parked all winter. lol
#12 | |
What mathematical formula did you use to reach that conclusion?
E=MC2
2007 GT
don't change your plugs don't even try to take them out to check them we have alumnim heads and can f*** up the heads very easliy bring it to a ford garage to have them take them out and CHECK them that way if they f*** up a head there paying not you you do not need to change you plugs till 100,000 miles but at the rate your going that will be next year
2007 GT
it could have something to do with your tune running to rich
#16 | |
May 08 ROTM
2008 Audi S6
This really does sound like a richness at start up issue, which is easily remedied in the tune if you want to. It's not necessary though, as it's not a damaging problem. I'd sit tight and when your ready for a custom tune, let your tuner know this happens so he can tweak it a hair.. |
Your Mom's Favorite
2007 Mustang GT
Eats Chevys, Shits Imports...
[/quote]Don't be affraid of changing these plugs- It's a must for the supercharged folks and I have not heard one horror story about head trouble from anyone that swapped to HTo's on this site - Nor modfords for that matter. [/quote]
I put a set of HT0's on my KB charged 07...ran like crap. Severe lurching under heavier load/low throtle settings. My fuel leaned out a bit more than anyone would like when this happened. Figured it couldn't be the brand new plugs, so I checked the vacuum system, thinking it was boost flutter. Ohm'd out the coils, thinking it was a misfire...Pulled all the plugs and checked them for spark...they were all fine. The problem wouldn't go away, so I went back to the stock heat range. Been running like a raped ape ever since. The unburned fuel from the weak cylinders was causing the ECU to pull fuel out of the mix. Even talked to Jim Bell on the phone about it, he said he's never heard of a problem with colder plugs on their mules, but if the stockers work, run 'em. The Knock sensors will still pull timing if the plugs get too hot. IDK if I just had a couple weak plugs in the batch, but they were definitely the problem. My .02
http://www.moddedmustangs.com/forums...p-vote-me.html ![]() TEAM RICER GT CREW MEMBER (11 SECOND RIDE WITH A 12 SECOND DRIVER) MEMBERS AGAINST MEMBERS AGAINST STUFF CREW FOUNDER TRUNK MONKEY CREW FOUNDER |
Threads Similar to: lot of black smoke on start up.
| White Smoke When I First Start It Up? | scrapdaddy jr. | V6 Mustangs | 14 | February 27th, 2009 01:32 PM |
| Black rims on black cars. | Chuck Strobeck | 5.0 Mustangs | 14 | August 29th, 2007 10:45 PM |
| Black 3D Carbon louvers for sale prepainted black | Coltdog | 2005 - 2010 | 0 | March 8th, 2007 07:55 PM |
| '00 Mustang V6 black smoke | Makikun | V6 Mustangs | 15 | January 26th, 2007 03:59 PM |
