engine light help!
well i have the bamachips tune for slp lms and underdrive pullies and i recieved the tuner and i called and ask if it was ok to load the tunes they said yes so i did i have been using the car for 2 -3 weeks without the pullies installed but with the tune and now i recieved a engine light??? clueless help plz...
One Man Wolf Pack
you should just load your stock tune and use that until you install the pulleys. the car will run fine cause your only mod is exhaust. try the stock tune and see is the CEL goes away. wait a sec, read the code with the tuner and the post the code on here to find out what its for.
![]() ΜΟΛΩΝ ΛΑΒΕ
how do u read the code?
also can i run the stock tune with the jlt cai on the car?
when i install either tune it says fuel level low and dte odo i forgot rest is this normal...
i checked that just now.. says nothing to read or something....
i just returned it to stock took a ride beating the shit out of it, coasting.. and nothing everythings good.. so then as a test i decided to throw in the 87 perf tune and no engine light... did the same drove it like i stole it, and coast.. nothing.. but when i returned it to stock the start up was weird... but maybe thats the jlt cai cuz the idle went high then low then high real quick... im lost right now.. |
ok so I decided to try to see if there were any dtc's and now there is when I as running just the stock tune it was these 3...
P0171 SYS TOO Lean 1 P0174 SYS TOO Lean 2 P0340 CAM POS S CIR ER 1 S 1 but if I load the 87 prf tune it only says 1... P0340 CAM POS S CIR ER 1 S 1 ... leme kno wtf is wrong.. thanks shitload... if u wat to call or text ..number is 6462967060 |
May 08 ROTM
2008 Audi S6
Well, by their listings you can obviously see your getting 2 lean condition codes and a cam position sensor issue.
If you put your stock tune it do these codes remain? If so, go to the dealer. If not, then call Bama and see if they can correct the lean condition. Lastly, I don't think this is a tune issue, I think the cam position reading is coming in false and causing the lean codes. Either way, you have to find out if they remain in stock configuration, meaning none of the Bama tunes in the car. |
Threads Similar to: engine light help!
| Check Engine Light On '01 GT | OcOnnor220 | 99-04 | 24 | September 26th, 2007 04:58 PM |
| cai engine light | blazor | V6 Mustangs | 5 | August 19th, 2007 08:21 PM |
| check engine light | 02ATIstang | 99-04 | 24 | May 22nd, 2007 05:03 PM |
| engine light | nyjetsfan4lif3 | V6 Mustangs | 6 | March 13th, 2007 09:17 PM |
| Check Engine Light | zhunter | General Tech | 10 | October 20th, 2006 03:32 AM |
