Installing a Torque Converter??
Old July 15th, 2007, 11:46 AM   #1
MustangJon255's Avatar
2005 Mustang GT
12.67
MustangJon255 will become famous soon enough
Send a message via AIM to MustangJon255
How might I go about this?
I think all i have to do is jack up the car, pull down the trans, unbolt the old stall, and slide in the new one, put trans back on??? Is that it? I know I'll need a tune but as far as mechanical goes...is that it?
"Never before has a 12 second car looked so mean and intimidating. Bring it."
Go to
www.fquick.com/americanmuscle255
for all info as well as videos!
Old July 15th, 2007, 03:06 PM   #2
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
car will have to be pretty high, remove driveshaft, remove inspection cover on front of transmission and unbolt torque converter from flywheel there are 4 of them and you have to rotate the motor to get to all of them, after push the torque out of the flywheel, remove starter, remove trans cooling lines, remove shifter cable and any other electrical connections, unbolt trans crossmember and remove bolts that hold trans to motor, drop trans and swap torque converter, make sure to put oil in converter before stabbing in trans, and rotate both ways and make sure the torque converter is fully engaged in pump on front of transmission or when you install it back on motor and try and start will destroy trans pump, to reinstall rear this post backwards
Threads Similar to: Installing a Torque Converter??
Torque converter shutter. Hudstang 96-98 0 August 12th, 2007 06:25 PM
torque converter 06Stanger 2005 - 2010 0 July 29th, 2007 11:16 AM
HOW TO FILL UP TORQUE CONVERTER? oasr87 V6 Mustangs 3 July 10th, 2007 04:58 PM
torque converter barksdaleammo 99-04 5 April 3rd, 2007 06:20 PM
Torque Converter ? BraggStang General Tech 5 August 11th, 2006 06:57 AM
