Alum. driveshaft
Old July 15th, 2007, 05:49 PM   #1
leebunnyz's Avatar
leebunnyz has a spectacular aura aboutleebunnyz has a spectacular aura about
Alum. driveshaft
what do you guys think about this driveshaft?
http://www.lmperformance.com/16405/73.html
Jesus Christ is #1
"The Founder Of Crews"
Old July 15th, 2007, 07:29 PM   #2
leebunnyz's Avatar
are there better and cheaper aluminum driveshafts out there?
Jesus Christ is #1
Old July 15th, 2007, 07:35 PM   #3
RStrick0352's Avatar
2007 Mustang GT
11.40 @ 121 mph
RStrick0352 will become famous soon enough
Send a message via AIM to RStrick0352 Send a message via Yahoo to RStrick0352
Keep in mind that the drivehsaft you have in that link is for a transmission that our cars dont come with. Thats for a Tremec TKO trans, so unless you plan on doin a trans sway also it wont work. I went out with the intention of buying an aluminum DS but ended up getting a steel because the steel shaft only weighed 3 1/2 lbs more than the aluminum and was over $100 cheaper. So unless your deadset on and ALUM one you should keep a steel in mind, they're also stronger. Heres a link to where I purchased mine, give them a call they're very friendly and can answer any questions you have.
http://www.driveshaftshop.com/item168735.ctlg
GT 6sp Grabber Orange
For mods check my garage.
349 rwhp, 331 rwtrq Naturally Aspirated
445 rwhp, 495 rwtrq 100 Shot
60ft: 1.74
1/4: 12.15 @ 112.43 N/A
60ft: 1.71
11.40 @ 121.18 100 shot Nitrous
Old July 15th, 2007, 07:38 PM   #4
Gunny's Avatar
Gunny is on a distinguished road
I have a Powerhouse aluminum 4" driveshaft in mine and I really like it. It removed all the slop when idling around in 1st gear and feels more solid. It costs though.
http://powerhouse411.com/catalog/ind...products_id=27
2006 GT 5 Speed Convertible
Whipple HO SC (461 RWHP / 444 Torque)
4.10 Gears
Pypes O/R H-Pipe
Borla Stingers Cat Back Exhaust
Various suspension goodies
For more info, visit: http://www.themorgansite.com/Mustang/mustang_info.htm
Old July 15th, 2007, 07:44 PM   #5
leebunnyz's Avatar
no i didnt know that D/S was made for a different type of tranny...thanx for the site im going to be looking into it. did you notice a difference when it was installed? did you install it yourself?
Jesus Christ is #1
Old July 15th, 2007, 07:46 PM   #6
leebunnyz's Avatar
do you have any clearance problems?
Jesus Christ is #1
Old July 15th, 2007, 07:51 PM   #7
Gunny's Avatar
There is a small standoff under the body of the car that WILL slightly rub if you don't bang it/grind it out. The tab is worthless and can be grinded right off. It seems like it was a standoff for the line when the car was built and is about half-way down the length of the shaft. I'm also pushing a ton of horsepower and that caused the issue. My car is lowered 1.75 inches in the rear with the BMR lowring kit and after making the minimal "adjustment", there has been ZERO clearance issues. I will be installing the BMR front and rear driveshaft safety loops next weekend JUST IN CASE. I had a shop do the install, but I could have probably done it myself if I wasn't so lazy.
4.10 Gears
Pypes O/R H-Pipe
Old July 15th, 2007, 10:42 PM   #8
Reverendbiker's Avatar
Reverendbiker is on a distinguished road
Re: Alum. driveshaft
Don't see anything wrong with that driveshaft, but you really might want to look at this one:
http://www.leonardracingproducts.com/drive.php
It's got a great reputation and is about the best price available.
jack <><
2007 GT Premium, redfire
5-Speed Auto
www.reverendbiker.com
Threads Similar to: Alum. driveshaft
dss alum. ds Bhblondguy 2005 - 2010 18 September 25th, 2007 05:25 AM
GT40X Turbo Alum stang94 94-95 2 May 13th, 2007 09:49 AM
found best deal on alum. driveshaft dumps 2005 - 2010 38 April 1st, 2007 09:27 PM
