Lowering Question
Old July 18th, 2007, 03:35 PM   #1
Gunny's Avatar
Gunny is on a distinguished road
Lowering Question
I put in the BMR Lowering Kit (lowering springs are 1.25" Front and 1.75" Rear) along with the LCA relocation brackets and BMR adjustable panard bar a little while back. Everything looks right and the car handles WAY better. One thing that has happened since putting the gear on is when I go over a bump that compresses the rear end (like a drainage ditch, or dip in the road), I hear a "clunk" from the rear end. It almost sounds like tools from in the trunk rattling/bouncing around once (and no, there are none). I have everything greased, torqued at ride height, etc. I am wondering what the F is making this noise. Could it be my shocks bottoming out? Any of you experience a similar situation and what was done to correct?
I'm thinking of just purchasing the adjustable Tokico D-Spec shocks for all four corners, but don't want to give up the duckets and have it not solve the problem.
Thanks for the help!
2006 GT 5 Speed Convertible
Whipple HO SC (461 RWHP / 444 Torque)
4.10 Gears
Pypes O/R H-Pipe
Borla Stingers Cat Back Exhaust
Various suspension goodies
For more info, visit: http://www.themorgansite.com/Mustang/mustang_info.htm
Old July 18th, 2007, 06:35 PM   #2
psycho bob's Avatar
07 GT
12.86@104
psycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to allpsycho bob is a name known to all
Send a message via Yahoo to psycho bob
i have the same only with eibach pro kit. i also did replace the stocks for the tokico's and have not had any noises like you are getting
Originally Posted by RZNCAIN View Post
I didn't check for spelling so fuck off with your grammar police.
http://www.moddedmustangs.com/forums...build-bob.html
Old July 18th, 2007, 07:04 PM   #3
Gunny's Avatar
What's your feeling on the D-Specs? It looks like everyone raves about them. Did they provide the appropriate spring rate for the lowered ride height? I know Tokico advertises it does all that crap, but there is no substitute for hearing it from someone who has them installed.
4.10 Gears
Pypes O/R H-Pipe
Old July 18th, 2007, 07:45 PM   #4
Skirt Chasing Phallus Phondler
1FastFox's Avatar
Kit Car/Ducati/Explorer
Nike Fast
1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future1FastFox has a brilliant future
Sounds like its bottoming out ( hard to say though without actually hearing the noise though ). another option though, did you check to make sure the isolators on the tops and bottom of the springs are in the proper position, it could be the springs hitting steel whenever tension is let out then applied agian... Might need new isolators
Old July 18th, 2007, 10:02 PM   #5
Gunny's Avatar
1FastFox, excellent suggestion. I will try and look at that tomorrow. Thanks!
4.10 Gears
Pypes O/R H-Pipe
Old July 21st, 2007, 12:13 AM   #6
05mustang_TT_charged's Avatar
2005 Mustang GT
10.32@137.70
05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough05mustang_TT_charged is a jewel in the rough
might be hitting the bump stops on the rear axle to the car, not sure i am lowered only 1.25 and never heard any noise, and i live in south louisiana and the roads are crappy around here
Old July 22nd, 2007, 11:31 AM   #7
MustangJoe65's Avatar
MustangJoe65 is on a distinguished road
i was just gonna say that. i think the bump stops will make contact before the shock bottoms out. i lowered mine about 1.5" and there is not much travel maybe 2" before the bumpstop will hit. i left it alone cuz i figured better that than the shock.
1965 Prochaged Caspian Blue / Platinum Grey Coupe
2005 Mineral Grey Mustang GT
Threads Similar to: Lowering Question
2" Lowering Question 03GT_Hybrid Modular Mustangs 6 October 27th, 2007 02:16 PM
Lowering Kit trueballerisme 2005 - 2010 3 September 21st, 2007 08:39 AM
Lowering Springs Fitting Question!!!! Slowbra_12 96-98 2 June 10th, 2007 11:34 AM
about lowering... Murderjetz General Tech 13 April 10th, 2007 12:11 AM
Question about lowering springs and need for adj. LCA's ponyup 2005 - 2010 4 March 7th, 2007 09:54 AM
