xcal 2
Old July 25th, 2007, 09:23 PM   #1
trueballerisme is on a distinguished road
xcal 2
For some reason i can only load 2 tunes...
And how do i know what tunes i have already loaded on my car. I just want to make sure that i have both of them loaded correctly
Old July 26th, 2007, 03:34 AM   #2
can anyone give me any help? also when i load the tunes is there anything else i need to do to get rid of the speed and rev limiter and that?
cause the only thing i did was load the tunes and clicked cancel for the other stuff
Old July 26th, 2007, 05:52 AM   #3
GT/CS's Avatar
GT/CS is on a distinguished road
I'm pretty sure you need to adjust the rev limiter under the optional parameters menu as these are not changed in most custom tunes.
Ford Racing heads, Comp stage III cams, 4.10's, Steeda delete plates, SLP long tube headers, Custom 3'' X pipe, Magna flow 3" Magnapacks, Airaid CAI, SCT XCAL 2 93 tune, Steeda front and rear swaybars, Dynotech aluminum driveshaft, HTP TB spacer
Old July 26th, 2007, 12:53 PM   #4
Is there anything else i need to change in the optional parameters?
Also how can i make sure i have uploaded the tunes?
Old July 27th, 2007, 01:41 AM   #5
May 08 ROTM
2008 Audi S6
Emay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud ofEmay has much to be proud of
True, there's lots of info about what your asking on the SCT site for starters.
Your question seems odd, sounded a bit like you were wondering which tune was in use in the car, by that statement I'll re-itterate tha only one tune is placed in the car at a time. The SCT holds them all and you pick which one to run. You don't store them all inside the car computer. Again your question sounded funny.
You know the tune installed successfully when the SCT prompts you with "turn key to off position" likely shortly after your car goes through several beeps and dummy light flickering during the install. Once you see that promt, you successfully loaded the tune.
When you go back in to insert a different one, you just pick the new one in the SCT you want, and follow the prompts, you don't have to un-install, it just overwrites each time.
You can't plug in and see what's currently installed (like read the cars computer), it doesn't work that way.
Lastly, only you would know what you needed changed in optional parameters, this is because you know your mods, but also because those parameters are for customizing to your liking.
For example and optional parameter is there for disabling traction control, I have that hard coded to all my tunes so it never can be on anymore unless I insert my stock calibration. Some people wouldn't like that.
Rev limiter can be put where you want based on how protective you want to be of over-reving the car. That's a personal choice type thing.. Most of those parameters are.
Hope all this helps..
FLICKR Unique Imagery
Threads Similar to: xcal 2
Another SCT XCal 3 ? auburntiger7231 99-04 1 October 25th, 2007 06:14 AM
SCT Xcal 3 ? auburntiger7231 99-04 3 October 19th, 2007 01:03 AM
SCT xcal III onederful100 2005 - 2010 2 October 12th, 2007 09:32 PM
new Xcal 3 silvergtstang99 99-04 19 October 2nd, 2007 04:51 PM
