Could someone please tell me what this is??! - Forums at Modded Mustangs
post #1 of 33 Old February 6th, 2013, 10:25 AM Thread Starter
scooter_81's Avatar
Hello all. So I've only had the car 3 weeks now and am still making my way into it. First off my mods are BBK twin 62mm TB, FRPP hot rod cams, SLP loud mouth exhaust with high flow catted x pipe, BAMA tuner. Steeda CAI. Now the problem; started my car the other morning and it died because it acted like it had a vaccum leak because it idled way down after first start. Took me forever to get it started back. Actually had to hold the accelerator half way open and it finally spitted and sputtered back to life. I was looking for any sign of a vaccum leak and found this and wasn't sure what it was. I'm guessing who ever had the car before maybe had a fuel regulator on it. If u know what it is please tell me what it is and if it could be contributing to my problem.And the car is also throwing a system too rich code.Thank u.
scooter_81 is offline
post #2 of 33 Old February 6th, 2013, 10:33 AM
cammed, geared, and blown
BlueDevil's Avatar
Maybe a throttle body issue? Mine threw a couple codes when I changed my throttle body...I had to replace the GT500 electronics with my stock ones to fix the issue. Use your programmer so you can read the trouble code (is it even throwing a check engine light?)
These cars don't use a return style fuel system, so no "regulator" like the old 5.0s. Maybe replace the fuel filter.
| KB 2.6L | MGW | 4.10 | UMI | CHE | Steeda | Eibach | SCT | VMP | Pypes | EBC | Stop Tech | Prothane | Comp SPR | Shelby |
BlueDevil is offline
post #3 of 33 Old February 6th, 2013, 10:40 AM Thread Starter
scooter_81's Avatar
It's throwing a check engine light. It reads system too rich. Do u have any idea what that might be in the picture?
Steeda CAI, FRPP hot rod cams, BBK twin 62mm TB, x pipe, SLP loudmouth exhaust,and BAMA tuner.
post #4 of 33 Old February 6th, 2013, 10:48 AM
BlueDevil's Avatar
Nope! Maybe a rigged up sending unit for a fuel pressure gauge, or part of a nitrous system? Looks like a nitrous solenoid. You wouldn't need (external) fuel system mods for cams/tb...
Did you have Bama tune the car or was it tuned when you got it? I'd call Bama and tell them what code you are throwing.
post #5 of 33 Old February 6th, 2013, 10:55 AM Thread Starter
scooter_81's Avatar
It was tuned when I got the car. I need to call bama but work nights. I need to be Zzzzzz right now lol!
post #6 of 33 Old February 6th, 2013, 11:06 AM
did you check the voltage at your throttle position sensor before you installed the bbk 62mm and copy that reading to the bbk
Badd GT is offline
post #7 of 33 Old February 6th, 2013, 01:50 PM
AmericanMuscle.com
AM_Will's Avatar
I have a feeling Badd_GT is onto the right solution. Most likely the TB needs to be adjusted or cleaned. If the throttle blade is not sync'd properly with the pedal, you'll either end up in limp mod or experience stalling/idle symptoms.
I would start by taking the TB off and cleaning it on both sides, this will get the easy stuff out of the equation. Then we can go from there if the issues continue!
Shane
Will Levantovsky | AmericanMuscle.com
Toll Free: 866.727.1266
Bama Hotline: 888.226.9764 | M-F 9AM-5:30PM EST
WIN A $1500 MMD STYLING PACKAGE
Free Same-Day Shipping!
AM_Will is offline
post #8 of 33 Old February 6th, 2013, 02:10 PM
day after I had my car tuned had this same issue, not sure if its related to that or not but took it back to the dyno shop and they fixed it, havnt had an issue since then
FRPP Hot Rod Cams
4.10's
BBK CAI
Mac LT's
Mac o/r prochamber
Pypes pypebomb
tdb4roncs is offline
post #9 of 33 Old February 6th, 2013, 05:13 PM Thread Starter
scooter_81's Avatar
alright fellas ill try that and see what happens. All the mods were all ready on the car when i bought it.Dont know what kind of past its really had? Still no ideas on what is tee'd in to my fuel rail? I think blue devil is right, maybe somebody had a fuel pressure guage on it at one time and just left the solenoid on it?? Thanks again ill try to clean the TB and let yall know what happens.
post #10 of 33 Old February 6th, 2013, 06:12 PM Thread Starter
scooter_81's Avatar
So I'm guessing since its drive by wire. The voltage is what tells the butterfly what position to b in correct? Don't know a lot about DBW.
post #11 of 33 Old February 6th, 2013, 06:13 PM Thread Starter
scooter_81's Avatar
Next question is how do you match the voltage to your TB? Does the tuner have to do that?
post #12 of 33 Old February 6th, 2013, 07:11 PM
BlueDevil's Avatar
Here ya go! Do you have a multi meter? You may have to know the original voltage off the stock tb, though... still have it? Then again, the guts to your original tb are probably what's inside the BBK unit.
For what it's worth, my stock was 1.2, and when I transferred it to the GT500 it was 1.21 so I called it good enough.
post #13 of 33 Old February 6th, 2013, 07:55 PM
new guy
Set your tb voltage at 1.25v and you will be fine.
It just has to be in a certain range to operate properly.
http://i216.photobucket.com/albums/cc235/mayo68/DSC_0037-001-1-2-1.jpg
mayo is offline
post #14 of 33 Old February 6th, 2013, 10:06 PM Thread Starter
scooter_81's Avatar
Thanks blue devil for that very helpful video. Mayo ill try the 1.25 setting. Hopefully this will take care of my problem. Thanks again!
post #15 of 33 Old February 7th, 2013, 06:10 AM
don't exactly know the significance of the setting other than BBK says to do it.Thanks for putting up the video Blue Devil. My factory setting was 1.18 for what its worth and thats what I set mine to and have never had an issue.
Badd GT is offline
post #16 of 33 Old February 7th, 2013, 07:26 AM Thread Starter
scooter_81's Avatar
Thank you.
post #17 of 33 Old February 7th, 2013, 10:17 AM Thread Starter
scooter_81's Avatar
Morning folks. Checked my TPS sensor and its reading 1.25. Thats all i have time for today but i plan on setting the bbk TB to 1.25 in the morning. Thanks again and I will fill you in on the outcome.
post #18 of 33 Old February 7th, 2013, 07:28 PM
AmericanMuscle.com
AM_Will's Avatar
cooter_81,
At least that's one step of ruling an issue out. Let us know how the TB cleaning goes, too!
Shane
AM_Will is offline
post #19 of 33 Old February 7th, 2013, 09:53 PM Thread Starter
scooter_81's Avatar
Originally Posted by AMShaneLesky View Post
cooter_81,
Shane
On the cleaning aspect I have some MAF cleaner. That should b safe for all the TB electronics right? And do I need to remove tps sensor and spring housing cap?
post #20 of 33 Old February 7th, 2013, 10:47 PM
BlueDevil's Avatar
I just hold the butterflies open and use a rag to clean the housing openings and butterfly edges. You'll see the black residue. I use maf cleaner, but less is more. Some TBs have a clear coat that you don't want to destroy.
Human Verification
